Bent iron pipe
9 Users
20 Reactions
not-my-real-name
(@not-my-real-name)
This once tall iron pipe was so bent both ends were in the ground. Afer careful excavation I could determine where the bottom was. With no bulldozer in sight, one can only wonder how this pipe got so mangled in the forest.
Posted : June 10, 2025 3:57 pm
2
jimcox
(@jimcox)
tree fell on it?
Posted : June 10, 2025 4:09 pm
Around here if they're sticking up too much ATVs and snowmachines in low snow years can clobber them. Skidding logs is hard on them as well.
Posted : June 10, 2025 5:53 pm
not-my-real-name
(@not-my-real-name)
@jimcox yes, that could explain it.
Posted : June 10, 2025 6:57 pm
not-my-real-name
(@not-my-real-name)
@williwaw thank you.
Posted : June 10, 2025 6:58 pm
not-my-real-name
(@not-my-real-name)
I'm thinking I should set something there as close to the position as possible while leaving the bent pipe as evidence of finding the original corner.
Posted : June 10, 2025 7:07 pm
GaryG
(@gary_g)
Ya need a pipe straightener! Always had a 4ft section of steel pipe to straighten up bent rebar. The pipe might break off at the crease though. Sounds like a rebar and cap set at the base of a "x" size bent iron pipe. That is if it is the actual corner. 😃
Posted : June 10, 2025 7:13 pm
1
not-my-real-name
(@not-my-real-name)
@gary_g  Yeah. Might need a little heat on that crease. A flamethower would work, but I don't want to start a forest fire.
Posted : June 10, 2025 7:46 pm
not-my-real-name
(@not-my-real-name)
...but seriously, the only bars I am able to bend are those half-inch ones. I also thought about cutting the pipe at the crease and resetting it. I am concerned the somebody will take it to be just a piece of junk and rip it out.
Posted : June 11, 2025 4:05 am
That pipe looks amazingly similar to many of the 1/4 GLO brass caps I see, they used pipe sticking out often 12-18" and many get bent just like that one. If they can be rehabilitated I do that, however, that one looks iffy. Set your cap, bury the pipe alongside. I don't think it's always machines that bend them, livestock can wear out almost anything sticking out of the ground.
Posted : June 11, 2025 6:44 am
2
Norman_Oklahoma
Posted by: @not-my-real-name
Go to the hardware store and get a new length of pipe. Set it and put your cap in it.
Posted : June 11, 2025 8:58 am
3
I always make it a point to try and rehab these things because if I don't, who will? Sometimes it's just driving a 32" 5/8" down the side of it well below grade and putting my cap on it. Straightening a 5/8" rebar is easy with a section of plumbing pipe, but straightening iron pipe like that, too much a PIA.
Posted : June 11, 2025 10:30 am
1
Norman_Oklahoma
This is an example of the perfect being the enemy of the good. In Oklahoma, a non-recording state, you could rehabilitate a found marker and move on. Unless it is a PLSS corner, in which case a CCR and $5 recording fee. If you find a damaged marker in Oregon and rehabilitate it you are on the hook to file a record of survey. Between your time and filing fees that will add around $2000 to the survey cost - minimum. In Washington State the mere fact of finding such a marker in the course of a survey - technically - puts you on that hook.
Posted : June 11, 2025 2:13 pm
3
not-my-real-name
(@not-my-real-name)
Finished!
Posted : June 12, 2025 12:42 pm
2
I've found you get good results by swinging a pipe or bar onto the hammer head. It focuses energy in just the right spot, though it can transfer a significant portion up your arm to the elbow.
This pipe appears a bit too 'pinched' to recover. I'd bury it alongside my new monument to avoid leaving two options. Tell the story in my narrative on my recorded map...
Posted : June 12, 2025 1:07 pm
1
GaryG
(@gary_g)
Awesome!
Posted : June 12, 2025 3:09 pm
1
 🤣 🤣 🤣 Search the area.  You may find a croquet field laid out with such "wickets".
Posted : June 16, 2025 1:34 pm
2
john-putnam
(@john-putnam)
@holy-cow
Sound like our back yard, we used to play extreme croquet.  #1 rule, no blood, no foul.
Posted : June 16, 2025 1:59 pm
2
