Taken from a webpage... These are not ours !!!!!!
13 Users
sacker2
(@sacker2)
FLOOD INSURANCE? Save by considering an Elevation Certificate and/or LOMA $180
$240 LOT SURVEYS QUOTES FOR MORE COMPICATED SURVEYS
$85 FEMA ELEVATION CERTIFICATES FOR FLOOD INSURANCE $150 FOR SUPER RUSHES
o.O :excruciating: :-X :-S
Posted : February 15, 2013 2:49 pm
tommy-young
(@tommy-young)
I've seen those rates before. TPR posted something about them the other day.
Posted : February 15, 2013 4:08 pm
Andy Nold
(@andy-nold)
Supporter
When you post exact text, it is not hard to cut and past that text into a web search engine and figure out exactly who you are talking about.
If they're going to put it on the web for public consumption, is there some reason their identity should be withheld?
Posted : February 15, 2013 4:09 pm
They don't want anyone to call them ! No one can survey for that price.
Posted : February 15, 2013 4:31 pm
DEREK G. GRAHAM OLS OLIP
(@derek-g-graham-ols-olip)
There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply.
The person who buys on price alone is this man's lawful prey. John Ruskin
Posted : February 15, 2013 4:58 pm
spledeus
(@spledeus)
What's a PSM?
In Florida, are all Surveyors Mappers too?
Searching for the text results in more than one firm (or one firm with multiple names?)
http://flaeloma.com/index.html
http://aeclandsurvey.com/
http://www.flasurveys.com/
Posted : February 15, 2013 4:59 pm
You shouldn't question what someone charges for their services, only they know what their services are worth......
Dougie
Posted : February 15, 2013 8:10 pm
What's a PSM?
Several years ago the great State of Florida (in one of it's fits of infinite wisdom) decided that Photogrammetrist's were every damned bit as good at surveying land from aerial photographs as surveyors who actually "surveyed" the site on the ground.
Thus "PSM", or Professional Surveyor and Mapper. Makes sense don't it? 😉
Posted : February 15, 2013 8:58 pm
spledeus
(@spledeus)
What?
So can a photogrammetrist perform boundary surveys?
Posted : February 15, 2013 10:46 pm
The Pseudo Ranger
(@the-pseudo-ranger)
What?
Yes, but only if they willing to do them for $240.
Posted : February 15, 2013 10:48 pm
bow-tie-surveyor
(@bow-tie-surveyor)
I believe that the people who are doing the elevation certificates for under a $100 are using network VRS GPS to establish elevation at the site then run a quick bench run (possible solo laser level) around the house then take a couple of pictures. It is conceivable that they could be in and out in under an hour. Then take an hour to fill out the elevation certificate. So is $85 for about 2 hours of work doable?
I have never used network GPS and I am not sure how good the elevations are that they produce, but I have heard from a number of surveyors here in Florida that it is pretty good.
The Bow Tie Surveyor
Posted : February 16, 2013 5:59 am
alan-cook
(@alan-cook)
Did anyone else click the link for ALTA surveys? It proved to be nothing more than a dissertation on alligators.
Posted : February 16, 2013 8:21 am
Cliff Mugnier
(@cliff-mugnier)
"Network GPS" vertical accuracy is dependant on the density of the CORS sites. With a large spacing among stations, you can get numbers that may look good but are not necessarily reliable.
Professional work still requires professional judgement. There's no "Easy Button."
Posted : February 16, 2013 11:58 am
bow-tie-surveyor
(@bow-tie-surveyor)
It's my understanding that Florida has a pretty dense RTN network. The Florida Department of Transportation about 10 years back started installing CORS stations all over the state (like at least one in every county). In addition, there are a number private network providers that add on to that as well.
That being said VRS GPS sounds like the magic black box with the "Easy Button" to me. All you are measuring is a vector from this "virtual reference station" that is always with you what some computer has modeled for you from the CORS stations around you. Very mysterious. I guess the guys in the white lab coats say its good. Not sure how you check it.
Posted : February 16, 2013 5:23 pm
roveryan
(@roveryan)
If CORS in your country is similar to stand alone RTK base/rover setup then I would say that elevation from them is pretty accurate.
Remember that you are also using RTK elevation values for topographic survey & bathymetry survey. If they are reliable for those purposes then the Z-value from CORS is similar to RTK Z-Value. I would just make the distances from the stations to be minimum as much as possible to minimize Z errors.
Posted : February 17, 2013 3:31 am
