Hello All,
I have not been on the board in many years and just re-discovered it today. As I am now getting "long in the tooth" as they say, I am somewhat semi-retired and found something that I have been interested in for years. I just recently became involved in selling drones for my local surveying equipment dealer because I wanted one. Originally I was just going to do demos, but it got so busy I just went to work for him. Just a few quick comments on drones. They are not the panacea for topo/mapping. They are just another arrow for the surveyor to keep in his quiver. It is nothing more than an airborne data collector that can be a great time saver in the right situation. You still have to process data and create a finished product.
Now for the interesting part. The vertical component of the point cloud is 2-3 times the horizontal spacing. so if your mission is set up to do 1.5 inch pixels the the vertical error will be 3-4.5 inches. Now I have come across some surveyor types (non-registered) in the last month or so who are involved in agriculture doing field leveling and tile irrigation installation. They tell me that their work has to be within a 0.10'. I ask them how they are doing this topo work and one of them drives his 4 wheeler across the fields. He is also the one who said he was working to 0.02' because that is what his data collector showed.
The other gentleman told me that he mounts a GPS on the farmers tractor and does a "measure up" to get the HI and the farmer drives the field. They are both convinced that they are working to within a 0.10 of a foot. I use a Leica GS15 with a base and also with a network. All I know is that when it needs to be accurate, I get out a level and shoot the elevations.
All of this just substantiates my belief that any equipment in the wrong hands is a disaster looking for a place to happen and you can't argue with ignorance.
Enough of my rant.
A few years back I attended a demo for machine control. The 'trainer' was going through the steps to set up a job. At the end of his 2 minutes on localization he showed the parameters for a job they were setting up. The scale was several times what it should have been and the slope north and east made just over a 2% tilt.
The saddest part of the whole thing was the discussion with the Surveyors at break. They didn't see an issue. Yes, equipment in the wrong hands is a bad thing...
Actually, under open skies, the GNSS systems of today are pretty reliable horizontally and vertically. I trust them to yield results within specs (1 cm / 2 cm's) if proper methods are used.
I do, too, with the understanding that the spec is 1-sigma and has an additional 1 ppm error component not mentioned above. Vertical errors of 4 or 5 cm on a 5 km vector aren't uncommon.
I am a construction guy, I work with short baselines, usually maximum 1 km. My experience is the vast majority of QC check shots under an open sky are within mentioned numbers above.
Drones for photogrammetry?? I thought that commercial use of drones was illegal in the US?? did I miss something?
Field tile to the nearest 0.1'? They may "think" they need that kind of accuracy, but unless the field is flat as a pancake, I doubt it. just like they may "think" they are getting that kind of accuracy from their gps and measure up tractor methods.
The fact is, a good field guy can lay tile and make it work by eye. At least that's how I always saw it done growing up.
water flows downhill.
We have Sections with a foot of fall in a mile. Eyeball that and you will have a problem...
for sure!! wow. and I thought Illinois was flat!
Andy is in Florida: also known as the flattest piece of delineiated land on the planet.
Keep in mind what is being measured. Yes they MIGHT be getting the nearest 0.10' but I bet they don't know, but if you are taking shots on plowed farm ground, its so rough the nearest 1' is all your really getting.
exactly right, David.. the whole thing is just silly.
Yes, I get out the level a lot. Must agree with that, but for a field survey, there is nothing that will compete with GPS and a four wheeler. Either do them RTK or post-processed. Much better than lidar surveys I've used, some of those were good, some were bad but none were nearly as accurate as GPS and a four wheeler. You can do them with a total station or robot, but for a much higher cost and little benefit. And if you try to cross-section and level them you miss too much.
I expect what they are doing is the original ground topo with the tractor or atv. They then design their tile runs based on that. The tiling machine would be a slow movimg tractor with better accuracy to better control the depth. It would probably be a minimum of 3 ft deep, and a minimum of 4" tile, so there is some wiggle room there. All it has to do is not have any spots in it high enough to keep it from flowing. The accuracies they are getting may not be what they think, but evidently the method does work.
Yeah, that's what I was trying to say... Not as well as you did, though.
They can believe it's .001' accuracy too, as long as the water flows, who cares.
Ps. Finally replacing old #49 with a new S6!
What year did you buy it? Did it quit or you just upgrading?
Still working with the geo every day. Traded in an older Topcon I had on the shelf.
Haven't had an afternoon to really even work with the S6 yet, between the weather and finishing projects.
