Hi
anyone wants to give this a try.
I received a Trimble job file (R8 gps data) from someone else, I need to check the Coordinate system for Belgium (for shift grid file and geoid hbg03 used)
My TGO 1.63 and data transfer says it's an old version 2.1 file and can not import.
Next message is Database wrong version, expect 1.90-9 and actual 2.10-17.
Can someone convert for me to something I can import in TGO or use the ascii file converter to convert to Jobxml or Survey report.
The one that delivered the file is of no help, this is not a survey company but a probing company. The contractor will start the foundations tomorrow at 7 o'clock ... that's 12 hrs from now on
link to job file.
http://www.mediafire.com/download/uhbvp3d4uvdldwy/genk-1.job
christof[dot]lambrecht1@telenet[dot]be
thanks
Christof.
Christ: not sure what you really need, but as far as I know there is no R8 data in this file. But, I did create a .jxl file out of it.
Note: it is ascii, you can open it in any editor, it has transformations, etc listed.
John,
great! I was able to process the jxl in the ascii file utitlity and made a survey report, these guys took the wrong projection system without the shift grid file;
Thanks for soliving my problem instantly, your help is very much apreciated!
Greetz from Belgium.
Christof.
John Hamilton R O C K S ! !
> John,
> Christof.
