TDL 450H burnt pin
9 Users
cordgrass
(@cordgrass)
My radio cut out after a few hours of work but I was finish the job. I thought my battery was dead. I went to setup my rtk this afternoon and noticed a burnt pin. The radio did come on and transmit light was on once I started the base then it cut out. I went check the cables and noticed this. Can this be repaired or is it finished?
Posted : July 6, 2017 6:34 pm
Well THAT can't be good!
Posted : July 6, 2017 6:40 pm
As long as no circuits were fried, replacing the plugs could fix your problem.
That exact style of plug may take a major search.
Start with Google and EBay.
Posted : July 6, 2017 6:53 pm
superfly
(@superfly)
Our equipment manager says yes and it costs a couple hundred bucks. He also tells us never to go past 16 watts and never the (hwy) setting it heats up the radio faster. I also use a sun screen on top of radio.
Posted : July 7, 2017 8:46 am
Be sure there is a fuse in line from the power source to the radio, then be sure to make it small enough to be useful. I know it can be frustrating to burn out fuses on the radio but if it saves that from happening,,,,,,,,,,, I had one go out last Tuesday, and it's a pain to go back to the radio and replace it, still it's better than sending the radio in for repairs. The power cord came with a 5 watt blade fuse, about about the weakest one for that application, but it may have saved me from your situation.
Posted : July 7, 2017 8:55 am
fairleywell
(@fairleywell)
Make sure you get an updated cable with the repair. The part number should end in REV-B if memory serves.
Posted : July 7, 2017 10:17 am
cordgrass
(@cordgrass)
I called Local dealer they said it could be repaired and I ordered a new cable. They will also repair the old cable I can use as a spare.
Posted : July 7, 2017 11:16 am
cordgrass
(@cordgrass)
MightyMoe, post: 435758, member: 700 wrote: Be sure there is a fuse in line from the power source to the radio, then be sure to make it small enough to be useful. I know it can be frustrating to burn out fuses on the radio but if it saves that from happening,,,,,,,,,,, I had one go out last Tuesday, and it's a pain to go back to the radio and replace it, still it's better than sending the radio in for repairs. The power cord came with a 5 watt blade fuse, about about the weakest one for that application, but it may have saved me from your situation.
I had a 15 amp fuse guess I'll get some smaller ones.
Posted : July 7, 2017 11:18 am
david-baalman
(@david-baalman)
Had the same issue, we were told you MUST turn the power off before disconnecting the power cable.
Posted : July 7, 2017 11:31 am
Pin 1 (the burnt one) is +12v on the Trimble gear I'm familiar with, so I can see how unplugging the cable before powerdown might do that.
Posted : July 7, 2017 1:41 pm
Geoff giegling
(@geoff-giegling)
I have heard that you should firmly hold/tie the data cable to the tripod so it isn't swinging in the wind, This can cause
micro shorts scorching the pinholes
Posted : July 7, 2017 2:12 pm
