Which is correct;
1. Thence North along x line at 300.00 feet pass a 5/8 inch iron rod found at .... and continuing for a total distance of 600.00 feet to....
2. Thence North along x line at 300.00 feet past a 5/8 inch iron rod found at .... and continuing for a total distance of 600.00 feet to....
passing
:good:
More of a structural question.
3.) thence N xx°xx'xx" E and passing through a 5/8" iron rod @ 300.00 feet, and passing through a 1/2" rebar @ 402.25 feet, but in all a total distance of 600.00 feet to a big dead skunk in a rock pile, on the north line of said NE1/4-SE1/4...;
thence...
I like your question. It means you are considering....
We need more of that.
JMHO, but...
1. Passing over. We all know what you mean by making a passing call, but to be pedantic you can pass to the side of something.
2. I put the overall distance first...just because.
Thence North along x line 600.00 feet; passing over a bent 5/8" goat stake at 300.00 feet.
I like to "Pass through" them. If you pass over them.... you might get high!
> Which is correct;
None of the above.
3. ...thence North along said line 300 ft; thence East 300 ft; thence South 300 ft; thence West 300 ft to POB.
Show the "found monument" on your recorded survey map. Don't include it in a property description. This is not rocket science and we are not solving world peace. We are doing our best to perpetuate and maintain a unique description for each and every parcel of land.
Pass is something you wave at or play football with. Past is something you went by or already did. Neither word belong in a property description IMHO.
> Which is correct;
If you are going beyond it, you've passed it. Why not use beyond?
If you pass through them you may knock them 0.04' off line 😀
In Texas only the property description normally gets filed with the deed, the plat ends up in a desk somewhere.
"passed" or "passing" denotes physical location. "past" denotes time.
I agree with Robert, but that could be a regional thing. Surveys are not filed here only the deed. It's best to put as much information as you can in the description including a reference to your own survey and any old deeds and filed plans/plats. That's the way it works 'round here at least.
Passed? 🙂
Not necessarily when past is used as a preposition.
"I got that creepy feeling when I drove past the cemetery"
"The adult bookstore is on Scuzball Street, 200 feet past the pawn shop"
Gramma's Nosey Question
That is just plain wrong and unprofessional.
Personally, I want people to know what in the heck I did on my survey and why I decided to do what I did. It is my decision, it is my liability, and I will back it up. This does not pertain to some guy wanting to put a fence up tomorrow, it pertains more to the 3rd owner about 15 or 30 yrs from now trying to put that fence up long after I'm pushing daisies.
For the life of me I will never understand why any state does not require recordation of a survey if a licensed professional sets their monument in the ground. And for the other life of me I don't understand why any professional surveyor would not want their decisions in the record book for others to know what they were thinking at the time.
Oh that's right, that time has passed us all. I like looking at the past, and hope others will follow my footsteps.
I don't understand the point of omitting the monument calls from a description.
I also think you misunderstood the example. We're talking about a straight line here, with a monument online between the end points.
Thence along xxxxx North 300.00 feet to a 5/8 inch iron rod; thence continuing along xxxxx North 300.00 feet to a ....
please don't try to reinvent common language, keep it dead simple.
:good:
Most of the time, when you quote the drawing being an attachment to the property description, the drawing will be recorded along with the deed or other document the description is included.
It can also be helpful for the drawing to be on the same size of paper as you description.
:good: that's how I'd do it.
