Plat Narrative
14 Users
I came across this a couple of days ago, I particularly liked the "vertical datum" note (the Geoid height in this area runs around -15.5 meters).
Vertical
Posted : October 13, 2021 7:08 pm
Wow. Just ....?ÿ wow.
Posted : October 13, 2021 8:59 pm
(@gene-kooper)
Well, if you had stayed retired you would have avoided this nitwittery.
Posted : October 13, 2021 9:12 pm
@mark-mayer Ya can't make this stuff up! Actually I HAVE seen worse...much worse.
On the upside, it tells me more about his survey, than the author probably intended.
Posted : October 13, 2021 9:16 pm
(@gene-kooper)
@loyal And don't forget to to include the difference between NAVD88 and the U.S.G.S. elevations being in NGVD29 (assuming that they looked at spot elevations on a USGS quad sheet for the "U.S.G.S. elevations").
Posted : October 13, 2021 9:21 pm
@gene-kooper Some of the U.S.G.S elevations (including both contours & Bench Marks) predate NGVD29 by quite a bit (1901 Topographic Map) and BMs which were stamped with the elevation and SLAK (Salt Lake Datum)
Posted : October 13, 2021 9:59 pm
(@gene-kooper)
@loyal I think you are being too generous with the extent of his research. With that narrative, it is more likely that he came across a 1950s or 1960s vintage USGS topo quad rolled up and stashed in a corner of his office.
Posted : October 13, 2021 10:28 pm
Posted by: @gene-kooper
I love this word.?ÿ I can't say as I have ever heard it before.?ÿ
ps - for some reason it seems a particularly comfortable fit in a discussion of land surveying... ;)?ÿ
Posted : October 14, 2021 3:33 am
(@shawn-billings)
That's incredible. Like you said, this is actually very informative Metadata.?ÿ
Posted : October 14, 2021 4:15 am
(@rover83)
I've seen "Datum: GPS" quite a bit.
Concerning that note, it would seem to indicate that no geoid separations were applied and heights are ellipsoidal...which is something else I have seen a few times on topographic surveys. In this area the difference is ~70 USFt.
Posted : October 14, 2021 4:58 am
The GPS thingy I'm guessing isn't the real problem.?ÿ
He found the original monuments and rejected them? "because of math"?ÿ That's a quote!!!!
Posted : October 14, 2021 5:07 am
(@bstrand)
@mightymoe
Yeah, I actually find that more amusing than the GPS bit.?ÿ Hopefully someone came along and got this guy up to speed pretty quick, changed careers, etc.
Posted : October 14, 2021 5:40 am
 Norm
(@norm)
@mightymoe?ÿ
If the math is ambiguous shouldn't the existing monuments hold more weight??ÿ And we don't know if he's on grid or ground. We do know he's in GPS nirvana.
Posted : October 14, 2021 5:51 am
The scary part is, the narrative worked. We all know exactly how he wrecked the boundary.
If this guy was in my town we'd have to talk..?ÿ
Posted : October 14, 2021 5:57 am
(@rover83)
Posted by: @norm
And who knows what that "grid" could be and what projection it was derived from. I once came across an azimuthal projection...
Posted : October 14, 2021 6:06 am
(@gene-kooper)
As for what "grid" he used, I think folks are overthinking this again. I have a sneaky suspicion that he [ab]used the localization feature of his GPS black box with three points that are only 200 feet apart and in a straight line.
Posted : October 14, 2021 6:35 am
@norm?ÿ
LOL, he is making an argument opposite of his conclusion......
"I do not think it means what you think it means" Inigo Montoya.?ÿ
Posted : October 14, 2021 6:47 am
The "Subdivision(s)" in question were surveyed by a father & son team in 1964 & 1965 (both were Registered Engineers & Land Surveyors), and have been a notoriously festering boil on the local cadastral fabric ever since (particularly the exterior boundaries). Within the subdivision itself, little evidence of the original 2x2 wood hubs remain, and even fewer have been recovered over the years, and there is a hodgepodge of unmarked ReBars and various "subsequent" attempts to set property corners. In any case, it is a mess. I am only concerned with the exterior boundaries, and that's more than enough headache for me.
Posted : October 14, 2021 9:27 am
Posted by: @mightymoe
@mightymoe How I wish this were isolated to just your neck of the woods.?ÿ
Posted : October 14, 2021 10:07 am
(@jitterboogie)
@loyal?ÿ
Is this from Park County by chance???? ?????ÿ
Posted : October 14, 2021 10:24 am
