How does everyone handle late changes to ALTA surveys?
15 Users
david-baalman
(@david-baalman)
My standard ALTA proposal includes a note: "We are happy to provide a draft copy and address one set of comments. Any changes requested after finalizing the survey, including requests to add entities to the certification, will be considered extra to the contract and billed accordingly. Note: requests that are contrary to the professional judgement of the Professional Land Surveyor in responsible charge cannot be accommodated."
I have a request from a client on an ALTA to add another lender to the certification of a survey completed 10 months ago. They want me to just add the name and not change the date of the survey. I'm reluctant, it seems like it should be a new survey to me, but they act like it should be a nothing change, and should only cost them 1/2 hour of office time. How does everyone else handle this?
Posted : February 12, 2018 9:09 pm
Let them consider what it would cost to get someone else to satisfy this so-called requirement.
Posted : February 12, 2018 9:13 pm
mark-flora
(@mark-flora)
We've been doing quite a bit of ALTA's lately and this seems to be the norm. Although 10 months seem like a while to me. Most requested changes/edit's usually happen within a few weeks after completion of the final draft.
Posted : February 13, 2018 6:29 am
jph
 jph
(@jph)
Is the lawyer and anyone else involved doing this minor change for free?
I have no idea, and we accept this as true, but has anyone ever confirmed that just adding another lender, even if you back-date it, doesn't extend liability to the current date, along with any changes to the site or title made since that date?
Posted : February 13, 2018 6:38 am
lmbrls
(@lmbrls)
Any revision must have a revision date. You should not make a misrepresentation for their convenice.?ÿ Do they mean 1/2 hour of office time plus $100 per sheet? No problem with that.
Posted : February 13, 2018 6:42 am
tommy-young
(@tommy-young)
It depends on how good of a client this is.
Posted : February 13, 2018 7:21 am
cameron-watson-pls
(@cameron-watson-pls)
Table A item 1 has been deemed a necessary requirement regardless of what?ÿthe Client wants by our Board in CO.?ÿ When requests like this come in I explain any "update" or "re-certification" requires at a minimum a site visit to confirm all the corner monuments are still in place.?ÿ?ÿI won't back date a survey so the fee for this and the extension of my liability is normally 20%-30% of the original contract value, more if we find corners need replaced.?ÿ
Posted : February 13, 2018 8:35 am
jered-mcgrath-pls
(@jered-mcgrath-pls)
Any time I need to make changes beyond a final delivered product it is going to cost my time.?ÿ
Portion From ALTA FAQ?ÿ?ÿ https://www.alta.org/news/news.cfm?20160216-FAQs-for-the-New-2016-ALTANSPS-Land-Title-Survey-Standards
As an aside, notwithstanding the innocuous-sounding word ƒ??update,ƒ? an update is actually a new survey.?ÿ The only difference is that the surveyor happens to have surveyed the property previously, so the client may see a reduced fee or timeframe depending on a number of factors (e.g., how long has it been since the initial survey??ÿ And how many changes have affected the property since?).?ÿ
And honestly the Lawyers know it is illegal and borderline fraud to backdate with an attempt to portray contractual agreements were in place and entities were bound by said documents from a prior date. Backdating in the case of contractually recording a past oral agreement may be allowed if an oral agreement was used to legally bind entities in a legal contract at the time of the backdate. Since property can't generally change hands from an oral agreement though the use of backdating for property is typically a no-no.
Posted : February 13, 2018 10:05 am
said-lot
(@said-lot)
I do them and then complain about it to coworkers.?ÿ?ÿ
Posted : February 13, 2018 10:28 am
rick-taylor
(@rick-taylor)
Absolutely not going to do it. A lot can change on any given site in 10 months, so that's a new survey, and with an extension of certification to another party it's added liability. My question to the client is "do you tell your doctor, attorney, accountant, mechanic, plumber, etc. what should be done and how much it should cost?" Inform them as to what you have to do and the fee, and get your money up front.
Posted : February 13, 2018 10:53 am
david-baalman
(@david-baalman)
Thanks everyone!
A bit more info came out today: they have a new title commitment showing 1 new encumbrance and also citing my survey from 10 months ago. Fairly easy to convince them now that this is a new survey and won't be free.?ÿ
Posted : February 13, 2018 8:38 pm
Texas is not a recording state, recording is purely a client's decision.
Most clients do not record drawings because it costs more.
In recent times I've seen Title companies refer to prior survey drawings and other survey work they have copies of in their Title Commitments and that has not been recorded or appears in any deed description that has been recorded.
I've also seen that appearing in other Surveyor's work as well, sometimes refering to information from their own work and/or from other surveyor's work, also, none of it ever found in public records.
What good is a reference that can not be fact checked?
When something is not of record, does it legally exist?
I really do not believe that the pocket deed theory includes pocket surveys.
IMO, Public notice has not been exerted, given, placed or put in the timeline.
0.02
Posted : February 14, 2018 9:29 am
@a-harris you said "Texas is not a recording state, recording is purely a client's decision." can a Surveyor record his work or is that not permitted?
Posted : February 14, 2018 9:47 am
jph
 jph
(@jph)
"I've also seen that appearing in other Surveyor's work as well, sometimes refering to information from their own work and/or from other surveyor's work, also, none of it ever found in public records."
I totally agree there.?ÿ I recently came across this note on a plan:
"The boundary information shown is based entirely on the reference plan noted."
The reference plan is an unrecorded ALTA plan done by this same surveyor.
Posted : February 14, 2018 9:55 am
Anyone can record most anything at their own expense.
I have found that most clients do not want their surveys to be in the public records.
Most are of the opinion that they have made a big investment in having their land surveyed and if their neighbor wants to know about their common boundary, they can pay for their own survey.
Posted : February 14, 2018 10:04 am
Posted by: A Harris
Interesting mindset. I see the opposite out here, most seem to be wanting to assert their claim to ownership an any way possible... but we treat occupation as a very high position in the order of priorities, even absent a clear chain of title.
True, cost is always a concern, even if it is only $1.79.
I assume the cost of recording is less that the cost of the actual survey.
Posted : February 14, 2018 10:44 am
daniel-ralph
(@daniel-ralph)
It appears to me that the op had sufficient language in their agreement to trigger an additional fee. What that would be should be negotiated. I wouldn't be bullied into doing anything professionally that I wouldn't do personally. The OP holds the trump card in this case; me thinks.?ÿ
I am blessed to be in a recording state. That doesn't mean everything gets recorded or is filed and is limited by those products created after 1973. My clients do not get a choice to record or not. If they want to control my product, I am not the man for them. Unfortunately, they will find someone that will comply with their excuses. The filing fee here is a significant $160 or so. This fee funds a state map repository that collects and acquires surveyor's records, recorded and unrecorded maps and other resources. They scan these documents and index them every way possible. This week they announced that the fee to access these records on-line has been eliminated!?ÿ?ÿ
Happy Valentines Day ??ÿ
Posted : February 14, 2018 11:15 am
david-baalman
(@david-baalman)
Op is in the same state, and is equally excited about no longer having to pay for research on the Public Land Survey Office website.
For the record the parcel in question is a vacant lot in a binding site plan I completed 2 weeks before the original ALTA survey. For those in other states, a binding site plan is Washington State speak for a subdivision survey of commercial property.
I love doing a second survey on my own work, it's a good opportunity to see how good my field crews match each other. Just have to make sure to have plenty of peer review on the final product.
Posted : February 14, 2018 9:12 pm
jamesf1
(@jamesf1)
"Most clients do not record drawings because it costs more."
I am licensed by my State to protect the public. The adjoiners are the 'public" envisioned by the licensing statutes. My client has no say regarding my fulfilling my duty to the public - I record everything, otherwise I have jeopardized my license.?ÿ
Posted : February 15, 2018 7:24 am
jph
 jph
(@jph)
Posted by: Jim in AZ
I think that you'd be opening yourself up to legal action if you practiced in a state where recording isn't mandatory.?ÿ You would need your client's permission, as recording would be revealing facts, data, and information, which they may decide they don't want revealed.
Posted : February 15, 2018 9:12 am
