Strange OPUS Error..
5 Users
Is anyone else having files with GLONASS observables rejected by NGS? Just started today...
Posted : October 4, 2017 12:15 pm
That has been an issue, I though they would not process at all if they were present. Not sure why they can't just ignore them.
I always strip out the Glonass (and other constellations) before submitting. Relatively easy to do with teqc, just use the -R switch on the command line to get rid of Glonass birds
Posted : October 4, 2017 12:30 pm
Like John (above), I always strip out the GLONASS (Compass, Galileo) birds before sending the files to OPUS.
However, I just sent a "full boat" (NAVSTAR,GLONASS,Compass,Galileo) file just to see what happened, and it processed fine (<5 minute turnaround).
Posted : October 4, 2017 12:36 pm
Just submitted one with GLONASS SVs 10 minutes ago and processed fine.
Posted : October 4, 2017 12:39 pm
Williwaw, post: 449498, member: 7066 wrote: Just submitted one with GLONASS SVs 10 minutes ago and processed fine.
It's different for you...you can see Russia from your job site.
Posted : October 4, 2017 12:44 pm
I probably got flagged for my time in the Baltic...
Posted : October 4, 2017 12:53 pm
thebionicman, post: 449502, member: 8136 wrote: I probably got flagged for my time in the Baltic...
Russian satellites do not interfere with US Government OPUS solutions. Failing surveying media desperate for page views. Sad!
#fakenews
Posted : October 4, 2017 12:59 pm
James Fleming, post: 449499, member: 136 wrote: It's different for you...you can see Russia from your job site.
Yes, but only because the earth is flat, and if you believe this you too could qualify as a Fox News commentator.
Posted : October 4, 2017 1:06 pm
It MIGHT be that certain servers at NGS behave differently. Not all data is processed on a single server, maybe they have slightly different versions of software. I write a lot of software, and I know it can be difficult to make sure that the software on all of my PC's is all the same version. I make small tweaks and bug fixes, but I do not put version numbers on them (just me and my staff using the software), so it can be difficult to keep track.
They probably use scripts to pre-process the data, and one single line in a script can make a difference.
Posted : October 4, 2017 1:28 pm
