OR and WA HISTORY YOU SHOULD KNOW
14 Users
latahgps
(@latahgps)
John B. Preston Esq., was appointed by President Millard Fillmore as the first Surveyor General of the Oregon Territory. ?ÿAt the time of his appointment, Mr. Preston was the City Surveyor for St Louis.?ÿ One of the first tasks assigned to Mr. Prestonƒ??s was to create a system for surveying the land within the New Oregon Territory. ?ÿHe was appointed in December 1850, and lost his position in 1853, he then "drifted into obscurity." ?ÿ?ÿ
On June 4, 1851, John B. Preston set a ƒ??Red Cedar Stakeƒ? to indicate the starting point of all public land surveys in what was then called the Oregon Territory.?ÿ This is the same boundary that later makes up the states of Oregon and Washington.?ÿ Later, on July 25, 1885, the Red Cedar Post was replaced with a carved stone.
Mr. Preston set the point deep in the hills west of Portland, where he believed there would be little chance of the stone being disturbed.?ÿ Another reason Mr. Preston selected this location was so the base line would not cross the Columbia River and the meridian would lie west of Vancouver Lake.?ÿ
The stones original location is now indicated by a stainless steel marker in The Willamette Stone State Heritage Site, an Oregon State park approximately four miles west of downtown Portland.?ÿ The Stake and later The Stone established the base point, or the start point for the Willamette meridian.?ÿ
From this starting point, using a solar compass, Deputy Surveyors James E. Freeman and William Ives then ran the line south and north from the initial stone.?ÿ The north-south lines, or Principal Meridian, were completed with astronomically procedures using a solar compass. The solar compass, invented by William A. Burt, U.S. Deputy Surveyor of Michigan, soon became the standard compass for use in the U.S. public land surveys.?ÿ It functions astronomically, and except when the sun is not out it does not depend upon the magnetic needle in any way.?ÿ The lines run with it are true courses, and when used by a skilled surveyor, the results can be accurate to within 1 to 2 minutes.?ÿ The solar compass enabled the surveyor to run true lines.?ÿ In general, the meridian lines established the starting point of all additional lines.
Starting at the same point as the north-south Principal Meridian the east-west, the Base Line was set.?ÿ This line must be set on a true east-west line.?ÿ As with the Principal Meridian, the Base Line is set using a solar compass.?ÿ While setting the base line the surveyor would set quarter-sections and section corners at intervals of 40 chains (2640 ft.).?ÿ Standard township corners were set at 480 chains (31680 ft. or 6 miles). (1 chain = 66 feet).
Using the Principal Meridian as a starting point Standard Parallels, also known as correction lines, were established every 24 miles, north and south of the Base line.?ÿ They were run east and west of the Principal Meridian.?ÿ The Standard Parallels were designed to counteract the error that otherwise would result from the convergence of meridians; and, because the public surveys have to be governed by the true meridian.?ÿ These lines also served to reduce errors arising from inaccuracies in measurements.?ÿ The first Standard Parallel line north of the Base line was labeled ƒ??First Standard Parallel North.ƒ? The first Standard Parallel line south of the Base line was labeled ƒ??First Standard Parallel South.ƒ? Each standard parallel line is labeled consecutively.?ÿ (IE: Second, Third, Fourth . . . Standard Parallel)
Posted : September 26, 2021 2:30 pm
J.E. Freeman surveyed the exterior boundaries of T23S, R14E, MDM in 1855. We are visiting Section 27 this week, it was surveyed by William Minto in 1872.
Posted : September 26, 2021 3:04 pm
ruffbrew
(@ruffbrew)
It's on my bucket list to visit the park.
https://stateparks.oregon.gov/index.cfm?do=park.profile&parkId=180
Posted : September 28, 2021 9:54 am
tim-v-pls
(@tim-v-pls)
@ruffbrew The park is kinda unremarkable. Our local PLSO chapter did a volunteer "spruce up" day this past spring. (I did not attend.) The marker is down a slope and now surrounded by trees. When you get there you think "how did they survey out of this?"
It's easy to get to and a good little field trip for every local surveyor a least once.
Posted : September 28, 2021 10:36 am
protracted
(@protracted)
Here is a great book all about it. ?ÿDefinitely worth a read for anyone in Oregon and Washington and maybe other PLSS areas as well. ?ÿ
https://www.powells.com/book/chaining-oregon-surveying-the-public-lands-of-the-pacific-northwest-1851-1855-9780939923205
In some ways the Willamette Stone site and park can be described as unremarkable, but in other ways it is quite remarkable and meaningful. ?ÿPartly due to the ease of access, Iƒ??ve been dozens of times and enjoyed each visit.?ÿ
Posted : September 29, 2021 7:22 am
john-putnam
(@john-putnam)
Several decades ago I had a couple of co-workers get hitched at the Willamette Stone.?ÿ Seemed appropriate since they are both surveyors.?ÿ The park was barely big enough to hold a wedding.
Posted : September 29, 2021 7:46 am
john-putnam
(@john-putnam)
@protracted?ÿ
Bonus field trip points if you visits Powell's Books which is literally just down the road.?ÿ
Posted : September 29, 2021 7:49 am
tim-v-pls
(@tim-v-pls)
@john-putnam That's awesome!
Posted : September 29, 2021 8:46 am
tim-v-pls
(@tim-v-pls)
@protracted
To clarify, what I meant to imply by "unremarkable" is that to me, as a surveyor, this park is one of the most important land marks in the Pacific Northwest. It should have a grand arched entrance, manicured lawn, exquisitely maintained landscaping, etc.
Alas, the parks department doesn't hold it in the same esteem.
Posted : September 29, 2021 9:07 am
Jp7191
(@jp7191)
@john-putnam hopefully they created 10 little surveyors to fill the void!?ÿ Jp
Posted : September 29, 2021 10:01 am
@ruffbrew?ÿ
I visited the stone last Saturday afternoon, for the 2nd time in 26 years. I had the place completely to myself. It is a 5 minute walk on a fairly steep paved path from the parking lot on Skyline Blvd to the stone.
Posted : October 12, 2021 9:35 pm
The monument itself
Posted : October 12, 2021 9:38 pm
jitterboogie
(@jitterboogie)
@john-putnam?ÿ
I was at Powells flagship on Burnside several years ago in the rare book room, and asked, " What is the most expensive book you have in here right now?"
No surprise it was a 1st copy of Lewis and Clark.?ÿ Only 35k then.?ÿ Pretty frickin cool!
Posted : October 12, 2021 10:08 pm
jitterboogie
(@jitterboogie)
@mark-mayer?ÿ
My Ex-wife and inlaws routinely mocked me every time we cruised by the Skyline Cafe and I joked about stopping by the burger joint to get one.?ÿ THis is cooler than that, and well, glad to know they're not interested in this kind of stuff either so i'll never see them visiting there either.
COOL!!!
Posted : October 12, 2021 10:12 pm
Jed
 Jed
(@jed)
My gps says its off... ????
Posted : October 13, 2021 7:50 am
john-putnam
(@john-putnam)
@jed?ÿ
You're going to need Nate's gear for this point.
Posted : October 13, 2021 10:52 am
BStrand
(@bstrand)
Member P&R
So the surveyor general went out and put a stick in the ground and then told some other guys to do the work.?ÿ Sounds like a pretty sweet gig if you can get it.?ÿ ????ÿ
Posted : October 14, 2021 9:53 am
Norman_Oklahoma
@bstrand?ÿ
Left unsaid is the work that must have gone into figuring out a spot that would keep the base line south of the Columbia River and the meridian west of Vancouver Lake, and all the while having the meridian run south down the Willamette Valley floor for nearly a hundred miles before striking off into the mountains. You can't just stand on the spot, or any spot near it, and see that.?ÿ The location was selected within a few months of Preston's arrival in the Oregon territory. It must have been a very busy few months. And it's not like he could just place a craigslist ad and hire up competent field crews just like that.?ÿ ?ÿ ?ÿ
And all the while the place is teaming with settlers anxious to perfect their claims. In most places the (non-native) settlement was sparse to non-existent when the surveyors arrived to lay out their townships and sections. In this case the area had been settled beginning 26 years before he arrived and things were getting pretty far advanced. The City of Portland had been founded 5 years before that.?ÿ
So maybe he didn't do a lot of the field work himself.?ÿ But that doesn't mean that he didn't have his hands full.?ÿ
Posted : October 14, 2021 10:44 am
protracted
(@protracted)
If other meridians are feeling left out, you can explore your initial point in this book, https://www.powells.com/book/initial-points-of-the-rectangular-survey-2221114631373 or maybe via this link, https://www.blm.gov/or/gis/geoscience/geosciencespublications.php
Posted : October 14, 2021 9:40 pm
BStrand
(@bstrand)
Member P&R
@norman-oklahoma?ÿ
My comment was intended to be more humorous than a serious criticism of the guy's work ethic, but OK...?ÿ
Posted : October 15, 2021 8:09 am
