Survey Truck Size
16 Users
hillsidesurveyor
(@hillsidesurveyor)
Hello all
I am a solo owner/surveyor. I currently work out of a 2012 half ton chevy truck and tow my atv with either an open place or enclosed trailer depending on the season. (enclosed in the winter). I also tow a 23' long enclosed aluminum trailer from time to time. I am looking at upgrading trucks since my current rig is getting a bit rusty and has higher miles. While searching for trucks it is very hard to find a half ton with at least a 6 1/2' box and it seems that I can get a brand new Ram 2500 Tradesman (gas) a fair amount cheaper than a half ton. The new Ram 1500s have real good deals right now, but I don't want to pull the trigger on one since they have a brand new engine that has yet to be proven for reliability.
Do you any of you guys work out of a 3/4 ton? Do you prefer it over a 1/2 ton? Gas mileage isn't a huge issue since I generally work close to the office and don't put on a huge amount of miles. The main thing I don't like about the 3/4 ton is that they sit up so high and it would be more difficult to reach all of my equipment in the truck bed. I did see though that there are aftermarket springs available for the Ram to lower the rear a few inches.
Thanks,
Posted : October 31, 2024 1:38 am
john-putnam
(@john-putnam)
Supporter
I would avoid 1/2-ton trucks for survey work. When loaded with standard kit, my trucks have always tended to weigh in at the upper limits of 1/2-ton trucks. That continuous stress is hard on them.
Posted : October 31, 2024 1:53 am
Supporter
I have a 2500 Ram 8' box with the ATV in the back. I also have a new 3500 Ram with the same configuration. The 2500 is a 2012 and has been bullet proof, I've had no issues with the 3500 so far and it's a pleasure to drive. I don't like pulling trailers, it's much better loading the four wheelers in the back of the truck. Even if I didn't load the ATV in the truck I still wouldn't do the 1/2 ton, I carry too much stuff.
The Rams sit higher which is a plus, I can't imagine lowering them for where I go. I tried a GMC but it dragged everywhere, so I had it lifted and it never drove right again. I've used fords and I'm not against them, the Ram Tradesman is more of a work truck to me. You would be happy with the 3/4 ton no matter which version you get, but the one ton is perfect for heavy duty surveying.
Posted : October 31, 2024 2:05 am
Norman_Oklahoma
Member Debater
I have worked out of a Toyota Tacoma for an extended period. It's quite do-able as long as you are pretty dogmatic about what goes, and stays, in there. Nevertheless, I share John's point of view about 3/4 tonners standing up better in the long term. But if much of your work is in an urban environment the smaller unit might be the better choice.
Posted : October 31, 2024 2:38 am
BStrand
(@bstrand)
Member Debater
I bought a 2021 Ram 1500 6.5' bed and put a decked box in it with a tonneau cover and I think it's a great configuration for what I do. I don't tow anything with it, but I wouldn't be worried about it if I had to.
I used a Ford 3/4 ton crew cab 6.5' bed at one place I worked and I didn't care for it. It didn't have running boards which made it an annoying pain in the ass to get in and out of and the backseat space was mostly wasted.
If I was frequently towing side by sides around the mountains and doing heavy civil work I might buy a 3/4 ton, but for the stuff I do a 1/2 ton is totally sufficient.
Posted : October 31, 2024 4:31 am
Tom Bushelman
(@tom-bushelman)
Supporter Debater
I've been surveying out of the back of an F-350 dually 4 door, 8' bed for the last 18 years. Plenty of room for equipment and 4 wheeler right in the bed. Just hauled 40,000 lbs of hay today with it also. Not good if you do a lot of urban stuff but great otherwise. Trucks with dual rear wheels actually sit a couple inches lower than their single rear wheel counterparts which makes bed access a lot easier. And from about 2023 and up, most trucks have built in steps on the outside front and rear of the beds. Very handy. Unfortunately, I just bought a 2022 model without that.
Posted : October 31, 2024 6:03 am
I'm glad I'm not in the market for a new truck. I'm still driving a 2008 Tundra 2WD SR5 regular cab with 8' bed, 5.7L V8 and towing package, and it's been perfect for the kind of work I do (mostly urban/suburban, with a fair bit of flatland rural/ag in the mix). I paid around $25k when it was new in 2007. A new SR5 (can't get a regular cab anymore; can't get a V8 anymore, either) with comparable features would run close to $60k. I only have about 70k miles on it, so I'm counting on it to carry me all the way to retirement.
Posted : October 31, 2024 3:13 pm
lukenz
(@lukenz)
I work solo out of a 2019 Suzuki Vitara Allgrip (small SUV, 1.6l) and has plenty of room for rural and urban boundary work I do. Tools behind cargo barrier in boot and instruments on backseat in footwell + on seat strapped down with seatbelt. Poles sit beside rear passenger seat. Only need Leica legs for robot/gnss base + lightweight set for backsight.
Most firm here use utes with canopy over the tray which are similar size to the Toyota Tacoma, never understand why such big trucks are used elsewhere. If it wasn't for https://www.portacone.com/ I would have needed a ute too.
Posted : October 31, 2024 5:24 pm
hillsidesurveyor
(@hillsidesurveyor)
Thanks for the replies. I work mostly rural ag land, but do some lot surveys etc. I would estimate that I would have around 700 lbs of gear (including the wood box organizer) in the back end at all times, so I don't think that would be overloading a half ton truck to much. For those that haul their ATV in the back of the truck, where do you store all of your other gear? Do you use the standard box or have a specialty service box with side doors etc. ? I will have to go do some test drives and see what works the best.
Posted : October 31, 2024 11:41 pm
Supporter
truck:
Posted : November 1, 2024 12:59 am
dmyhill
(@dmyhill)
Supporter
We used to work out of 3/4 ton suburbans, but those are all used for kid haulers now...
I believe that 3/4 ton is a good idea for a number of reasons. The biggest drawback is that any modern truck that is 3/4 ton is so far off the ground that it is a PITA to work out of. We got a Ram 2500 and no one wanted to work out of it.
A Toyota Tundra, with helper springs in the back ended up being the favorite truck in the stable.
Posted : November 1, 2024 9:01 am
hi-staker
(@hi-staker)
Member Debater
Quote from MightyMoe on November 1, 2024, 6:59 am
truck:
Is there supposed to be a picture or link with this post? All I see is "truck:"
Posted : November 5, 2024 4:23 am
Supporter Debater
As has been said, it all depends on what you do. We are in the PNW performing a mix of construction staking, casastral, design boundary and topo, and a few other tasks mixed in. We do a lot of offroad and tow occasionally.
We started buying Ram quad cab 2500s with short boxes. They have the rear step and full length side bars. This is a great setup for us.
We bought our first rig like this in 2015. It's pushing 280k miles and is now the primary rig for our Washington office. Not bad for a gasser. The last two we bought were diesel. It's getting hard to buy a bad 3/4 ton truck.
I would not equip a crew with a half-ton truck for most duties. Puttzing around the office deciding what comes and goes creates unnecessary chaos and burns time. Driving an overloaded truck puts people, equipment, and business at risk. Don't get me wrong. There are tasks where the half-ton carries what you need. They are the exception, not the rule...
Posted : November 17, 2024 10:38 am
OleManRiver
(@olemanriver)
Member Debater
I run a F350 4 door gas. It’s a farm truck survey truck and a take the kids to school truck. Haul eve from hay to Barbie dolls. lol. I have the base model XL trim package. I could easily fit a 4 wheeler in bed if I wanted as well as equipment. If I were to go solo I would probably buy a cab n chassis. Put a flatbed on it. Mount tool boxes custom made for things at the edges and up front cab. For all the survey supplies. Have tie downs to drive atv up on flatbed and be off. The bed on a chassis cab would probably be taken off and placed on the next truck when the time came. Manufacture would be of no concern as the chassis are all straight and standard. Also easier to get things out than over these new trucks the regular beds are so high for a short legged man. The great thing about the flatbed is you can customize it as you go. Maybe an old cross over toolbox from a yard sale just bolt it down. Don’t like it anymore take it off get something different.  For surveying I would probably go single rear. Use an under the bed toolbox and run power inside and have a charging station.
Posted : November 18, 2024 8:21 pm
Supporter
try it again:
Old truck
Posted : November 19, 2024 11:14 am
Norman_Oklahoma
Member Debater
Posted by: @hillsidesurveyor
... I would have around 700 lbs of gear .... in the back end at all times, so I don't think that would be overloading a half ton truck to(o) much.
Driving around with half, or even a quarter, of a full load all the time puts a special kind of wear and tear on the vehicle.
Posted : November 20, 2024 10:26 am
anonymous_9036
(@Anonymous 9036)
Guest
Hello all
Thanks,
20241120 151003 HDR
I attached two pictures I took yesterday of our companies recently retired 2010 Tacoma with 260,000kms after 14 years of carrying survey years with the original shocks. It always felt overloaded. The rest of the trucks are half tons including my 2005 Silverado with 430,000kms.
Depending on what your carrying you might need a 3/4 ton.
This post was modified 5 months ago by Anonymous 9036
Posted : November 21, 2024 7:41 am
party-chef
(@party-chef)
I prefer full size vans. Really a shame they don't make stock awd or 4wd options but way nicer for working out of.
Posted : November 24, 2024 7:25 am
Jon Collins
(@jon-collins)
I've always used 3/4 tons since we all moved away from suburbans. Just a little stronger for what we do and not very much more than a 1/2 apples to apples. Couple grand.
Posted : November 26, 2024 3:24 pm
Supporter Debater
Posted by: @party-chef
I worked out of a Ford Transit, AWD the last few years and mostly loved it. Best part was I had standing room in the back to change in n out of winter gear. Going off road with it was dicey. They became difficult to get after Amazon bought up a good bit of the production for delivery vehicles.
Posted : November 26, 2024 4:50 pm
