How in the h*ll do you delete old job files from the Trimble TSC2?
Thanks
The only way I have found using Survey Pro is to use Active Sync or Windows Mobile Device Center.
Hi,
on the TSC2 from within your explorer, no such optiuon in Trimble Acces.
Tap your windows Key. Upper left button on my TSC2
Tap File explorer
Browse to your Trimble Data folder
selcet your file or files if needed
Tap Menu (bottom right) en choose Delete.
I think you can also delete them when from the pc when your connected with active sync and browsig from there.
You know once deleted on the TSC2 there's no way to undelete as on yoiur dekstop.
Hope this helps,
Christof.
These are old files from who knows who...I don't have any use for them, my TSC2 has survey controller 12.46...thanks..
Easiest way is through a PC using Active Sync or Mobile Device Center and Windows Explorer. But you can also just use the file explorer in Windows Mobile. If you leave Survey Controller open you can't delete the job that's open in it, so when I really want to clear one out I close SC first.
I use total commander from Total Commander on all my PC's. They have a windows mobile version (for the TSC2) and an android version as well. Also has ftp client built in. One of the few absolutely indispensable programs that I cannot live without.
