Location Maps
24 Users
Location Maps can be time suckers.?ÿ
I'm not sure if Win 10 is much better at it or Autocad handles it better, but I've been having good luck with using the snipping tool.
I open the GIS and simply window out an area with the snipping tool, save it to a file available to anyone on the network and drop it into autocad as a jpg file. Super quick and easy and the file sizes are small.?ÿ
Roads, streets, other features are labeled, the same can be done in Google and unlike a few years ago they are crisp enough for a location map. Before any snip I did was too fuzzy for my tastes.?ÿ
Posted : 07/01/2022 8:50 am
(@frozennorth)
Amen, always seems like so much effort to dress up legacy data for a decent location map.
I've started using the free ArcGIS for AutoCAD plugin.?ÿ The learning curve is not too steep, and they have a lot of web map service (WMS) connections already in the can.?ÿ You can add whatever other ones you want (like, say, municipal, county, or state GIS), and pulling in a variety of layers is a nice option.
Posted : 07/01/2022 9:07 am
(@bstrand)
What is a location map??ÿ Is that the same as a vicinity map?
Posted : 07/01/2022 9:11 am
dms330
(@dms330)
@bstrand?ÿ
Yes for all practical purposes that I know about
Licensed Land Surveyor
Posted : 07/01/2022 9:13 am
(@john-putnam)
If your project is on a known projection, you can access and extract imagery and mapping in C3D directly.
Posted : 07/01/2022 9:23 am
(@wendell)
Admin
I used to have a separate CAD drawing for those. Each time I needed a new one, I'd add it to that drawing. At some point, I was able to bring several of them together. I had a pretty nice roadmap of a good chunk of Tucson.
@wendell kicking it old school.
Posted : 07/01/2022 9:32 am
 jph
(@jph)
I just make a quick map each time, tracing with a polyline over a GE image.?ÿ I only need enough to identify the site, doesn't have to be a piece of art.
I can't tell you how many plans I see with no locus map, site address, tax parcel ID, etc.?ÿ I'm looking at the plan, and can't even tell where the heck I am.
Posted : 07/01/2022 9:42 am
(@stephen-ward)
@jph I use that same method.?ÿ Use snip to grab a slice of the GIS or Google Map, save it as a png or jpg into the job, image insert in to CAD, trace, then delete the image out of my drawing to keep the size down.?ÿ Tracing the roads makes for a cleaner map and allows me to label the streets correctly.?ÿ The local addressing folks will turn a plat down in a heartbeat if the road names differ in any way from their official spelling & punctuation.?ÿ
Posted : 07/01/2022 9:51 am
(@squirl)
@jph and @stephen-ward
I do the same thing. I've had clients "complain" about the different vicinity maps (location maps) and whether they used imagery, road information of a mix of the two so I now just give them a "down and dirty" vicinity map and haven't heard a grumble since.
Make it fancy, give your polylines a larger width for major highways. ?????ÿ
Posted : 07/01/2022 10:08 am
@john-putnam?ÿ
I usually have orthos, quads, ect in a drawing. But that's not as helpful when it needs to be shrunk, moved, doubled up for a location map. The snips are tiny files, easy to drag and drop wherever needed. I doubt it's more than 5 minutes start to finish for location maps the way I've started doing them. Unless of course something complicated is necessary such as the ones for the BOC. Those take hours.?ÿ
Posted : 07/01/2022 10:20 am
(@eagle1215)
I have been drafting for just under 2 years. Our vicinity maps used to consist of a screenshot pasted into the drawing. I had troubles getting it to look good. We usually show the quarter section information unless there is a missing corner. I now draw seprate lines along the quarter lines on a separate layer and copy the quarter to create the section. I then place road labels, rr tracks, towns, etc.. I hatch the property using the boundary, again this is on its own layer. So, can I directly input gis into cad? This would be a time saver for vicinity sketches, flood plain/way, tiles, r/w, and more.
Posted : 07/01/2022 11:08 am
(@mike-marks)
I posted my position on vicinity maps years ago but maybe it's worth repeating.?ÿ
I think they're silly and redundant, take up valuable paper space, and are a requirement in most local jurisdictions because of bureaucratic fiat. State statutes where I practice make no mention of them.
Supposedly they're required "so the layman can easily determine the locus of the survey."?ÿ Record maps are highly technical documents and should not be subject to accommodation strictures for laymen.?ÿ They precisely locate points, parcels, easements, reference adjacent and historical records, the PLSS if applicable, usually require ties to SPC nowadays, etc.?ÿ If a record map cannot be positioned in its proper cadastre location by examination of its mandatory Subtitle: "Brief legal description of what is being surveyed: to include Owner's Name & Document Number and Lot, Block, Subdivision Name, Vol. & Page"?ÿ and the actual map then there's something horribly wrong with the map that a vicinity map will not fix.
But I'm a pragmatist and if a County/City insists, I'll provide a vicinity map just to keep the ball rolling.?ÿ A few local agencies get it and do not require them;?ÿ here's an elightened County's submittal requirement: "Vicinity map on first sheet if there are no street intersections shown."?ÿ They sorta realize that a vicinity map is silly but don't quite realize how silly it is.
Concerning how to do it it's a ten minute effort these days by snipping the County-wide GIS road layer, adding your PIQ as a filled block, and minor labelling.?ÿ It still irks me to do so though because I'm wasting precious paper space, incurring additional lability if I screw it up and my map might turn into a two-pager and incur an addtional $200 mapcheck fee.
Posted : 07/01/2022 12:36 pm
 jph
(@jph)
@mike-marks?ÿ
I get what you're saying, but it's such a simple thing to do.?ÿ My only problem is when I've had a plan kicked back because I didn't add a locus map when the property was at the intersection of two streets, so it was abundantly obvious where it is.
Posted : 07/01/2022 12:56 pm
(@fairbanksls)
The added liability of a vicinity map hasn't kept me up at night for a very long time.?ÿ?ÿ
Posted : 07/01/2022 1:03 pm
Page 1 / 3
