Hiper Lite plus on VRS
antcrook
(@antcrook)
Hi,
I am trying to get my Hiperlite plus to work on a VRS us a FC-2500 with Topsurv. I can get a far actually logging onto the VRS and he screen on the FC-2500 says that the data is being received, but when I go to the status screen the solution stays on Autonomous and never goes to Float or Fixed, also the radio is no showing up as 100%, it is blank. Any Thoughts? I do have the unlimited range on the unit.
Thanks
Anthony
Posted : August 2, 2013 11:55 pm
blemoine
(@blemoine)
Anthony,
Check the Mount Point you are using,
Check the expected format of the RTK Correction for your RTK Rover equipmnet. Prob need to select the RTK Rover format to RTCM/RTCM v3.1. Make sure the Mount Point you're selecting is outputting RTCM v3. Or you can select CMR/CMR+ mount point, just my 2cents.
-BbB B-)
Posted : August 3, 2013 12:23 am
antcrook
(@antcrook)
I tried both the CMR/CMR+ and RTCM3 mount points. Both times the screen pop ups and says it has successfully connected and is receiving the specified correction.
Posted : August 3, 2013 10:21 am
The Pseudo Ranger
(@the-pseudo-ranger)
I've had the same problem with a Hiper Pro on the Florida RTN. I get connected, 100% link, good sats, but it stays in Autonomous. This is with TDS.
If your RTN has the options, try RTCM2.3, and/or try a single baseline solution to the nearest station. That will often solve my problem.
Posted : August 3, 2013 10:50 am
antcrook
(@antcrook)
My radio link is blank, even though it claims it is on the network.
Posted : August 3, 2013 10:59 am
antcrook
(@antcrook)
I got it to work. Instead of auto selecting the port to which the TCP correction are sent I manually forced it to use Serial Port C. That seemed to work.
Posted : August 3, 2013 5:30 pm
