survce question - data collection
mag-eye
(@mag-eye)
Can anybody tell me how carlson survey processes data if i have a single BD record and then a FD, FR but without a BR record.
I have been turning my trav. stations in set collect but for monuments and some other pts I will use traverse which then in my raw data it leaves a BD record after setting my BS followed by A FD,FR, whenever I use the traverse function
The coords are slightly different to the shots using traverse if i remove all the BD records that follow setting a backsight rather than leaving the single BD record. So it seems as if the single BD has some weight.
Posted : December 14, 2018 3:05 pm
mag-eye
(@mag-eye)
Ahh should have titled this Carlson survey question. Not sure how/if to edit the topic title
Posted : December 14, 2018 5:31 pm
jph
 jph
(@jph)
If you have BD/BR for your traverse, I believe that it will also use that to reduce the FD/FR on your sideshots.?ÿ If they're all taken from the same setup session.
If you have no BR and just BD, it will just average the FD/FR values, and won't adjust anything that is usually based on the BD/BR values.
For example, I have an instrument where the reverse is 20" less than the direct.?ÿ So if my BS is 00-00-00/179-59-40, then all FS shots should be similar or they will be adjusted.?ÿ With no BR, if I shoot a monument at 90-00-00/89-59-40, the resulting angle will be 89-59-50, instead of 90-00-00, if I had also recorded a BR.
Clear as mud?
Posted : December 16, 2018 12:19 pm
I do not use SurvCE or Carlson. I use Survey Pro to collect and Star*Net to reduce my data.?ÿ If I do not have a complete set of BD/FD/FR/BR data the conversion to StarNet dat format just crashes.?ÿ?ÿ
Posted : December 16, 2018 12:48 pm
mag-eye
(@mag-eye)
If anybody is interested here is a sample RW5 file to run direct reverse report on in carlson survey notice how it ignores pt 53.
I would like to know how Carlson survey processes BD FD FR BR records more in depth.
I hope i attached this correctly just rename the file to Rw5.
Posted : December 17, 2018 10:36 am
mag-eye
(@mag-eye)
Here is my complete rw5 data 1 original and 1 that i edited if anybody would like to take a look.
Specifically how the BD etc. sets are handled.
Ahh monday.
Posted : December 17, 2018 10:45 am
jph
 jph
(@jph)
As said in my prior post, if you have D&R on your BS, it will use that split to adjust your average on the D&R split for your FS shots.?ÿ
If you have no R on your BS, it will just give you the average of your FS?ÿ D&R.
Your BR shots are generally only 1-2" off 180, so your adjustment on the FS sideshots will be only 1" or less.?ÿ
So your results will be almost the same as if you had a BR shot.?ÿ?ÿ That said, it's bad form, and you don't know if someone kicked the leg after the BD shot.?ÿ Also think it's a good practice to shoot a check shot on the BS as your last setup shot.
Posted : December 17, 2018 11:21 am
mag-eye
(@mag-eye)
JPH thats why i posted this.....
The FD/FR to pt 53 that follow the initial BD shot is ignored. Ultimately after processing the angle from pt 49 to 53 is just the FD record no average. Pts 54,55,56 average the FD/FR.
In my data whenever i reset zero on my BS it has a BD record once i removed all the extra BD records not needed for the sets 1 thru 3 all other FD/FR records were averaged.
Just trying to make sense of this.
Posted : December 17, 2018 11:42 am
mag-eye
(@mag-eye)
What i would like to accomplish is full sets on my traverse and just 2 face measurements to other critical pts.
But whenever i reset zero in the field i get a BD record leaving me cleanup in my RW5 data.?ÿ
Weird If I do a set?ÿ (by set i mean set collect in carlson survce) Oc 2 BS 1 FS3 then followed by just an FD/FR to 51 it pulls the BD/BR from the set to 3 but if there is s/s records after the set then followed by FD/FR just the FD/FR are used.
In survce in my settings i only have traverse set to forward and reverse not the BS I dont want to take a forward and reverse reading to my BS every time i set zero.
So maybe if all i want i a forward 2 face measurement i should be going about this a different way
I feel like people may be recording there sets differently then me doing an initial BD/BR reading ant then using Traverse FD/FR to how ever many pts they want applying the single BD/BR readings to multiple other FD/FR sets.
How is that for clear as mud haha.
Thanks to all who are putting time into reading this.
Posted : December 17, 2018 11:49 am
mag-eye
(@mag-eye)
Sorry just trying to keep this up front.
I have been doing some testing of data sets (BD BR FD FR). Finding some interesting results.
I thought there was a lot more Carlson users on here that could share some info.
Posted : December 18, 2018 4:41 pm
mag-eye
(@mag-eye)
Maybe I'm wrong but some may be interested to know that in Carson survey processing rw5 data if you have a BD/FD/FR/BR record in any order with just a FD/FR to a different pt immediately following?ÿ the complete set it takes the BD/BR from the prior set to complete the set to that pt.?ÿ
It's crazy to me that there is nothing explaining this in any Carlson manual/help that I could find
Posted : December 18, 2018 4:54 pm
