World's Smallest Drill Hole
14 Users
not-my-real-name
(@not-my-real-name)
...measured at 0.01 feet.
Drill Hole
Posted : 31/05/2022 3:53 pm
GIF
Posted : 31/05/2022 3:58 pm
GIF
Posted : 31/05/2022 4:01 pm
That seems small for a survey point, and probably gave great joy on finding it in that messy area.
But if there's a prize for smallest I can do better than 0.01 ft ~1/8" ~3 mm.
Posted : 31/05/2022 4:15 pm
not-my-real-name
(@not-my-real-name)
@bill93?ÿ
Anything smaller would be a pin hole.
Posted : 31/05/2022 4:20 pm
(@chris-mills)
I've used 2.5mm. on concrete surfaces where heavy abrasion is likely and any normal marker would get dragged out.
2.5mm. drill hole, to about 20mm depth, shallow 4.5mm countersink, then drive a 3mm. stainless steel countersunk head screw into the hole. If you leave the drill dust around the hole and push it in as the screw gets hammered down it'll bind and stay forever. Just make certain the head is just below the surface. I've occasionally found some that I put in 30 years ago, still resisting the efforts of snowploughs!
Posted : 01/06/2022 5:49 am
(@andy-bruner)
I had a teacher in high school who was retired from the Navy.?ÿ After WWII he had been stationed in Japan.?ÿ He was a mechanical engineer and worked with Japanese industry during the reconstruction.?ÿ There was a "friendly" rivalry between a Japanese tool company and an American company over who made the best tools.?ÿ One of the competitions was for who could make the smallest drill bit.?ÿ He said the American company sent over a tiny drill bit - the Japanese firm sent it back with a hole drilled in it.
Mr. Rivers developed a great respect for the Japanese people during his years there after the war.?ÿ He was also a good math teacher and a strict disciplinarian.?ÿ He would be in big trouble in our schools today.
Andy
(@back-chain)
Posted by: @andy-bruner
nice.
Posted : 01/06/2022 7:04 am
(@lukenz)
@chris-mills?ÿ
Curious why you hammer in a screw rather than use a masonry screw (not many that short I've seen through) or a tap in masonry anchors like the Ramset Shuredrives?
In NZ the tap in ones are the go to for control points in concrete. Personally, I try to counter sink them by running the drill bit around the top of the hole at 45?ø. Also if you use the ones with the stainless nail you can use a punch to make a fine dimple on it as the reference point.
Posted : 01/06/2022 11:16 am
(@mitchptd)
@andy-bruner?ÿ
My father told me the same kind of story.?ÿ At Snopes they rate it as "legends"
Here is the one dad repeated to me:
"As it was being told just prior to World?ÿWar II,?ÿa German manufacturer had asked an American steel company to produce a?ÿ4-foot?ÿsample of the thinnest wire they could make. The Americans put their most experienced metallurgists and wire-drawers on the job, finally producing what they believed to be a work of technological art. A special courier was dispatched to Germany to deliver the sample and get the reactions of those it had been made for.
The courier was welcomed at the plant and given a glass of schnapps while the wire was taken to another room to be examined by German experts. Before the man had finished his drink, the box heƒ??d brought the sample in was returned to him, now sealed with wax. ƒ??Your answer is in the box,ƒ? he was told. ƒ??Please do not open it until you return to your plant.ƒ?
Stateside once more, the wire was examined by the American engineers whoƒ??d slaved over it. They found a hole drilled down its center, effectively turning their solid thin wire into an impossibly-reamed hollow tube."
Posted : 03/06/2022 11:26 am
There's a YouTube video I saw a few years ago showing a competition between two machinists to see who could drill a hole longitudinally through a 0.5 mm pencil lead.?ÿ One guy was using a manual toolroom lathe with a tiny (!) twist drill bit, the other guy used a wire EDM (electric discharge machining).?ÿ As I recall, the lathe approach came closest to succeeding (and may have actually succeeded). I think the EDM kept burning through the side of the lead.?ÿ?ÿ
Posted : 03/06/2022 12:04 pm
(@ashton)
What this reminds me of is the whole business of US survey foot vs. international foot was supposedly created by a need in precision machinery to have an inch that was so well defined that the differences among US, UK, Canadian, South African, and Australian definitions of the inch were making a difference, and a supposedly interchangeable part made to the standards in one country would not necessarily interchange with the same part made in another country. Supposedly this kind of problem first became noticeable during World War II.
But I have never been able to pin down any specific information to back up this vague idea.
Posted : 03/06/2022 1:01 pm
Units are decidedly weird things.?ÿ Take the ton for example.?ÿ Long ton, short ton, water ton, freight ton, ad infinitum.?ÿ A freight ton is 40 cubic feet.?ÿ A ton of air conditioning provides the same amount of cooling as one ton of ice melting.?ÿ Still not sure what a 3/4-ton truck is, though.
https://en.wikipedia.org/wiki/Ton
Posted : 03/06/2022 3:29 pm
not-my-real-name
(@not-my-real-name)
I will be happy to convert the drill hole's diameter to what ever units you desire... except tons.
Posted : 03/06/2022 5:33 pm
Posted by: @holy-cow
Not quite-it's a rate, not an amount..?ÿ A ton of air conditioning removes heat at a rate corresponding to one ton of ice melting PER DAY.
Posted : 03/06/2022 6:37 pm
