workflow process for Carlson/w intellicad to bring in dem data from USGS TO PROCESS CONTOURS
1 Reactions
jjr
 jjr
(@jjr)
I am trying to process USGS DEM  data in Carlson to create contours. The youtube videos are old and the links are old. I wonder if anyone does this on the regular and can offer any workflow tips and cookbook steps?
thank  you
Posted : April 8, 2026 10:46 am
ozzy84
(@ozzy84)
<GFU> (grid file utilities)  <import grid> select your DEM file follow prompts to save DEM to *.grd (make note of DEM units if different than yours)
still in GFU, <export grid> (select your *.grd if not already selected) to DEM or Carlson Tri. File, <ok> name new file.
If Units differ you can open your new .tin with Surface, Triangulation file utilities. Load .tin, <next>, <scale>, look over options, Saveas new Tin name with your units "*usft.tin".
Now you have .tin to load into surface manager.
hope this gets your going.
Posted : April 8, 2026 11:40 am
jjr
 jjr
(@jjr)
@ozzy84 thanks  I am lost in processing hell. I have defined an inclusion area.  The thing hangs up on cell 12965000  I get lost at export to carlson tin
Posted : April 8, 2026 1:05 pm
jjr
 jjr
(@jjr)
@ozzy84 It looks like I have a huge file. Is there away to trim this down and just process a portion of it
Posted : April 8, 2026 2:06 pm
Glenn Borkenhagen
(@glenn-borkenhagen)
I looked at my earlier notes on this process, found that I used QGIS (an open-source GIS program that I highly recommend) to clip the DEM file to the area of interest.  Then it worked!
There certainly may be other programs (I believe Gl__al M__per is one, along with ESRI's ArcGIS Pro) that can clip a DEM/TIFF file.
For some reason the word global followed by the word mapper is redacted??
GB
This post was modified 6 months ago 2 times by Glenn Borkenhagen
Posted : April 8, 2026 2:26 pm
ozzy84
(@ozzy84)
Carlson can handle large .grd better than large .tin
When you finish with GFU import DEM you will have NEW.grd from DEM.
Surface -> Triangle File Utilities -> load GRD -> select New.grd -> next -> pick bounding polylines -> select inclusion polyline-> press enter for no exclusion.
Look at bottom and make sure Output only has "Insides" box checked.
Saveas "NEW-small.grd" -> Exit.
Now open NEW-small.grd in Triangle File Utilities -> next -> saveas NEW-small.tin.
Posted : April 9, 2026 11:57 am
Posted by: @glenn-borkenhagen
GB
mods made it a bad word?!??
Posted : April 9, 2026 12:12 pm
1
