Subdivision Layout Software
11 Users
Ben Purvis
(@ben-purvis)
Can anyone recommend a good subdivision layout software? I have a very large and strangely shaped property that is going to be divided and need a software that may help produce several different layouts quickly and efficiently.
Posted : May 22, 2012 3:53 pm
cptdent
(@cptdent)
Carlson makes a good product. Either the Civil or the Survey package may have what you need. Check out the features on their website.
Posted : May 22, 2012 4:27 pm
Ben Purvis
(@ben-purvis)
I use Carlson and have used the lot layout function but was looking for something possibly more feature rich.
Posted : May 22, 2012 4:36 pm
ladd-nelson
(@ladd-nelson)
Did you use Area Layout -- Create Lots -- Design Lot function or the Area Layout -- Lot Network collection of routines? If the latter, what kinds of features do you feel are needed to make these subdivision layout tools more feature rich?
Ladd Nelson
Posted : May 22, 2012 8:48 pm
Perry Williams
(@perry-williams)
Unless you do a ton of large subvdivisions, I would recommend keeping it simple.
I know Texas is not New Hampshire, but around here there is simple too many factors in subdivision for a computer to figure it all out. They can be used for preliminary design, maybe.
Here are just some of the constraints we are up against:
min frontage, min lot size, prohibitions against irregular lots, wetlands, house sites, utilities, well locations, ledge, septic locations, woodland buffers, building setbacks, view easements, subdivision road layout constraints, length over depth ratio constraints, steep slope limitations, nitrate setbacks, etc, etc.
Posted : May 23, 2012 5:04 am
andy-j
(@andy-j)
google "coving"
and start reading...
Posted : May 23, 2012 6:24 am
google "coving"
Coving is soooo 90's 😉
The main proponent of coving has moved on to Prefurbia
Prefurbia Part 1
Prefurbia Part 2
Prefurbia Part 3
Prefurbia Part 4
Posted : May 23, 2012 6:32 am
andy-j
(@andy-j)
google "coving"
haha!! yes, that was the name that popped into my head..same guy, fancy new word!!
Posted : May 23, 2012 6:39 am
What exactly do you mean by "feature rich"? We have AutoCAD Civil 3D, and it is so "feature rich" that it is essentially unusable... Be careful what you wish for!
Posted : May 23, 2012 7:53 am
squinty-vernier
(@squinty-vernier)
google "coving"
Entertaining seminar, too! I need to adapt those techniques to doublewide layouts 😛
Rick
Posted : May 23, 2012 7:59 am
foggyidea
(@foggyidea)
Pencil and onion skin paper is what I use at the beginning stages...preferably yellow onion skin paper...
Posted : May 23, 2012 8:12 am
andy-j
(@andy-j)
but vidalia onion skin paper makes some sweet designs!
Posted : May 23, 2012 8:13 am
Paul Plutae
(@paul-plutae)
Old method, but it has been quite successful for many large prelim layouts.
Flimsy paper and drafting table.
Posted : May 23, 2012 8:15 am
foggyidea
(@foggyidea)
I'm trying to get a mental handle on a subd design program that would do better, especially if topo is a concern, as it always seems to be...
Posted : May 23, 2012 8:17 am
Kris Morgan
(@kris-morgan)
Ben
Really? What software do you normally use? I use Carlson, but would have no problem using PacSoft for the same thing.
Is this a trick question?
Posted : May 23, 2012 8:24 am
Perry Williams
(@perry-williams)
Ben
Not really. Ben feels he should occasionally post a survey-related thread to show us he occasionally actually does do some work.
I just start drawing closed polylines and do some quick area calcs on them and tweak them around using the Autocad Grips to get the necessary setbacks and acreage. Of course, subdivisions around here always need to checked out in the field to see if suitable building locations are available and the sites are accessable before anything can happen.
Posted : May 23, 2012 9:04 am
Kris Morgan
(@kris-morgan)
Ben
I agree. Typically, if I don't have a topo of the area, I'll load the contours from the quad sheet and look at that (better than nothing). Then calc the boundary, lay in some lots and a few roads, evaluate whether I could tweak something, then pass it off to the client as a proposed S/D with a price. Should take, depending on the size, about two hours.
Posted : May 23, 2012 9:10 am
Kris Morgan
(@kris-morgan)
Perry
One time, I was asked by an attorney, to design the most elaborate s/d I could conceive on the proposed take line of a proposed lake (WTF?) and show where the proposed pipeline (you see where this is going) would bisect the tract. The attorney and his client came in and said, that's what I was thinking of doing (yeah right) and they used that as an exhibit to run damages up on the pipeline.
It took a little longer than two hours, but I was done in under a day with some really elegant and elaborate BS. I don't think there were 5 tangents in 5 roads out there. I tried to write my name with it, but that didn't work. 🙂
Posted : May 23, 2012 9:13 am
Ben
IMHO, If you don't have a topo of the area you shouldn't be laying out a subdivision! Maybe you're in a flat state, but where I am the vertical issues often drive the entire layout...
Posted : May 24, 2012 8:00 am
Ben Purvis
(@ben-purvis)
Ben
Flat as a pancake, one small creek crossing property and waterfront on the back.
I've decided to just sketch up two quick but substantially different layouts and let the design go from there. I just don't have time to give them a half dozen layouts and the budget I've been given doesn't allow.
In the end I'm going to sketch up what I would do with it, or at least substantially what I would do, and let them make a decision.
Posted : May 24, 2012 10:13 am
