Not the best way to set a corner
16 Users
(@the-pseudo-ranger)
I found this one today. First time I've ever seen this. I recall having a conversation with my PC about this early in my career, and explaining it to a couple of greenhorns since.
That's a surveyor's disk, marking a property corner, epoxied to the lid.
Posted : July 31, 2012 2:35 pm
(@derek-g-graham-ols-olip)
Able display of a faint sign of intelligence in action ?
DGG
Posted : July 31, 2012 3:01 pm
(@clearcut)
Wow!
Posted : July 31, 2012 3:08 pm
Are we even sure that particular water valve lid is positioned on the correct water valve? Let alone, has it been rotated? It might be for some valve 500 miles away.
This reminds me a bit of a former surveyor in this area who would pick up a loose railroad spike out of the ballast and drive it into the ballast as a survey monument. There are hundreds of spikes within a few feet of the corner. How would you ever know which one was the right one?
Posted : July 31, 2012 3:14 pm
(@don-blameuser)
Well now, wait a minute.
Except for the Cow's argument that the the lid could be placed on another valve, how far off could it get?
How big are those covers?
Significant?
I don't know. I just know that, with Keith Williams back on the scene, I definitely do not want to be classed as an "expert measurer."
Don
Posted : July 31, 2012 5:17 pm
Don, if you measure that "monument" on a warm afternoon I hope you take into account the coefficient of expansion of the iron lid.
Posted : July 31, 2012 5:53 pm
 vern
(@vern)
When I started out surveying in Arlington, Va there seemed to be a lot of points that fell on manhole lids. We used to chisel marks in the rim so we could criss-cross the plumb bob string on the point. I wonder why anybody would set a cap with identification on a movable object, OH WAIT, the earth is moving too. why are we setting caps?:'( o.O
Posted : July 31, 2012 7:15 pm
(@clearcut)
great point Don.
We should accept it wherever it may fall that day.
Measurements be danged.
Posted : July 31, 2012 8:08 pm
(@harold)
Use GPS !
We can get it down to a gnat's whisker that-a-way. Oh, waitaminute.....our tectonic plate is moving, too!:-D
Posted : July 31, 2012 8:21 pm
 RFB
(@rfb)
Yep, SOP around here.
Sometimes you'll even see 4 N/Ds instead of chisel marks.
BUT, IF you used epoxy on the lid also, it would be OKAY!!!!
Posted : August 1, 2012 2:52 am
(@idiot-wind)
As a greenhorn rodman in the early '90's, my crew had to follow up on another crews job and run levels. The PC from the other had crew chisled and painted the corner of a headstone in a cemetery. He was fired later that week.
Posted : August 1, 2012 3:46 am
(@daryl-moistner)
That would actually be cool if it was my headstone
Posted : August 1, 2012 5:31 am
 hlb2
(@hlb2)
Heck, I've never had luck with the epoxy. We set a few block corners in some concrete curbing a few years back, they are all gone now. Bad epoxy maybe???
Posted : August 1, 2012 5:55 am
(@mark-chain)
haha....
Yeah, I like it, try to get a plot for a grave where you can write up an easment for the NGS to set a horizontal or vertical mark to be used by surveyors and have the mark set in the headstone.
Otherwise, please don't bury me down in that cold, cold ground.
Posted : August 1, 2012 6:40 am
(@bruce-small)
I"ve seen a monument set on the lid of a manhole, and not near the middle either. Crossouts on the rim are good, but the lid?
Posted : August 1, 2012 10:22 am
(@keith)
Hey, why is that not a good idea.
The next surveyor just needs to rotate the lid somewhat and the monument will match the new distance.
Maybe a different idea here? 😉
Keith
Posted : August 1, 2012 10:27 am
(@wa-id-surveyor)
Due to a mis-set monument case in a new city street project I had to chisel an 'X' and my pls # on the interior ledge of the monument lid. By the time I got to setting this corner the contractor was long gone and there was no way he was going to move this monument case. Somehow he failed to set it in the right place...something about misplaced reference points. He did manage to get the other 5 in the correct location though.
Posted : August 1, 2012 10:57 am
(@mark-chain)
Good one Keith
Maybe that can be a standard monument always set on a lazy-susan type of apparatus. The next guy can just turn the table. Saves on driving all those extra pins in the ground.
Posted : August 1, 2012 11:18 am
(@keith)
You got it Mark!
No more pin cushion corners!
Posted : August 1, 2012 11:47 am
