Leading Zero
11 Users
not-my-real-name
(@not-my-real-name)
Supporter Debater
Which is correct?
1.)?ÿ ?ÿ S 04?ø 26ƒ?? 55ƒ? W
2.)?ÿ ?ÿ S 4?ø 26ƒ?? 55ƒ? W
Posted : June 18, 2023 10:16 am
Both are correct. I use 1), thinking being that I prefer not to have negative space in the writings. But 2) is perfectly valid.
Posted : June 18, 2023 10:59 am
mathteacher
(@mathteacher)
Some NGS applications require leading zeroes, even in degrees of longitude. For example, in the radial search option for data sheets, 80 degrees has to be entered as 080. Also true for NCATS. I've assumed that this is  because the software separates deg min sec by counting digits, but that's just a guess.
I use the leading zero as a placeholder to indicate that there's no missing digit that I failed to enter.
Posted : June 18, 2023 11:21 am
oldpacer
(@oldpacer)
Depends on rather you see youself on a world or on a continent
Posted : June 18, 2023 1:08 pm
jph
 jph
(@jph)
They both are correct.  (Now, just waiting for you to reveal the reason for the question)
Posted : June 19, 2023 5:30 am
Supporter
Neither are correct it should be S04°26’55”W.
I dislike the spaces between the direction and the degree and between the " notation and the direction on my plats. Since I dislike them on the plat I want the narrative to reflect the same.
Like JPH asked, who is complaining about the two choices (either are fine) and why are they complaining?
I'm looking at an Independent Resurvey plat by the BLM from 1925. They use S.4d27'W. no place holder or space.
Why do hand drafted plats look so good?
Posted : June 19, 2023 6:51 am
jph
 jph
(@jph)
I agree that some of the older hand-drafted plats look beautiful, real artwork there.  But some just look like crap, no planning or thought going into them at all.
Then again, some early CAD plans look very stark or bleak.  Probably done by someone like me, with no artistic understanding at all
Posted : June 19, 2023 7:20 am
I prefer leading zeros.
Posted : June 19, 2023 8:32 am
kevin-hines
(@kevin-hines)
Supporter
Its an individual preference item.  I prefer using the zero as a place holder.  I found that I don't mess-up as much when keying in deed description in an AutoCAD drawing if the place holder is there than if it is just a single digit degree.  It is just how I trained my brain to communicate with my fingers.
Posted : June 19, 2023 8:40 am
Supporter Debater
@kevin-hines
MY preference (and that is all it is) has a space after the letter for north and south and one before the letter for east or west.  Also, MY preference is 04 degrees.  Always looking for two digits for bearings helps to insure I didn't do a typo and left off the second digit.  If doing azimuths, I would use 004.  Again, to help avoid typos.
Posted : June 19, 2023 9:42 am
Norman_Oklahoma
Member Debater
Eliminating the space keeps the bearing from orphaning at the end/beginning of a line. Nevertheless, I prefer the look of the space. One outfit I worked for added periods in lieu of the spaces to make the space without an actual space character.
Posted : June 19, 2023 11:44 am
Member Debater
I still remember the day my dad finally got a job, and we could afford leading zeros.
Posted : June 19, 2023 12:31 pm
Supporter Debater
@james-fleming
Did he also buy you some marbles to replace the roundish pebbles you had painted to look like marbles and a real pocket knife to replace the sharp stick you had been using to play mumbly peg?  You probably had a roller skate key but no skates to use it on.
We were so poor, I had to play tag with my shadow.
Posted : June 19, 2023 12:39 pm
