Todays 6 acre survey...notice the black cat checking me out.....not sure what that skull is from...wild hog maybe,,,
WTF is that skull on the post? It looks like a pelvis with tusks.
Looks like the remains of that green dude drinking thru a straw in the bar in Star Wars.
on your SMI HP48 setup
Allen Wrench, post: 418847, member: 6172 wrote: WTF is that skull on the post? It looks like a pelvis with tusks.
It's a boar;)
I truly miss the days of spinning angles with a Topcon GTS and a 48 in an environmental case! It was only 6 years ago but for some reason it seems a lot longer.
My GTS-302 hasn't seen the light of day for about 6 years now. I guess I ought to charge it up and make sure it still works.
MightyMoe, post: 418856, member: 700 wrote: It's a boar;)
Looks like the lower jawbone of a boar, inverted.
Think I have the same gun. GTS-302B.
Sure is a lot easier surveying with all the leaves off the trees.
Jim Frame, post: 418866, member: 10 wrote: My GTS-302 hasn't seen the light of day for about 6 years now. I guess I ought to charge it up and make sure it still works.
It's a pretty good bet it will work, but also a good bet that the battery will have to be recelled first after sitting that long.
That is from the era before they figured out how to make gear quit working if you didn't keep up with the updates.
aw thanks, now i'm thinking about my ex-wife...
I am making a note to stay away from the women in Minnesota.
