Question about RTN ...
Question about RTN Field Procedure
17 Users
20 Reactions
I'm assisting a colleague with a boundary survey spanning 2 sections.  He doesn't have time to compile the map, so he asked me to prepare it for his signature.  In addition to title reports and deeds, the only field information he provided were RTN coordinates of the control monuments his field crew tied in.  Since the boundary needs to be on ground rather than grid, I asked for the jxl files so I can adjust and convert the SPC positions to ground positions.  In examining the one jxl he sent, I see that of the 9 controlling corner monuments found, all but one of them were located with a single 3-epoch observation; the other has only one single-epoch shot.
Is that really the way boundary control is being done these days?  I know I'm a dinosaur, but that seems like pretty skimpy data to hang a boundary on.
Comments?
Posted : August 12, 2026 8:26 am
Well, at least all the monuments were found.
But if someone needs to reset one in the future from his survey drawing, I wouldn't expect it to be as close as it could have been to the old position.
Posted : August 12, 2026 9:53 am
Norman_Oklahoma
I'm as appalled as you are, but I think know that what you are seeing is common.  What is more, I think it likely that your PLS client doesn't know that it is happening this way. Luckily, with the current state of technology, the coordinates are probably good enough. Whatever that means.
Posted : August 12, 2026 10:36 am
That is really sketchy. Just be glad it's not your name on it at the end of the day. I don't think I would be able to hold back on saying something to that effect to the person staking their name and reputation on it.
Posted : August 12, 2026 11:47 am
john-putnam
(@john-putnam)
Jim,
Way sketchy.  Call me old school but monuments get a minimum of 180 epochs on two discrete observations.  I like to shoot for four hours between observation. In my 30 plus years of GNSS experience, I can not tell you how many times the two observations don't jive.
What is the issue with preparing the map in the native grid?
Posted : August 12, 2026 1:31 pm
1
jimcox
(@jimcox)
That would be an unacceptable cadastral field procedure here in New Zealand - GNSS data should be two sets of observations separated by at least 30 minutes.
While not mandated, for me each set has two measures of at least 60 epochs averaged with a 180 pole spin between.
Posted : August 12, 2026 2:13 pm
I will guarantee you that , Joe Fieldwanderer, does not perform up to the goals that have been stated.  The only way those goals will be met is if the PLS takes the time to track exactly every shot taken versus time of day of the shot and then enforces penalties for failure to meet expectation.  Of course, that also dictates that the PLS bill out time accordingly to the client.
There are shots in the field that may take over 30 minutes roundtrip to access out in the wilds of PLSSia.  Too hot, too cold, too windy, rain is going sideways, too difficult to access, whatever.  It's not going to happen because "we" collectively are not as tough as the oldtimers who had to do it the hardway.  One hundred feet at a time through every inch of obstacles, on foot, teamed with a doofus, all uphill and then the chain breaks and you notice the tripod tilted too far.  Hell, I remember turning a 90 to get back on line by doing a 30-40-50 triangle based on a best guess alignment.  That's how you determined the distance to the center of a center.  Forget that theoretical crap about rossing straight lines between quarter corners.  And, on a curve??????????  What a farce?
Posted : August 12, 2026 4:48 pm
Posted by: @john-putnam
If it was simply a matter of aliquot parts, I might do it on grid.  But this job entails dozens of parcels and exceptions, with a lot of oddball bearings (some parallel with a railroad, some following a creek), so making the comparisons with record dimensions will be simpler (for me, anyway) if it's on a local basis of bearings and using ground distances.
Posted : August 12, 2026 7:14 pm
@jim-frame
"and using ground distances."
AMEN  I detest basing description writing in "in the sky" coordinates.  That can be a far larger descrepancy than being out of level.
Posted : August 12, 2026 11:29 pm
Norman_Oklahoma
Posted by: @holy-cow
With the new 2022 datum Kansas will have 20 zones, 19 of them LDPs. The difference between grid and ground distances will be small enough to ignore. That may seem like a lot but remember that Oregon has had 39 LDPs for over a decade.
Posted : August 13, 2026 3:11 pm
john-putnam
(@john-putnam)
@jim-frame, in these cases I like to create separate drawing for the various records.  I then Xref them into my boundary drawing.  This way you piece the puzzle together by translating and rotating them onto your found monuments.  When working with SPC coordinates you can even scale the xrefs by the C.F. to bring them to the grid.  If you like record line, then NCOPY it from the xref into the working drawing.
Works great for coming up with search coordinates.
Posted : August 13, 2026 6:24 pm
2
That's pretty much my practice, though instead of XREF I just keep the record parcels on a separate layer (or more than one layer when things are especially complicated).
Posted : August 13, 2026 8:30 pm
2
Norman_Oklahoma
I’ll make them a block, residing on a separate layer. Makes it easier to keep together.
Posted : August 13, 2026 9:42 pm
1
peter-lothian
(@peter-lothian)
Posted by: @norman-oklahoma
Ditto. It amazes me to receive CAD files from other surveyors that don't have separate layers for the record info vs. final boundary determination.
Posted : August 14, 2026 6:31 am
2
murphy
(@murphy)
I'm down to three observations, each for 30 seconds with around 20min or more time separation but that's only for NC and SC RTNs where I've tested with static and total station. I've had bad luck with hodge-podge of RTNs in VA and elsewhere.
After all of the years of viewing examples on this site showing higher quality data from base/rover, I've finally switched to that process and just use the RTN as a check on the RTX-PP coordinate that TBC creates from my base receiver's .T04. I should have listened to many of the folks on this forum as any time lost setting up the base has been recaptured by higher precision, particularly under canopy.
Posted : August 14, 2026 12:17 pm
1
Learner
(@learner)
I get very good repeatability with Carlson BRX7s Base Rover pair, even under heavy (but not full) canopy.  I usually occupy a point for at least 30 seconds, sometimes up to 3 minutes depending on how good the solution math 'looks' on the screen.  When I have good confidence on the first shot, I can't remember a time when I didn't get the same results the next time.  Get iffy data the first time, then all bets are off.  I have also seen a point that wouldn't fix 5-15 minutes before return a tight solution in the time it took me to look at how to navigate to the next point or cut a little bit of line thinking I was going to need to run the line in with TS.  The version of SurvPC I'm running has Carlson's SureFix, so it's a double solution from the beginning anyway.
Posted : August 14, 2026 1:58 pm
MountainHermit
(@mountainhermit)
Those occupation times for the RTN are not adequate for a defensible boundary position if there should be a dispute that goes to court. Just sayin'
As for you canopy guys, a word or three of caution. Just because the manufacturer gurus say that you can correctly position under canopy doesn't mean that you can. They have their algorithms and the comparisons available with the various GNSS signals are much better now, but signals bounce and are interfered with by canopy. It's physics. Might want to consider doing a little side measurement with a Disto or offset just to make your stuff defensible as well.
This post was modified 1 month ago by MountainHermit
Posted : August 15, 2026 9:19 pm
Learner
(@learner)
The only way occupation time plays into it for me is this:  I occupy for as long as, or as many time as it takes to get repeatable results.  What I posted above is about that.  Repeatable results.  If I don't get the same answer twice within the legal standards, I redo it or change data collection method and redo it.  Keep collecting data until I'm sure it's right.  And I'm not using RTN.  Always been a Base/Rover guy....
See also what C posted here:
https://rpls.com/forums/postid/594724/
This post was modified 1 month ago by Learner
Posted : August 17, 2026 6:08 am
Norman_Oklahoma
Tight groupings don't necessarily equal good coordinates.
Posted : August 18, 2026 10:13 am
2
GaryG
(@gary_g)
Posted : August 18, 2026 11:58 am
2
