Help!! Rinex into TBC
Yazeed
(@yazeed)
Hello guys,
I have that friend who asked me to do him a favor; to process base lines for him. he uses STONIX equipment but he does not has any software to process base lines.
as I have TBC (Trimble Business Center) I asked him to send me RINEX format.
but when I imported them, I received an error message :
any Ideas how to fix this?
BTW: I have chosen the correct antenna type and receiver type from the list in the import dialog box.
thanks in advance
Yazeed
Posted : January 9, 2014 11:18 am
Alan Chyko
(@alan-chyko)
Yazeed,
What version of TBC are you running? I have run into this error myself, but I don't really recall if there is a fix, if this was a known issue for a while, etc.
IIRC, in my experience as long as the correct receiver/antenna shows up in the observation properties, it will still process fine.
I will take a look at some of my more recent projects to see if it still happens.
Posted : January 9, 2014 11:31 am
Can you post the header portion of your rinex file? I have a feeling that something is possibly in the wrong column?
Posted : January 9, 2014 11:56 am
Yazeed
(@yazeed)
Hi Alan,
the version is 2.40
thank you
Posted : January 9, 2014 1:05 pm
Yazeed
(@yazeed)
here is the header of the file:
2.10 OBSERVATION DATA M (MIXED) RINEX VERSION / TYPE
GpsAssistant (20120221) PGM / RUN BY / DATE
A.1 MARKER NAME
MARKER NUMBER
OBSERVER / AGENCY
STNS93333017 Stonex S9 S9-130626V1.06 REC # / TYPE / VERS
0 STXS9BS604 ANT # / TYPE
6136490.5987 1674606.4608 -471455.3527 APPROX POSITION XYZ
1.6101 0.0000 0.0000 ANTENNA: DELTA H/E/N
*** Height of bottom surface of antenna above marker. COMMENT
1 1 WAVELENGTH FACT L1/2
5 C1 L1 L2 P2 D1 # / TYPES OF OBSERV
5.0000 INTERVAL
2014 01 09 15 11 20.0000000 TIME OF FIRST OBS
2014 01 09 15 24 35.0000000 TIME OF LAST OBS
16 LEAP SECONDS
END OF HEADER
14 1 9 15 11 20.0000000 0 14R02R18R03R13R14R15R17G17G04G20G08G07
thank you
Posted : January 9, 2014 1:06 pm
Unfortunately, that does not show how it really is. In the past, on other boards, I have used
for to preserve formatting, but on this board that doesn't work. Feel free to email it to me (the whole file) and I will look at it.
Posted : January 9, 2014 1:58 pm
