I have no problem with inserting a signature into a PDF but when it comes to inserting one into a DWG I am having some issues that I cannot seem to resolve and it concerns the frame, edge or border of the image I am inserting. That edge is black and my signature is within this frame and I cannot figure out a way to remove it without removing my signature. Any ideas?
On a different note maybe this will motivate me to getting my PDF issues resolved.
Display Order?
Turn image Frame to "Off".
Gene Kooper, post: 453729, member: 9850 wrote: Turn image Frame to "Off".
Been looking for it and by golly I cannot find it. Using Carlson Intellicad.
Got it, You're the greatest. Thanks
Edit: The Image Frame kinda works a little. It turns off 2 of the frames but the other 2 are still there. Quite annoying.
Steve,
I use Autodesk Map and it is in the "Modify" menu. Select "Object" then "Image" and click on "Frame".
Otherwise, check the help file for image frame.
'Tframes'
thebionicman, post: 453745, member: 8136 wrote: 'Tframes'
Never heard of "TFRAMES". What's it do?
Just A. Surveyor, post: 453749, member: 12855 wrote: Never heard of "TFRAMES". What's it do?
As I recall it rurns certain frames on and off.
Insert a pdf of your signature. Blow it up big. Using the SKETCH command trace it with your mouse. Delete the image of your signature and you are left with a polyline signature. Scale it, save the drawing. Presto - you've got a dwg of your signature. Insert it as a block to any drawing. And since you created it by the movements of your own hand, it could be argued that it is, in fact, an actual original signature.
Pdfframe
I have my signature as a true type font, you could try converting the image to png format. I have better results with png files.
You can also change the linetype of the frame to ??dot? then change the ltscale of the frame to a high number like 100.
Most states now have digital signature requirements. A signed pdf in the manner you describe is not a digital signature and in most cases is probably not legal.
You guys are like Wiley Coyote.......Super Genius.
Thanks.
And I'm gonna look at the signature fonts. I like that idea a lot.
I know Georgia allows digital signatures but I don't know if that is just a copy of my signature or if in can use a signature font.
I will have to look into Alabama also.
??Digital? signatures in Fl., and probably GA., have to be accompanied with a digital certificate. There are numerous purveyors of digital certificates I prefer Identrust.
https://www.identrust.com/
I scanned my signature and inserted it into CAD as an image file. I zoomed in close and used the polyline command to trace my signature with a mouse. I used the PEDIT command, FIT option, to smooth up the lines a bit. It is saved as a 1:1 .dwg file and can be inserted into a drawing as a block. I will not send out a .dwg file with my signature or seal attached as part of the drawing file or embedded as a block. I print out my survey plat with my CAD seal using Foxit as a virtual printer, and then use that software to attach my password protected signature. Foxit has many different and useful functions. I just like it. Works for me.
I do exactly what Harold and Mark Mayer do. Works great. Just remember never to send out a CAD file with the signature in it, and always PURGE the CAD file before it goes out.
My seal was taken from a cad file and used on a preliminary plat. The plat had multiple issues and could have bit me hard. I no longer allow cadd blocks of any of my seals.
