What are these called?
10 Users
eddycreek
(@eddycreek)
Pretty sure Ive seen these before but never used them. Have to set about 6500 ft of curb stakes in the middle of a limestone roadbed thats been run over for the last 5 years. Best option I can think of is magnails. I remember seeing some plastic tabs with a hole in the end for a nail that would stand up and you can write on the upright flat part. Anybody know what Im talking about and where to get them?
Posted : June 8, 2016 7:36 am
eddycreek, post: 376142, member: 501 wrote: Pretty sure Ive seen these before but never used them. Have to set about 6500 ft of curb stakes in the middle of a limestone roadbed thats been run over for the last 5 years. Best option I can think of is magnails. I remember seeing some plastic tabs with a hole in the end for a nail that would stand up and you can write on the upright flat part. Anybody know what Im talking about and where to get them?
Checked Berntsen or Surv-Kap?
Posted : June 8, 2016 8:32 am
andy-j
(@andy-j)
hey Randy! Someone just posted about "hammerless stakes" down below.. I know that's not what you are looking for but it seems like it might be the same genre of supplies.
Posted : June 8, 2016 8:39 am
mvanhank222
(@mvanhank222)
7" landscape spikes, Milwaukee m18 hammer drill with a 3/8" bit the hole will leave just enough room for a pin flag with a 4ah battery we get over 50 holes into asphalt.
Posted : June 8, 2016 8:42 am
Steve Emberson
(@steve-emberson)
Quick stakes? Put them behind the nails
http://www.quikstake.com/surveyor/surveyor.html
Posted : June 8, 2016 8:46 am
scott-ellis
(@scott-ellis)
Could you use railroad spikes?
Posted : June 8, 2016 8:53 am
va-ls-2867
(@va-ls-2867)
Quick Stakes
Stake whiskers or stake chasers....
http://www.locatorsandsupplies.com/prodcat/StakeChaserWiskers.asp
https://www.google.com/search?q=stake+chaser&oq=stahe+chaser&aqs=chrome..69i57.2501j0j7&sourceid=chrome&ie=UTF-8#q=stake+chaser
Usually in hard surfaces, I would just use 60d nails with flagging tied on
Posted : June 8, 2016 9:09 am
vern
 vern
(@vern)
Limestone is tough conditions. How about a Ramset and the flags normally used for utility marking?
Posted : June 8, 2016 10:12 am
Jon Collins
(@jon-collins)
If you need to powder hammer like a ramses or hilt try the aluminum tumber tags, they will allow a small amount of writing. For concrete paving on hard base course we use a 30d ring shank or other suitable nail and we buy rolls of lawn chair weaving stuff cut it and nail thru it. A marker writes well, on white of course
Posted : June 8, 2016 7:45 pm
Jon Collins
(@jon-collins)
Webbing. That's the damn word I was trying to think of
Posted : June 8, 2016 8:53 pm
summerprophet
(@summerprophet)
I have done similar projects.
A good supply of 2.5" magnails, 50d nails, railroad spikes and a gin pin or two will get the points in the ground.
For the lath, I have a narrow hunting hatchet that I use as a wedge with the sledgehammer to create grooves for the lath to stick in. On the points that I can't get a lath in, I just tie the lath flagging to the nail flagging.
Posted : June 8, 2016 9:12 pm
