slider prisms
Dan Patterson
(@dan-patterson)
Has anyone on here ever used those little prisms that slide up and down the pin pole? I just got done a job where I had to climb all kinds of formwork and put wall line and column line marks everywhere. I work as a 1-man crew, so it was all done robotically.
It was a real pain doing it with the rod. I used a mini rod that's about 0.4' tall, but that was too short in places where the formwork covered line of site. I see they make 360å¡ sliders as well for robotic surveying. (I guess they're at either 0mm or some positive offset, so I'd have to be careful to change that).
Posted : July 20, 2016 1:37 pm
squowse
(@squowse)
Dan Patterson, post: 381812, member: 1179 wrote: Has anyone on here ever used those little prisms that slide up and down the pin pole? I just got done a job where I had to climb all kinds of formwork and put wall line and column line marks everywhere. I work as a 1-man crew, so it was all done robotically.
Yes I use to use them all the time. Sighting in between rebar was a particular requirement.
Never seen a 360 slider. Or maybe I have but the type with many separate prisms topcon or trimble style.
Posted : July 20, 2016 2:20 pm
We use a two prism rod for inaccessible locations. Works great. The DC stores the data (angles and distance) as if it was observed to the tip of the rod.
Posted : July 20, 2016 2:48 pm
I have a mini pole with three sections that has the sliding prism.
It is very good when a slim, skinny, 3/8" width pole is needed for close stakeout.
Do not use it very much because it can only be used at 0mm prism offset.
All my other targets are setup -30mm prism offset.
Mostly use the pole only for stakeout in prismless mode.
:gammon:
Posted : July 20, 2016 3:37 pm
Dan Patterson
(@dan-patterson)
:gammon:
I don't think I have ever used the pole to measure the distance in prismless mode. Do you account for half the thickness of the rod? Is it negligible?
Posted : July 20, 2016 4:46 pm
I take many shots in the SDA mode and then give a go or come amount to be in the center of the object, be it post, xtie, prism pole, rebar, power pole, etc. The method also allows for a right or left offset amount.
Wrap with prismatic reflective tape will increase the measuring range considerably and any setting will work, prism, target or prismless. That allows you to make a constant setting in your gun.
The sliding pole I have is 0.03ft thick and has three 2ft sections with a ring on top.
Taller and thicker and easier to shoot than a chaining pin.
Wish I had extra points for the other two sections. It is possible to adapt a plumb bob point up a size or two (gonna work on that fix).
The point are similar to that of a target arrow and would be better suited in being a plumb bob point.
I take my shot and when the DC says go 0.015 I know it is spot on.
:gammon:
Posted : July 20, 2016 5:56 pm
sireath
(@sireath)
I use Sokkia Robots and they have a sliding prism pole which I use for setting out. Looks like the link below. Very useful to shoot between rebars and things that block.
http://www.positionpartners.com.au/product-categories/accessories/survey-accessories/prisms/360-prisms/atp1s-360-sliding-prism.htm
Posted : July 20, 2016 7:28 pm
Dan Patterson
(@dan-patterson)
sireath, post: 381863, member: 9370 wrote: I use Sokkia Robots and they have a sliding prism pole which I use for setting out. Looks like the link below. Very useful to shoot between rebars and things that block.
Looks pretty cool, but that says -7mm offset. I don't understand how it can have a negative offset and be a slider. Wouldn't the node be inside/behind the pin pole if that were the case? Am I misinterpreting what the offset represents?
Posted : July 20, 2016 8:02 pm
stephen-ward
(@stephen-ward)
Dan Patterson, post: 381870, member: 1179 wrote: Looks pretty cool, but that says -7mm offset. I don't understand how it can have a negative offset and be a slider. Wouldn't the node be inside/behind the pin pole if that were the case? Am I misinterpreting what the offset represents?
It's all about the optical center not the physical center of the prism.
Posted : July 20, 2016 8:40 pm
