Is it a Subdivision?
14 Users
not-my-real-name
(@not-my-real-name)
Supporter Debater
The client owns contiguous parcels of land being shown as 32 and 33 on a plan drawn in 1874 and were occupied by same owner for a long time. The house is on only one of the parcels, while a garage is on the other.
The client wishes to build a second house on the parcel with the garage. The city shows the house and garage as one parcel (32 and 33 merged) on the assessor database, but the deed describes the perimeter being 32 and 33 as shown on the plan. Since the lots are in common ownership they can be considered to be merged.
A subdivision is the result of new lines being created, however, the lines separating the parcels as they existed in 1874 were considered by whomever built the house and garage. If I draw a plan showing the line between the two parcels is it a subdivision?
Posted : October 7, 2023 3:55 am
Supporter Debater
This should be an interesting discussion, based on the policies in force in the various areas of the responder.
In my case, this would not be a subdivision. Simply calling out a specific number would be adequate. I could even show a new tract as being some portion or metes and bounds description that only involves one of the two numbers. That would not be considered a subdivision in my area.
Posted : October 7, 2023 4:49 am
Here in Oregon there is the time before the Subdivision Control Act of 1963, and the time after (technically, there is also the 10 year period the law gave the cities and counties to enact local ordinances). Before that land developers could do pretty much anything they wanted to do, after - not so much. There are lots of cases of subdivisions before that time were lots are mapped in a certain configuration, and then were sold and developed in some weird combination of lots and portions of lots excepting other portions, etc., etc.
In any case, once the tax assessor has melded these combinations into a single tax lot they are, for planning/permitting purposes, a single entity. In order to reestablish those internal boundaries -for planning/permitting purposes - you are going to have to replat.
Posted : October 7, 2023 5:58 am
GaryG
(@gary_g)
Supporter
How are they held in title? Two separately described parcel in the same deed. Or are they two distinct deeds?That could have a bearing on the outcome.
In either scenario, I would not why you could not sell one parcel with out any other work. Now it being buildable would depend on septic regulations, etc.
Posted : October 7, 2023 6:11 am
not-my-real-name
(@not-my-real-name)
Supporter Debater
The two parcels are described in the same deed. I need to draw a map of the proposed construction on the parcel with the garage. The owner wants to build a house there and there are zoning issues.
I happened to be looking at other property configurations in the neighborhood and right next door there is a similar situation, but the assessor database shows both parcel lines.
I will have to talk with the city as the merger is really up to them. There is no strict rule.
Posted : October 7, 2023 6:18 am
fairbanksls
(@fairbanksls)
My personal opinion is no. You are talking about 2 distinct and separate tracts of land. I’d like to know who gave tax mapping or the assessor the authority to combine them. I’d question them about where their authority came from.
Be the wolf, not the sheep.
Posted : October 7, 2023 6:57 am
not-my-real-name
(@not-my-real-name)
Supporter Debater
Exactly. At first I thought a new line was needed, but I changed my mind, especially after finding a monument on the line between the two. We do have the doctrine of merger, but that is not law.
Posted : October 7, 2023 8:08 am
fairbanksls
(@fairbanksls)
As long as both lots conform to current subdivision regulations I think they’re golden based on a cursory review of applicable legal cases.
Posted : October 7, 2023 9:58 am
aliquot
(@aliquot)
What a subdivision is changes depending on jurisdiction so the general answers aren't very helpful.
For example, in Alaska, once a subdivision plat is accepted (or if a presubdivision regulation plat was recorded) lines can't be changed anyway except by the formal vacation process. Others have already described jurisdictions that have a very different view on this.
Posted : October 7, 2023 10:29 am
aliquot
(@aliquot)
I hold the same personal opinion, but unfortunately our personal opinions aren't worth much on this issue, because local goverments and/or states may have different opinions as expressed in their statutes, ordinances or regulations.
Posted : October 7, 2023 10:33 am
not-my-real-name
(@not-my-real-name)
Supporter Debater
Thank you to all that joined the discussion.
The reason for my question was that the parcels appeared to have merged. However the subdivision map of 1874 shows two parcels and as described in the deed, those two parcels are 32 and 33.
The assessor database does not show a line dividing the two parcels, but their parcel numbering system (called the Mblu for some baffling reason) incorporates two numbers in the field for parcel.
It makes a difference in how I file the map, that is, to file as a subdivision and force a meeting with the Planning Board, or file both as existing boundaries and straight to the Registry of Deeds without meeting the Planning Board.
I choose the latter. I will be filing the survey as existing boundaries showing two separate parcels.
Posted : October 7, 2023 11:55 am
To reiterate what I said earlier - the academic question of whether these should still be seperate lots or not is of no consequence. What matters is if your local authority will regard it as separate and issue a building permit, or not. Right or wrong has nothing to do with it.
I suppose that if you, or your client, don't like their opinion you could lawyer up. Good luck with that.
Posted : October 7, 2023 1:10 pm
In CA most of this stuff has been adjudicated. The rules are complicated, but the law is mostly settled.
Posted : October 7, 2023 2:37 pm
BStrand
(@bstrand)
Member Debater
Sounds like the subdivision was done in the 1800s, so no, I think your map would simply be a retracement survey.
Posted : October 7, 2023 4:59 pm
Norm
 Norm
(@norm)
Short answer: It's a retracement of two existing parcels that may or may not require a new subdivision.
Longer answer: It may be wise for the owner to contact the planning board regardless if they ever intend to convey either of the parcels separately so that there is a clear understanding on both sides of what the expectations will be should that be the case. If your survey is for that possibility and the owner is under the assumption your survey will allow them to convey either parcel separately the local authority should also be on board. A written request for an opinion with a written answer would be best. I might go so far as attaching the answer to the survey. If the local authority would require a new subdivision of two existing parcels now would be the time to address it. Don't kick the can down the road. It's not your call and you're taking on unnecessary liability doing so. Surely this situation has been addressed before. If the survey is not for conveying parcels separately why is it needed ?
Posted : October 7, 2023 11:36 pm
murphy
(@murphy)
I would familiarize myself with the ins and outs of zoning, discuss it with your client and consider the ramifications of: 1) stopping the survey, 2) showing it as two distinct parcels, or 3) adjusting the interior boundary to meet the client's and the zoning authority's criteria.
Academically, the statute of frauds is powerful and well established (the exception may be Louisiana). The judiciary leans towards limiting the ability of land to be transferred outside the confines of a written instrument, specifically a deed.
If Zoning gets a big head about their view that the lots have been merged. The direct question to the town attorney would be along the lines of, "Given that there's is no deed expressing an intent to merge the two parcels, when and how did the parcels merge?" Town attorney's aren't typically the crème de la crème of jurisprudence, but hopefully they wouldn't suggest that Zoning has the ability to supersede the statute of frauds.
Good luck, this sounds like a great opportunity to show the public the professionalism of land surveyors.
Posted : October 8, 2023 12:50 am
"Given that there’s is no deed expressing an intent to merge the two
parcels, when and how did the parcels merge?” ....hopefully they
wouldn’t suggest that Zoning has the ability to supersede the statute of
frauds.
I'll wager that the lots were merged at the request of the property owner at some time in the distant past - possibly to reduce the property tax rate or avoid some levy somewhere along the way. Because you are right - tax assessors can't do these things on a whim.
Posted : October 8, 2023 5:57 am
fairbanksls
(@fairbanksls)
Should be simple enough to obtain a written record of the owners request to merger.
Posted : October 8, 2023 6:51 am
That would be ideal, but I doubt that there is much to be gained. If such a document can be produced, the property remains merged. If a document, possibly from as far back as 1874, cannot be produced - so what? Statute of Limitations. The property remains merged.
The OP's only hope is to show that this merger happened extra-legally in the relatively recent past.
Posted : October 8, 2023 1:28 pm
Supporter
That would be two separate buildable parcels here. The big problem will be is there room to meet zoning restriction for the new building. Anything built prior to existing building restrictions will be grandfathered and you would need a variance to build a new structure that violates present day zoning. Those are sometimes granted to allow the new building to "follow" existing neighborhood patterns.
Neither the assessor nor the GIS department have authority to merge parcels. Already subdivided lots stay that way until they get re-subdivided, unless buildings were built across the lines and then they are automatically merged. However, I'm working with a landowner today that destroyed 1/2 a block of buildings, now he could build on each lot if he wishes (he doesn't), so the parking structure that covers 1/4 of a block still won't merge those lots. We know this cause we have had many public meetings and discussions with the "powers that be" over all these issues.
Your area may be quite different, local rules will prevail.
I'm reminded of the local city council that gave the GIS map authority over zoning layout. That didn't turn out well for them, but the courts held to the vote of the council overriding the legal descriptions adopted by the council for zoning layout and held the GIS (quite different) layout.
Posted : October 9, 2023 12:41 am
