Chiggers, Ticks and Nate
12 Users
PS, I have many new tick and chigger bites, from a long day in the field yesterday!! May God fry those buggers! 🙂
Have a great day.- (Nate)
[USER=291]@Nate The Surveyor[/USER]
Didn't want to add to the lengthy thread this was posted in..
so what are you trying to prevent this..
It must be extremely bad there in AR this year because in a normal year it is very bad. I know that you arr an experience woodsman too.
In the summer of 1985 when I surveyed in the Ozark National Forest and other Ozark sites vagarious precautions were tried.
The most successful was wearing a long hiking sock and tucking the Levi pants legs into the socks and then wrapping the sock with masking tape around the calf in addition to spraying deep wood off on the Redwings and socks.. If you got into seed ticks, then you could unwrap some of the tape and use the tape to remove them. One of the problems was the waist port of entry. Hiking up and down hollows with a tripod on your shoulder made it difficult to keep a shirt tucked . The crew every day (remember rural AR 1985 ) after boxing it up would go find some cold Strohs at a local store and then head to a remote swimming hole or Beaver Lake. Every would strip down and delouse and take a cool dip like a bunch of primates. No, we did not delouse each other.. Hog Scald Holler was the local skinny dip area in a cove of Beaver Lake. Go delouse and go for a mile swim. Best physical condition that I was ever in .
Chiiggers were always a step ahead of you. I didn't believe in the clorox or Pine Sol bath approach. I used the chigger-rid and nail polish treatment and then found that applying a little dab of Tiger Balm helped. Kept one of those little tins of Tiger Balm in my pocket. i'm sure that the clorox or Pine Sol worked because it was recommended by a few old moms of friends.
Once a friend from Louisiana came to the Ozarks and camped out with his dog. Somehow he got infested with chiggers and came to my house for advice. He showed up with an unbelievable amount of chigger bites. I told him that he needed the clorox bath treatment but I had just removed the bath tub during a bathroom remodeling and in true Ozark style, it was outside in the yard. I saw the expression in his face slowly tun to despair. I drove him to another friend's hose for the bath. H" Hi, thsu is my friend A from LA, we need your tub to de-chiggger him"
I know thta you hahave gad soem bad health issues with ticks, Take care of yourselves and others too.
The big think =g here is the skeeters now because of Zika. Neighbor brought over soem homemade natural ingredient repellent in a large spray bottle. You spray n the grass around the porches and entry doors. It seem to work!
Posted : July 20, 2016 8:22 am
jaro
 jaro
(@jaro)
An old sock with powdered sulfur inside makes a good duster for dusting the bottom of your pants leg and top of the boot. Works really well with chiggers, maybe ticks also.
James
Posted : July 20, 2016 9:38 am
JaRo, post: 381790, member: 292 wrote: An old sock with powdered sulfur inside makes a good duster for dusting the bottom of your pants leg and top of the boot. Works really well with chiggers, maybe ticks also.
James
Yes, after I posted I wanted to mention that a sock of sulphur was kept in the truck by the owner and used by some.
I had to juggle a few things here and I knew someone would post about sulphur dusting.
Posted : July 20, 2016 10:23 am
I recently got only my second ever infestation of chiggers. Behind the knees. First time was about 11 years ago. It has been about a month, and I still am itching.
At first I thought it was a reaction to some black fly bites I got in northern Ontario (horrible swarms), but then I realized that it was chiggers, by then it had been a few days. Difficult to see behind the knees, had to use a mirror to confirm.
Ticks? I can see them and remove them, not a big deal. But chiggers....horrible little creatures.
Posted : July 20, 2016 11:39 am
Bushwhacker
(@bushwhacker)
The most effective Chigger prevention I have found was something I discovered by accident. My girlfriend at the time and I went swimming, the bank was covered in bermuda grass, she coated down with cocoa butter to work on her tan I did not use any. I was covered in chigger bites and she had none, this got me to thinking of the Indians using bear grease to keep the bugs off. To this day I use Palmers Cocoa Butter everyday, just coat down from the knees down before you put your pants and socks on in the morning. It stays on better than any other oil or vasoline for me.
Posted : July 20, 2016 2:39 pm
If I recall correctly, someone told me years ago that Avon skin-so-soft worked as well
Posted : July 20, 2016 2:51 pm
mike-marks
(@mike-marks)
My list, in order of hassle:
  • Chiggers, almost impossible to prevent them and when severely bitten it's a week or two of weeping, itching hell.
  • Mosquitoes, when rampant it gets hard to breathe, handle optical instruments and keep your sanity. Easily solved with DEET liberally applied often, including the balding dome of my head. Bites are itchy but go away fairly quickly. Most mosquito bites are harmless in the US concerning disease.
  • White socks, a peculiar fly in Alaska that injects an anesthetic and an anti-coagulant which results in a wound that abscesses and takes weeks to heal. Massive preventative DEET works, sort of. There's similar flies elsewhere.
  • Ticks, major danger from disease, unavoidable in spring, but full on DEET doesn't deter them much. They're kinda slow to do damage so a stripdown inspection every night during shower (with help from a friend) you can pull them off. Also protective clothing is a must.
  • Gnats, which if small can penetrate your tent and seek out hairlines, eyes and other delicate parts. But their bite is not so bad, more of an annoyance as they fly around your face. DEET works so-so.
  • Stinging insects, I carry two EpiPens because I'm susceptible because the doc said one is not enough in a major anaphylactic shock episode. After my first hospital visit (1975) they dealt with it but sent me to a training seminar where I learned how to avoid encounters (back away and then run to water if possible), stay alert, do not enter their alert zone. No swatting or defensive maneuvers. Been 40 years since I've been stung and they claim the anaphylactic response weakens with time, but if caught 150 stings will surely kill me.
Posted : July 20, 2016 3:47 pm
cordgrass
(@cordgrass)
put clear finger nail polish cover the chiggers bites they will be gone the next day. They are bad here in louisiana
Posted : July 20, 2016 5:13 pm
The most effective chigger control is to never leave your house from late June through September.
Posted : July 20, 2016 5:46 pm
chiggers, ticks, mites, skitos
Permethrin does it all. Treat your clothes; not your skin.
https://www.amazon.com/dp/B001ANQVZE/ref=sxr_pa_click_within_right_1?pf_rd_t=301&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=2329824862&pf_rd_i=permethrin&pf_rd_r=1257AGJDYSEMETZZN1WV&pf_rd_s=desktop-rhs-carousels&psc=1
Posted : July 20, 2016 6:20 pm
I have tried many things. It wears off. And then, here come the bugs. Its like i had a sign on me somewhere, that said "bite me". Cause the bugs do just that.
Btw, "bite me" is not a part of my language!
Posted : July 20, 2016 8:27 pm
Every once and a while, maybe once a week; a fly gets into the house and i complain: "The only fly in Washington and it finds it's way into our house"!
In Nebraska, from May to November, every time the screen door opens, 50 flies come in. With 3 kids, do you know how many times a day the screen door opens?
Don't tell anybody; but the best thing to do is move to where there aren't any bugs. I used to wake up in the middle of the night scratching my chigger bites; I haven't had a chigger bite since 1990; I haven't missed it one bit...:grinning:
Posted : July 20, 2016 10:31 pm
Whatever used could be mostly diluted and sweated away early in the day and intensify the effects of the sun 10 fold for the next two months.
:sun:
Posted : July 20, 2016 10:52 pm
david-livingstone
(@david-livingstone)
My understanding is that once you start to itch from a chigger, it is already gone, so the nail polish over the bite may help it feel better, but it doesn't kill the little buggers like you would think. Deet always seemed to keep the chiggers off of me. For me chigger bites are worse than poison ivy but they don't itch for as long a period of time.
Posted : July 21, 2016 10:08 am
