Understanding Face Left and Face Right Angles
9 Users
15.2 K Views
Steward Souten
(@steward-souten)
Hello all
Probably worth apologising before hand for what may appear to be extremely simple questions - but I am very new to surveying with little access to field equipment.
I am trying to understand face left and face right observations using a total station.
I have done a little sketch which I was hoping someone could confirm that my thinking is correct or if its not then explain why my thinking is incorrect.
Below is a sketch of 3 x points in the ground.
I have set my instrument to face left.
I have set up over STN3 and set a fixed bearing of 00 00 00 to STN2.
I then turn clockwise until I meet STN1 giving me a face left angle of 353 18 14.
(Face Left Image)
Hopefully this is all correct so far.
The next bit is where I get a little confused.
My instrument is still at STN3 and I am sighting to STN1.
In order to take a face right angle I rotate the telescope vertically 180 degrees, making it point in the opposite direction to STN1.
I then turn clockwise until I sight to STN1 and read off the angle, in this case I get an angle of 173 18 13 which is my face right angle.
(Face Right Image)
Would you all agree that this is correct?
The reason why I mention this is because I thought that a face left angle is an angle measured clockwise while at STN3 From STN2 To STN1.
And a face Right angle was when the same angle is measured but telescope is rotated 180 degrees, turned clockwise until you have sighted back to STN1 and then the same angle is measured again but anti-clockwise - I know this is incorrect but doubt has crept into my mind.
Finally the reason why we take angles in both faces is because we can cancel out any errors; in this case I get a face left angle of 353 18 14.
By rotating the telescope 180 degrees so it is pointing in the opposite direction effectively means that my face left angle is now 353 18 14 - 180 = 173 18 14.
While the telescope has been rotated 180 degrees I sight back to STN1, then if the angular reading I get is more or less then 353 18 14 then the difference is the amount of angular error in my observation - would you guys agree?
Just to put everyone's mind at ease, I am not a surveyor or an engineer hence the "low level" questions, I just have an opportunity to learn about surveying which I hope will lead me onto a job.
If anyone can help then that would be great.
Many Thanks
SS
Posted : May 29, 2017 5:48 pm
The terms "Face Left" and "Face Right" originally refered to which side of the telescope the vertical circle of a theodolite lay when the telescope was reversed by rotating it 180?ø about its tilting axis. It the vertical circle was on the left side of the telescope from the observer's point of view at the eyepiece, that was the Face Left position. An alternate terminology is "Face I" and "Face 2".
The purpose of measuring an angle on each of those two different telescope positions or faces was to cancel certain errors resulting from the fact that the tilting axis may not have been perfectly perpendicular to the turning axis of the instrument and that the line of sight of the telescope (its "axis of collimation" was not exactly perpendicular to the tilt axis.
Any good surveying textbook will discuss errors of these types and how they are canceled in how observations are taken.
Posted : May 29, 2017 6:49 pm
See Kent posted at same time. Some duplicate info
The saying goes back to the origins of Theodolites.
It has nothing to do really with the direction you are reading. Anticlockwise or clockwise.
Setup, sight backsight on 'face left', site foresight. Flip telescope and rotate theodolite (total station) site foresight again (you are now on face right) then resight backsight.
Record each reading.
Some sight back and fore, then flip telescope and resight back then sight fore again.
Backsight 0?ø0'0ƒ?? foresight 156?ø25'36ƒ??
Flip and reread foresight 336?ø25'12ƒ??
Re read backsight 179?ø59'36ƒ??
Take mean face left and face right (included angles) and theoretically that's your true included angle. (those are a bit sloppy and good instrument should be far better)
In past with old instruments we'd stack up readings. Observe back then fore, then hold that reading and release bottom clamp and set that to backsight, read foresight etc.
That uses different parts of the circle to supposedly take out instrument errors due to poor circles.
I pinched the following of a site.
(i) Face Left: When the Vertical Circle of a Theod is situated on the left of the observer and the observation or reading taken with this face is called Face Left Observation or Reading.(ii) Face Right: When the Vertical Circle of a Theod is situated on the right of the observer and the observation or reading taken with this face is called Face Right Observation or Reading
Posted : May 29, 2017 6:50 pm
Richard and Kent explained FL and FR pretty well. I always called it direct and reverse (D & R), same thing as FL and FR.
The other thing you mention is angles right and angles left. When I used to use an optical theodolite (i.e. manually read circles) to run control, i would turn half of my sets (for example, 8 sets for second order class I) as angle right (BS-FS-flop-FS-BS). Then I would do the other half of the sets as angle left (FS-BS-flop-BS-FS). The average of each of these should sum to 360 within a few seconds. It was just another way to avoid blunders in reading and recording.
Posted : May 29, 2017 6:56 pm
larry-scott
(@larry-scott)
John Hamilton, post: 430343, member: 640 wrote: Richard and Kent explained FL and FR pretty well. I always called it direct and reverse (D & R), same thing as FL and FR.
Isn't 'angle right' increasing to right? And an 'angle left' increasing to the left? regardless of BS. I've never seen a theodolite that read 'angle left'.
Switching BS to FS is 'closing the circle', still angle right.
(Don't want to confuse the new guy.)
Posted : May 29, 2017 7:20 pm
Yes, it is closing the horizon, and of course the circle reads only one direction. But we called it AL and AR because we were measuring the angle in a different sense (FS first, then BS). So maybe it is not the clearest terminology. Once I converted the "AL" back to BS-FS by subtracting from 360, it was an "angle left" from the BS.
Posted : May 29, 2017 7:23 pm
Larry Scott, post: 430346, member: 8766 wrote: I've never seen a theodolite that read 'angle left'.
Maybe I'm misremembering -- it's been about 37 years -- but doesn't the T16 read angles both left and right?
Edit: I guess the ones we had were T16-ED models. From the http://www.wild-heerbrugg.com/theodolites2.htm#T16&apos ;">Virtual Archive of Wild Heerbrugg:
The T16-ED has the extra facility of a horizontal circle with double numbering (360?ø circle only), allowing angles to read or set out either to the left ("North to West") or, in the normal fashion, to the right ("North to East").
Posted : May 29, 2017 7:45 pm
One also, as in many discussions across continents, have to account for local lingo.
I'm equally at home with F1, F2 or FL F2.
Also the language of theodolites, jigger, guns not to mentioned terminology for observing principles and so it goes.
We talk about the same things, just the language sounds strange.
Posted : May 29, 2017 8:50 pm
Richard-I have always referred to a total station or an optical theodolite as a "gun". Causes some weird reactions sometimes when non-surveyors hear you talking about using a gun and shooting some distances.
About terminology...I had a non-surveyor one time who was running a GPS receiver for me tell the office people that we were out "turning corners".
Posted : May 29, 2017 9:01 pm
Military instruments usually have double etching. Orient the magnetic instument to the direction of fire. Sight the scope of another instrument (usually a gun site) and read the angle left. The gun puts that number in his site and shifts the whole cannon until he is sighting the magnetic instrument.
Repeat the process for the remaining cannons and voila. Everyone can hit the same target...
Posted : May 29, 2017 9:13 pm
bushaxe
(@bushaxe)
Jim Frame, post: 430350, member: 10 wrote: Maybe I'm misremembering -- it's been about 37 years -- but doesn't the T16 read angles both left and right?
I was about to mention the T-16 before reading this. Never used it for production but did have a chance to use it in school in 1987. So 30-years for me.
Posted : May 30, 2017 4:11 am
Steward Souten, post: 430334, member: 12714 wrote: Hello all
Many Thanks
SS
https://www.pearsonhighered.com/program/Ghilani-Elementary-Surveying-14th-Edition/PGM91929.html
Posted : May 30, 2017 4:43 am
Steward Souten
(@steward-souten)
rfc, post: 430367, member: 8882 wrote: https://www.pearsonhighered.com/program/Ghilani-Elementary-Surveying-14th-Edition/PGM91929.html
just got this book thanks
Posted : June 10, 2017 7:03 am
