Need help figuring out plat map (bearings??)
26 Users
17.5 K Views
foduddy
(@foduddy)
I really hope you guys can help me here. I purchased this property a year ago and with my neighbors actions recently I need to find and verify the rear corners and west and east boundaries.
In the picture I have included, my lot is in yellow. How do I get bearings from those numbers (N 63 07 30 E note: my keyboard does not have a degrees character to put in)could you explain what these are and how to use a compass to get the angle. The red mark is the only pin I can find. I know approximately where the south east corner is for there used to be a stake with a pink flag but my neighbors contractor broke it down when building his shed...
Please help I would greatly appreciate it.
Thanks
Fo
Posted : September 4, 2013 3:12 am
2xcntr
(@2xcntr)
As a licensed surveyor, my best advice to you is to hire a local competent surveyor to set your boundary markers. This is not a do it yourself job.
Calling a few real estate people should get you some leads. Check around and don't just go for the low cost estimate (bid).
You may also need the services of an attorney experienced in boundary law. (Good luck on that one)
Good luck.
I am sure I will enjoy all the other replies this post elicits.
If you need it again sometime try holding down the alt key while you type 248 to get a degree symbol (°). Glad I could help you on something.
Posted : September 4, 2013 4:15 am
Hmmh? Betweel Lots 16 & 18 The Should Be A Lot 17 ?
I wonder what that teeny parcel actually is?
Posted : September 4, 2013 5:23 am
Help with a compass
Fo,
Hopefully you're in possession of a compass that can lay flat and level.
First lay your compass on something flat, like your yellow pages phone book.
Next, carefully pick the compass up and place it next to the phone book.
Open the phone book up to the business section for Surveyors, Land.
Find someone in your vicinity and give them a call.;-)
We're all fairly friendly and can offer a least a brief rundown of our process and you could discuss your exact needs.
Posted : September 4, 2013 5:29 am
the teeny parcel..
is a public reserve for the oversized "Reduce Speed" and "Sharp Turn Ahead" signs.
Posted : September 4, 2013 5:31 am
ashton
(@ashton)
In my area, you can call the bar association legal referral service and for at most $25 you can get a 1/2 hour initial conversation. Perhaps your area has a similar arrangement. You might do that and as about your neighbor's actions, as well as whether your neighbor owes you for a survey to replace the boundary marker. Or was it a boundary marker? The pink flag certainly didn't survive from 1959.
As for the bearings, the first letter is where you start from, north or south. Then comes the degrees and minutes of the angle. Then comes the direction towards which the angle is turned, East or West. So N 34° 50' W means start at north, and turn 34° towards the west, then turn another (50/60)° toward the west. For compass purposes, just round the minutes to the nearest degree, so in this case, round to N 35° W. Then convert to an azimuth, which is how a good compass will be marked. If you start at 360° which is north, and turn toward the west, you will see the azimuth is getting smaller, so you need to subtract the 35 from the 360 and get an azimuth of 325°.
Then comes the fun of trying to lay this out on the ground. It's very likely that any survey done in 1959 uses magnetic north, which helps, but you'll be hard pressed to get better than +/- 2° agreement between your compass and the original surveyor's measurement. That works out to +/- 3 feet at the end of a 100 foot course. That's not really much of an improvement over just following the sideline of the road, which hasn't worked for you. So knowing what the bearings mean is unlikely to resolve your question.
Posted : September 4, 2013 6:02 am
The numbers are quadrant bearings. Using a compass in a residential neighborhood is not reliable due to local attraction.
The stake may have been next to the actual marker so it could still be there.
Note: the stake may have been at the northeast corner of Lot 18 which is about 1.5' east of your southeast corner.
Posted : September 4, 2013 6:26 am
cptdent
(@cptdent)
Is it just me, or does anyone else suspect we are seeing the return of "HardAssets"? 😀
If not, Foduddy, if you do not understand what those confusing glyphs on the plat are about, the LAST thing you need to do is to try and replicate then on the ground. Call a surveyor and then you can be SURE if you have a problem or not.
Posted : September 4, 2013 6:39 am
carl-b-correll
(@carl-b-correll)
The numbers are there, but you really, REALLY, REALLY NEED to hire a local, licensed surveyor with knowledge of this subdivision. Things need to be taken into account like the width and status of the right-of-way, the typical monumentation situation, the change in Magnetic North in your part of the world since 1959, and allllllllllllll sorts of things that we from outside of Lake County, Ohio wouldn't know from out here in internet land.
Anyway, being the numbers dork that I am, I got this for the lot:
PntNo Bearing Distance
PP
S 63°07'30" W 324.080
PP
N 34°50'00" W 80.720
PP
N 32°45'00" E 123.500
PP
N 45°13'00" E 173.850
PP
S 44°47'00" E 205.830
PP
Closure Error Distance> 0.0132
Error Bearing> N 78°37'27" W
Closure Precision> 1 in 68626.34
Total Distance Inversed> 907.980
Area: 45572 S.F., 1.046 Acres
DISCLAIMER: I WAS ONLY CHECKING MATHEMATICAL NUMBERS FROM A PERSONAL CURIOSITY, AND THIS DOES NOT IN ANY WAY REPRESENT ME ATTEMPTING TO SURVEY IN THE STATE OF OHIO
Carl
Posted : September 4, 2013 6:58 am
2xcntr
(@2xcntr)
Well, I replied first, early this AM and after a cup or two of good old Folgers... it occurred to me that I might have tossed a scrap to a troll. Who knows?
Posted : September 4, 2013 7:03 am
Target Locked
(@target-locked)
Why would there be a stake along your south lot line? Who set it? Is it on the property line or was it set to tie up a goat (ie "goat stake")? The flag you saw at the southeast corner, how do you know it isn't the northwest corner of Lot 19? Even IF you found "pins" at all the corners, how do you know someone didn't move it 5 feet, 10 feet? Even if you found ALL the corners in the RIGHT position, will your neighbor agree they are correct?
Hire a surveyor.
Posted : September 4, 2013 7:05 am
I wondered also..
But all I'm doing right now is August Billing...
trolls need love, too...:love:
Posted : September 4, 2013 7:21 am
dmyhill
(@dmyhill)
IT IS A GOAT STAKE!!!
> Hire a surveyor.
Oh SWEET! We can start up the "goat stake" argument again!!!
(I apologize to the OP.)
Posted : September 4, 2013 7:37 am
Andy Nold
(@andy-nold)
Welcome to the forum, Patrick. It looks like there are a lot of land surveyors in the vicinity of 7286 Raccoon Hill Drive. If you can't find the answer to your question here, I would try CT Consultants in Mentor, Garrett & Associates in Cleveland or maybe Schade Surveying Co., just about 3.5 miles up the road.
Lake County GIS
Posted : September 4, 2013 8:03 am
N 67º 7' 30" W would be "North 67 degrees, 7 minutes, 30 seconds West. There are 60 minutes in a degree, and 60 seconds in a minute. I would not worry about the seconds with my compass, and you might get to the nearest 30 minutes or even 15 minutes if you hold it real steady; but you do have to account for the magnetic pull of the needle. Magnetic north is not the same as north-north. The magnetic pull can be over 10 degrees depending on where you are.
Your best friends are the shovel and a metal detector when looking for corners.
To get the degrees symbol, while holding down the "alt" key, type 0176 then let up on the alt key. A slightly different symbol is [ALT]+0186. : °(= the 0176 code), º (= the 0186 code)
I would try to figure out where the corners are first, and if it looks like trouble, get a surveyor to find or replace them. A bickering argument where no one has had a survey only means trouble. If you can talk to your neighbor, ask them if they would go in halves with you on getting your common line staked. A survey may run $1,000 or more, so it's not cheap. I wouldn't go to a lawyer unless and until you have exhausted reasonable means. Know where the corners are and how much it's worth to you to fight it.
Posted : September 4, 2013 8:08 am
The Pseudo Ranger
(@the-pseudo-ranger)
Thanks Tom and Dave for giving the guy a straight answer. I've always thought that the reason we set corners is so the land owners can find them and know where they boundary lines are. I personally have no problem with a land owner using a shovel, tape and compass to attempt to locate his monuments.
I think Tom gave the best advice. Forget the compass. Get a tape and rent a survey grade metal detector and find a few corners, then measure from those corners to find the rest. Keep in mind that if you break a utility while digging you will probably have to pay to have it repaired.
A surveyor may be necessary if you can't find the critical monuments (they may be missing or buried too deep to easily locate), or your neighbor may dispute the markers you find, at which point a certified boundary survey will be good evidence on your side. Keep in mind that anything you find may just be a random piece of junk metal that was stuck in the ground for unknown reasons. A surveyor is an expert at distinguishing the junk from the property corners. Please, don't set your own monuments, if you can't find a monument, call a surveyor to reset it.
Posted : September 4, 2013 8:27 am
Fo,
All sound advice on the part of previous commentors. Please do yourself and your neighbors a favor and hire a surveyor if your unable to locate enough of your corners on your own with a compass, tape and metal detector. I've seen too many do-it-yourselfers build a garage or addition onto their neighbor's property because they didn't want to spend the money on a surveyor and then have to spend big money to move it or tear it down, all because they found a pin they thought was their corner, and turned out, it wasn't.
Good luck!
Posted : September 4, 2013 9:59 am
spledeus
(@spledeus)
Compass
Do you have experience with a compass? Did you know that North moves over time?
If this plat was created on a magnetic north, it is unlikely to be the same magnetic north you can measure today. You can go through the effort of calculating the difference only to find that the actual compass readings from 30 odd years ago don't transfer perfectly to your current north.
As far as the North and the East, take the advice of my friend the Cat in the Hat:
Never Eat Soggy Wheat.
North to East the bearing between. Add the NE bearing to 0 and you have the azimuth from north, but which north?
Good luck as I don't even use a compass anymore, well except for the cool app on the cell phone...
Posted : September 4, 2013 11:37 am
RPlumb314
(@rplumb314)
Fo, you've already gotten a lot of good advice here.
I can only add that in some areas, the building inspectors require a survey and drawing of the lot before they'll issue a permit to build a house. And sometimes, though not always, they will keep those surveys on file. You could check with your local building department and see if they have one for your property.
If you do find such a survey, it will probably show your house and some dimensions from the house to the property lines. This will be the proposed or planned location of the house. The house will not necessarily have been built in that exact spot, and it may have been changed or added onto. And that survey, if it exists, will not necessarily enable you to find all your corners, or convince your neighbor. Only a new survey will do that.
Posted : September 4, 2013 12:14 pm
jud
 jud
(@jud)
Compass
Doubt that this Subdivision Plat was done using magnetic North. Probably a Bearing was obtained using Solar Observation. 1959 may sound ancient to some but not so far back that Polaris and Solar Observations were beyond the ability of those Surveyors of the day. Heck, I went into the Navy in 1959 and the Navy was even building ships with steel and driving them with steam.
jud
Posted : September 4, 2013 12:29 pm
Page 1 / 3
