I just don't believe it needed to be commented on
24 Users
(@richard-germiller)
Prominent Member Registered
Now I've been doing this for almost 50 years in 4 states across the country and this has to be the most ridiculous comment from a City review. Mind you I've seen some pretty nitpicky comments.
"Quotation mark at the beginning of "Replat" is going in the wrong direction. Please adjust accordingly.
I thought they were just to ensure that the project meets the minimum zoning and other standards, not what freaking font you use.?ÿ
Posted : 23/05/2023 2:50 pm
Illustrious Member Registered
Please show me, in your code, where it says I need to use your specific font...
Posted : 23/05/2023 3:10 pm
(@jmedlock)
Active Member Registered
Wow… I think I’m literally speechless.  I think a perfect response to that is, “Please fill your potholes in your roads so I don’t make this huge mistake again.”
Posted : 23/05/2023 3:23 pm
KMA would be an appropriate response.  Put it in quotes, one single one double.  Let them struggle with what KMA means.
That fool reviewer needs to have his wings clipped promptly.
Funny situation from recently.  I was reviewing a proposed subdivision plat on behalf of the City.  There were a few substantive problems.  They would need to fix those concerns no matter what.  It was obvious they had gone online to determine specific names of officials needing to sign the final plat.  That must have been months ago as the Mayor's name was incorrect.  It WAS the mayor's name when they looked, but, he is no longer the mayor.  While pointing that out, I mentioned there was a problem with one other name on their list.  I also mentioned that it was not their fault that they had it wrong.  The website listing this woman's name had it misspelled, and still has it listed incorrectly.
Say her last name was Silley.  The erroneous listing says it is Sillley.  Three of the same consonant in a row.
Your reviewer would have surely demanded that hard-to-catch typo be corrected.
Posted : 23/05/2023 4:38 pm
(@flga-2-2-2-2-2-2-2-2)
I found out the hard way (as usual) about these kind of people. Sometimes they can cause serious problems prior to recording documents, especially plats and replats. As hard as it may be just appease these types. It's not worth a pissin' match back and forth about superfluous crap that could bite you in the ass.
Just smile at them, thank them for constructive scrutiny, and fix it the way they want it.
Posted : 23/05/2023 5:00 pm
(@hpalmer)
Honorable Member Registered
Guess the quotation marks going wrong way has me beat.
And I thought reviewer requesting plural possessive was a bit much.
Plat info could be wrong but the grammar is perfect.
Posted : 23/05/2023 6:10 pm
(@lukenz)
Perhaps they know so little about the surveying that all they understand is the grammar so they feel they have to add 'value' where they can.
Posted : 24/05/2023 2:56 am
Famed Member Customer
@hpalmer On a related note... I see a LOT of plats that are approaching void on their face for gross deficiencies, yet the math is impeccable...
Posted : 24/05/2023 3:51 am
(@squirl)
Noble Member Registered
WOW!!
I thought I was picky when I was reviewing ROW maps for the Toll Road a few years ago. This is WAY worse!
Posted : 24/05/2023 4:10 am
(@aliquot)
I would share all of your anger if this was actually preventing a plat from being approved, but is it? I would rather the reviewer point out minor errors than quietly let them by
Posted : 24/05/2023 4:51 am
I have the exact same issue. The computer drafting fonts all do that same thing EXIBIT "A", the quotation marks will be sweeping to the left. Go ahead change them,,,,,,,I dare you.
It's that way for roman, simplex and as far as I know all the fonts. Never had anyone complain about it. I figured they all understood how that works. To fix it you'd have to remove the marks, otherwise you'd be spending lots of time creating lil text marks and rotating or mirroring them. Hardly worth the effort.  Actually, I decided to check since I'm in a drawing. You might try changing to a text that keeps them straight. Seems there are a number of them. But still; that's world class editing going on.
Posted : 24/05/2023 5:41 am
(@john-putnam)
Noble Member Customer
Funny, I don't recall typewriters having 2 quotation mark keys.
Reviewers seem to have to bleed on your work to prove their value.  I have found it a best practice to always give the reviewer something obvious to mark up.  If you don't, they are going to start searching.
Posted : 24/05/2023 6:00 am
(@ontarget1)
Estimable Member Registered
I've had them comment on font types and line styles. We are required to underline existing road names and other items and I just use the underline function but then I get that has has to be a dashed underline. I've asked them to show me the style regs in the ordinance and they obviously can't. One told me my stamp didn't copy well. I told him to check the ink in the printer cause it was fine here.
Then the next guy gets one through using 0.03 sized fonts that nobody can read, but that's OK. Sometimes I just make the changes to avoid argument, other times I tell them to pound sand if they can't show me in their ordinance where the change is required. It's all bs to me.
Worst part is that the Towns hiring the reviewers believe they are some type of deity and that everything they want has got to be done. I wish there was some place a guy could take this stuff to and have them spanked somehow.
@mightymoe
One of my compadres looked and there's a way through the character map to fix it, I have to find which of the many area of the plat they're referring to, the title is one font and this particular city has you place the name of the plat in the dedication statement which are different fonts.
Posted : 24/05/2023 6:05 am
All, thanks for letting me vent.
I have given it a little thought and realized that, in my experience with these kinds of things, my plat is so perfectly correct insofar as this one particular reviewer is concerned, that they had to REALLY look for something to comment on, no matter how ridiculous it sounds, I may just send them a nice note (cc'ing their supervisor) thanking them for the wonderful compliment they have given me on my skills.
Posted : 24/05/2023 6:11 am
Page 1 / 3
Share:
