How wet is too wet to survey
24 Users
eapls2708
(@eapls2708)
Early in my career in the midwest, the truck for the crew I was on had a 0.2'x0.2' square drawn with permanent marker on the windshield just below the rearview.?ÿ The rule was if 3 drops hit within the square within a minute, it was raining to much to work.?ÿ If it was snow, as long as it wasn't warm enough to melt on the fieldbook pages and we could see a target, we were good to go.
I moved to the Puget Sound area in 1990.?ÿ Our instruments had an extra wax seal applied over all rubber seals and that kept the moisture out really well.?ÿ We didn't shut down for any amount of rain unless it was also windy enough to blow the rain sideways so that moisture got in through the seams on the bottom of the instrument and if we didn't have any work that could be done without an instrument.?ÿ First time it snowed while I was working there, we kept on working until regular quitting time.?ÿ By that time there was about 4" accumulated on the ground.?ÿ The boss and all coworkers still in the office acted as if I was crazy for working in the snow.?ÿ Surveyors who had come up in the Northwet, or had worked there for more than a couple years always made a beeline for the barn at the first sign of flakes.
I don't mind working in cold, snow, or a light to moderate rain.?ÿ Hate working in rain when it's windy.?ÿ Can't handle working in 90 degrees or higher for more than a couple hours.?ÿ I pack it in for heat.
Posted : March 14, 2019 11:26 pm
jimcox
(@jimcox)
I started my career on our West Coast.
Its climate is a little like your Pacific North West - ie Sub Tropical rain forest.
Back then, we would get paid extra for "wet time" - defined as starting when we felt the first drop of water run down between the shoulder blades
Posted : March 14, 2019 11:31 pm
lmbrls
(@lmbrls)
Somewhere between waist and chest deep. That is for swamp surveys.
Posted : March 15, 2019 5:25 am
@His most holiest of Bovines and God of methane: to answer your op:?ÿ ?ÿWhen it's raining.
Rain in FL usually happens in the afternoon. The easterly winds from the Gulf of Mexico collide with the Southeasterly winds from the Atlantic and create horrendous thunderstorms over central Florida. If a front is visually approaching and that usually means visible at 10 miles or so we pack it in. Lightning can strike miles ahead of an approaching storm. When I was employed in South Florida we had a party chief killed and a rodman severely injured when lightning struck a 200ƒ?? chain they were at each end of. The party chief was killed instantly. The rodman suffered third degree burns on his legs and feet, the lightning ripped his jeans in half and blew off both his shoes.
After that depressing episode Iƒ??ve instructed all my crews when they see approaching black clouds get in the truck until the thing blows over which is usually 30-45 min or so. Mother Nature is sneaky so treat her with respect. You might live longer. ?????ÿ
Posted : March 15, 2019 7:05 am
Electricity in the air is normally connected to our storms that fire up in the high plains in the summer. We are lucky that we have big sky's and can keep a look out for them. It's rare that we get rain without thunder. Rain fine, thunder, start looking to get out.
I've gotten a light shock before when picking up the base radio antenna, you know it was passed time when that happens.
Posted : March 15, 2019 7:58 am
john-putnam
(@john-putnam)
That is why you can turn the touch screen off.
Posted : March 15, 2019 5:31 pm
Norman_Oklahoma
Touch screen works well enough. Sarge's 2nd sentence is probably the operative one.
Posted : March 15, 2019 6:23 pm
P.L.Parsons
(@plparsons)
I work in South Alabama, gets more rain than Seattle, so working in the rain is just SOP. I use a pop up tent, over the instrument, with the legs nailed down. The Mesa has it's own umbrella, notched to fit through the prism rod, found out the hard way no, in spite of the marketing, they are not waterproof. Ponchos and rubber boots, and rock on.?ÿ
The no go in rain is the GPS unit, while I use an RPN connection to the CORS network, is too expensive to risk getting wet.?ÿ
Posted : March 20, 2019 8:57 pm
Posted by: P.L.Parsons
I work in South Alabama, gets more rain than Seattle, so working in the rain is just SOP..
Back in the '70s I did a load of telecommunications work within a triangle drawn from Houston to Baton Rouge to Shreveport.?ÿ
It rained.?ÿ A lot.?ÿ I grew webbed feet while I was down there.?ÿ I've never seen anywhere else on the planet that a truck could get terminally stuck so quick in that gumbo soil.?ÿ We once had a truck stuck in the mud so bad the wrecker services wouldn't touch it.?ÿ We finally found an outfit named "Thibodaux Bros. Recovery Service" that ?ÿgot it out with a D6 and a dragline on steel tracks.?ÿ My boss told me I was going to have to drive that same truck for 10 years to offset the cost of getting it out of the mud. 😉
Posted : March 20, 2019 10:30 pm
charles-l-dowdell
(@charles-l-dowdell)
When I worked for a firm in Lake Oswego, if you didn't work in the rain, you didn't work. Put on your rain suit, use "Rite in the Rain" field books and get going. The day before Thanksgiving 1989, completly lost the vernier in the T-16 due to moisture buildup in the instrument. Could see the minute portion, but the degrees portion was not even a ghosted outline. After a four day weekend and stting in the instrument room, it was back to normal.
Posted : March 20, 2019 11:16 pm
charles-l-dowdell
In 1959 when I worked for a firm in Casper, Wyoming after moving there, we were working out in the Gas Hills surveying an open pit uranium mine. One day it clouded up and the sky got dark, but no rain, thunder or lightning. We were running grid lines tying into the walls and berms of an adjacent pit that would be cut out by the mine operations of the pit we were surveying. The transit was set up near the edge of the slope and I was giving the rodman line to set nails at the toe of slope and the edge of the berm at the next level. below. When giving him hand signals for his line, my fingernails would buzz, with a kind of zip-zip sound. I called the party chief over and had him listen to the sound, so he said we'd better get out of there. We tossed a rope down to the rodman and pulled him back up the slope, put everything in the pickup and headed for the trailer we stayed in. The party chief said he'd never heard anything like the zip-zip coming off the end of my fingers.
Posted : March 20, 2019 11:42 pm
