Carlson BRx7
5 Users
3 Reactions
field-dog
(@field-dog)
Our Topcon HiPer SRs have been retired. Friday was my first day using the Carlson BRx7. No base station was used. I was locating property corners in a suburban area with light tree cover and overhead power lines. The BRx7 performed well giving me tight groups of points in 30-second observations. I have to remember to use MSM when configuring the BRx7 since we are now able to use many different GNSS constellations. The 40 mm GPS pole adapter is nice to use. We also got 2 m telescopic poles.
Posted : September 21, 2025 4:35 am
1
Topic Tags
Norman_Oklahoma
I’ve never been a Topcon fan. They used to be cheaper than the alternatives, now they haven’t even got that. I expect that you will be much happier now that you have something else.
Posted : September 21, 2025 11:38 am
field-dog
(@field-dog)
Posted by: @norman-oklahoma
I was tired of seeing autonomous appear on my data collector screen under light tree cover. It cost me many frustrating hours of lost time. Supposedly, the county has purchased a special feature for the BRx7 named Listen Listen. It is described as follows: Carlson Listen Listen is a cloud-based, low latency annual RTK subscription service, which sends RTK corrections to your Carlson base and rover via multiple cellular networks. We normally use only AT&T. However, in certain parts of the county we experience connection problems.
Posted : September 21, 2025 4:07 pm
GaryG
(@gary_g)
@norman-oklahoma
I always said, first to market, last to work.
Posted : September 21, 2025 4:24 pm
hpalmer
(@hpalmer)
Posted by: @gary_g
@norman-oklahoma
except we have a leica rtn base station streaming L1 and L2 and now L5 corrections since 2001 through a static ip to our rtk receivers.  First to market and still working.  Base will be decommissioned end of this year.
for me, first to work first to market - sometimes takes understanding and effort to make work.
I get it that there are many horror stories about vendors selling shells of equipment hoping it will work.  Those vendors get rooted out.
Posted : September 21, 2025 6:08 pm
1
GaryG
(@gary_g)
So true for Leica Equipment.
I ran a Topcon GPT-3005 for a long time and it was a great instrument.
Posted by: @hpalmer
Posted by: @gary_g
@norman-oklahoma
Posted : September 22, 2025 5:04 am
stacy-carroll
(@stacy-carroll)
We've been running a Brx7 since right after they were introduced. Mostly as a network rover. I've had mostly good results under canopy. To me, the most important thing is that it doesn't lie to me. Some other brands/models tell you they are fixed but when you check the point later, you find it quite a bit out of tolerance. I have not been able to get a fix every time under canopy, but when it says fixed it is telling the truth. With Brx7s as base and rover, under light to moderate canopy, I get accuracy that comes very close to what I see with a robot.
Me. "What's the difference?"
Posted : September 25, 2025 4:43 am
1
