I'm currently using 2011 stand alone with AutoCAD.
Where did they hide the "split multple codes" option in the field to finish routine?
It used to prompt me. I may have something turned off.
I'm enetering my field data with a "space" to seperate multiple codes and they are plotting on top of each other and I can't seperate the descrition. When I try edit point att, it shows them a two points at the same location, but still won't seperate. They have the same number.
Thanks
With a CRD file already "attached" to your drawing:
Survey -- Draw Field-to-Finish -- Edit Codes/Points -- Code Table Settings:
Geez, shouldn't you be watching football today or something?
Thanks for the response, it looks like I had "all" checked. The descriptions still seem to be plotting over each other and can't be seperated?
I'll see what happens on the next one.
Thanks again
Ladd,
Kudos to you and to your employers for taking the time to answer folks questions here. It is rare in todays world.
You're the man Ladd. Thanks for sharing. 🙂
