Mini Rodman
11 Users
jimmy-cleveland
(@jimmy-cleveland)
I am currently performing layout work that requires me to stake out points on a finished concrete floor on multiple floors of a building that is nearing 90 years old. It is a pretty neat project.
We have been using peanut prisms for accuracy, and either using them on the small point and running a conventional instrument, or on a 1' tall mini stakeout rod running robotic.
I was cleaning up the office the other day, and ran across this mini prism stand that I had purchased off of ebay just because I thought it might come in handy, and low and behold, it will be my rodman tomorrow. I had to purchase longer screws to make the stand a little taller to allow for the mini prism point to just barely touch the floor, but I think this should work out quite nicely.
Posted : May 28, 2015 1:49 pm
j-penry
(@j-penry)
I love it! What a great tool.
Posted : May 28, 2015 2:20 pm
gromaticus
(@gromaticus)
I bought one of these a few years ago, also on ebay - it was pretty inexpensive, from China as I recall.
It has come in handy on many occasions.
Posted : May 28, 2015 2:55 pm
Sweet
Posted : May 28, 2015 2:56 pm
jimmy-cleveland
(@jimmy-cleveland)
You are correct. I bought two more today for my other mini prisms for $9.50 each. I bought the screws Metric (M5-.8 x 60) at Home Depot this morning for $6 dollars and some change.
Total investment for each setup will be about $13.
Posted : May 28, 2015 3:31 pm
cf-67
(@cf-67)
A few more ideas!
Posted : May 28, 2015 3:57 pm
gromaticus
(@gromaticus)
I just remembered the last time I used it, about 2 weeks ago.
I had a tree branch in the way of a shot - a fancy ornamental that I couldn't trim.
I tried to prop it out of the way with a prism pole, but the branch would just slip off the top.
So I screwed this mini tripod upside down on the top of the pole. The three screws worked like a charm and kept the branch from slipping off the pole.
Posted : May 28, 2015 7:33 pm
Steve Corley
(@steve-corley)
Check this one out. We use this for high precision work.
http://themarksman.co
Posted : May 28, 2015 9:08 pm
jimmy-cleveland
(@jimmy-cleveland)
Steve,
I'd love to have one of those, but it just wasn't in the budget for this project. Do you like it? Is it worth the price?
I've seen several different models, versions when I did a google search.
Thanks,
Jimmy
Posted : May 29, 2015 6:04 am
Harold
(@harold)
You shoulda used a Plumb hammer!
Posted : May 29, 2015 9:20 am
> Steve,
> Thanks,
> Jimmy
Wouldn't be to me. Build your own for $27 plus $20 for shipping.
Add some threaded rod and a mini prism pole.
http://www.ebay.com/itm/like/181460475814?lpid=82&chn=ps
Posted : May 29, 2015 9:51 am
Steve Corley
(@steve-corley)
We have the model that has 2 adjustable legs and a point to center the prism over an existing monument. The level is large and sensitive. I have considered using it to do GPS observations on Bench Marks on bridges where you don't have room to set up a tripod without blocking traffic.
Posted : May 29, 2015 11:36 am
dms330
(@dms330)
Are those magnets on that bottom photo? I can't quite tell.
Thanks.
Licensed Land Surveyor
Posted : May 30, 2015 7:48 am
cf-67
(@cf-67)
> Thanks.
Yes, magnets - try it on top of a bolt - works pretty good:-)
Posted : May 30, 2015 8:34 pm
dms330
(@dms330)
thanks Colin
Posted : June 1, 2015 9:26 pm
Don't forget the laser pointer, and a means of keeping it in adjustment. The latter is the thing that would concern me the most with that setup, store-bought or otherwise.
Posted : June 1, 2015 10:56 pm
Larry Best
(@larry-best)
0.5' aluminum triangle 0.10 thick (salvaged road sign) (2) 5/16" x 2 1/2" machine screws
Posted : June 23, 2015 4:26 pm
