Trimble Business Center — Know your data is right. Start free trial.
GPS third order accuracy
12 Users
john-giles
(@john-giles)
How long does it that the average GPS unit to achieve third order accuracy? If you are on open ground, and need to collect a shot say every 5ft-10ft how quickly could you get each shot.
Or would it be quicker to set up a network onsite and use a total station? This would be to locate cemetery headstones.
I currently do not have GPS. Well I have it in my vehicle but you know I can't drive to EVERY corner.:-) When I get GPS I am going to change my company name to Giles Professional Surveying.
Posted : April 19, 2015 10:30 am
Deed Staker
(@deed-staker)
As fast as you can walk if you have it set to take a shot every 'x' number of feet.
Posted : April 19, 2015 10:51 am
IF you're talking about 1:5000, not very long at all. Just about as long as it takes to stand the rover up and key-in a description.
ps - A couple of my data collectors actually have cameras in them, for whatever reason. I never thought they would be any good for anything until we actually did a cemetery survey like you've described. Being able to correlate a pic with a shot was really cool...(after we finally figured out how to do it!)
I have a close friend that started a company, Great Plains Surveying, almost twenty years ago. The "GPS" was the farthest thing from his mind at the time, purely coincidental.
Norman_Oklahoma
> How long does it that the average GPS unit to achieve third order accuracy?.....
It's impossible to say. Obsolete standards like "3rd order" are expressed in terms of traverse closures, which of course you don't have with RTK.
But lets say you were going to traverse around a square 100 acre parcel, with traverse points every 500 feet. You'd have ~16 traverse legs and, if you achieved 1:5000, 1.7 feet of misclosure, or about 0.1' per traverse leg. 0.1 foot point positioning precision can be achieved with RTK virtually instantaneously, once initialization has been gained.
A a 4 legged traverse around a typical urban 50'x 100' building lot, 1:5000, would have a misclosure of .06 feet, an error of .015 feet per traverse leg. You would find that very difficult to achieve that 0.015 point positioning precision no matter how long you occupy with RTK.
Posted : April 19, 2015 11:21 am
or a 3 foot bust on one single point and the rest are better than .02'
traverse closures are pure fallacy without some sort of cross check....
Posted : April 19, 2015 11:34 am
A very good point about the size of the project.
Another minor point, though. The RTK errors per point don't accumulate the way they do in a traverse. So for the small lot if one has a 95% probability of being within 0.06, they all do. And they all have some chance of a bust that is undetectable due to lack of redundancy.
Posted : April 19, 2015 11:40 am
john-giles
(@john-giles)
I misread the paragraph. This is what how it actually reads.
The contractor shall use traditional surveying work (i.e. Total station) shall be in third order accuracy. Survey accuracy using GPS surveying methodology (i.e. Real Time Kinematic (RTK) will be less than one inch in both horizontal and vertical accuracy
But there has to be something to compare GPS to for accuracy. right?
I guess I'm looking for a comparison. Which would be quicker. I would need to get a Data Collector with a camera too.
Posted : April 19, 2015 11:46 am
Norman_Oklahoma
> A minor point, though. The RTK errors per point don't accumulate the way they do in a traverse. So for the small lot if one has a 95% probability of being within 0.06, they all do. And they all have some chance of a bust that is undetectable due to lack of redundancy.
That was just my way of translating loop closure based accuracy standards to point positioning based, and to show why it really has no meaning.
Posted : April 19, 2015 12:14 pm
Norman_Oklahoma
A total station traverse that misclosed by 1.7' in 8000' very likely would be the product of a bust somewhere along the way. But a transit and tape survey of the same route would have to be performed with out gross error to achieve that closure. Just one more reason that "third order accuracy" standards are to be considered absurdly obsolete.
Posted : April 19, 2015 12:21 pm
Norman_Oklahoma
Point for point there probably wouldn't be a lot of difference. The savings in time with GPS comes with the reduced number of control points you need to establish. The negative part comes with just not being able to get points in all situations due to obstructions, etc. If your putting in points over a broad but open area GPS is the clear winner. If you are putting in a lot of points in a smallish area then the TS is the tool of choice.
Also, getting verticals to 0.08' (1 inch) with GPS is something of a challenge. Generally assume that your vertical point positioning precision will be half that of the horizontal. ie/when you are getting vertical to 0.08', you will be getting horizontals to 0.04'.
Point positioning precision with RTK is estimated through least squares analysis of the vectors, known parameters of the receiver, and the available satellite constellation. An on-the-fly number is generally available to the user at the data collector. Of course that is an estimate subject to comparison to positions determined by more precise methods.
Posted : April 19, 2015 12:41 pm
Try Trimble Business Center free for 21 days. Get started.
Harold
(@harold)
I have done a few cemeteries with my total station and with GPS. Using GPS with my nearby base station, I remained "fixed" for the duration of the work.
All of my location shots were on the ground in the front center of the tombstone with my GPS pole touching the stone. That seemed to be the most consistent way of getting a location considering the variety of sizes and shapes of the stones. Most of the tombstones were granite markers varying in size from about 18 inches to about five feet across. The depth measured from about four inches to eight inches thick. Some bases were up to about two feet across. I located ancillary stonework or depression data as needed. Point descriptors included stone or base dimensions, last name and the photograph number of a digital camera. We used the camera to take a photo of the inscription. Geotagging the stone meant detaching the field controller unit from the pole and following menus to the picture tool. Two people running GPS (one on the pole and the other running the unit collecting data and taking the picture) may could have sped up the process somewhat. But one person on GPS and a second running a digital camera ended up being the most productive method for my map. If the geotagged position will be used in a GIS map, then it would be worth the field time.
Since I did not locate a "point" in front of the tombstone, I did not worry about the accuracy of my point too much. When we placed the GPS pole on the ground at the estimated center, I leveled the bipod. I keyed in the point descriptor first, then hit the side shot button. Long bases were located on both ends. As long as I am "fixed" my positional accuracy should be around .05 feet, which (IMO) is plenty accurate for a big granite marker. I am not sure why your specifications were written to contain the words "third order accuracy" when today's location measurements should be specified by a more relevant standard. Well, robot location methods would be relevant. Maybe they just meant "locate it with a few inches or so."B-)
I am interested in the methods others are using.
Posted : April 19, 2015 1:06 pm
john-giles
(@john-giles)
About how many could you do in an hour start to finish?
I am thinking it's going to take at least 30 minutes per headstone. field/office combined.
Here is the breakdown of what they want for each one.
lat lon elev. on each headstone (I can do either way total station or GPS or combination)
front and back pics that have to be cropped so only the headstone is showing. Plus lighting/shading has to be used on each headstone to ensure each pic looks like the next pic and to make sure they can be easily read. 5mp pics at .5 mb each pic. (I figured I would have to make something lighted to put over each headstone to take a consistent shot and cut down on pic edit time.)
A drawing has to be completed showing all headstone locations. Info on each headstone has to be in excel and a drawing has to be created that brings up each headstone pic with location when you click on it.
That's the more or less of it.
I'm thinking 30 minutes each once we get everything running smoothly. I might be able to cut that by as much as half if I can live feed the data straight to the office person to cut down or eliminate raw data errors. I figure a field crew can do 6 an hour and the office person could be drawing and plugging in data at the same time.
What do you guys think? I'm just looking right now I don't even know if I'm going to be able to bid on it because it's such a big project. But it would be nice and I would have to team up with some other companies in order to do it within a reasonable timeframe.
Posted : April 19, 2015 2:25 pm
john-giles
(@john-giles)
> Some kind of hood made of back material and a low light source on the camera could yield similar photos from all angles and maybe make manual cropping moot as possibly only the headstone would show up in the pic.
Thats what I was thinking too. Some kind of canopy/tent with a black back drop that could cover 1-2 at a time and keep the light consistent where only minor adjustments in photoshop might be needed for a minimal number.
I would love to bid/get the job. I want to at least work up a bid even if I don't bid just to see how close I end up. It's a real big job. 86 cemeteries and I'm a real small company but am in talks with an engineering firm right now to maybe team up.
Posted : April 19, 2015 3:46 pm
"Survey accuracy using GPS surveying methodology (i.e. Real Time Kinematic (RTK) will be less than one inch in both horizontal and vertical accuracy"
I'm not entirely sure that vertical accuracy is achievable without repeated observations...
Posted : April 19, 2015 6:01 pm
" I want to at least work up a bid even if I don't bid just to see how close I end up."
This work is based on fee only? - no qualifications required?
Posted : April 19, 2015 6:04 pm
Ancient Kudurru stone artifact related to land surveying history.
john-giles
(@john-giles)
It's a government contract so even if I don't bid I will know who won the bid and for how much.
I am more than qualified to locate cemetery headstones within the the boundary of a cemetery if that is what you are asking.
Posted : April 19, 2015 6:25 pm
john-giles
(@john-giles)
It is with a total station.
I picture the project as being primarily total station. GPS to set up a control network to work from but most of the actual work will be with the total station. Given the accuracy required, it's not looking like GPS will do the job.
Posted : April 19, 2015 6:36 pm
Norman_Oklahoma
If you follow a procedure which proves to produce coordinates to a given accuracy upon testing it is reasonable to assert that points established using similar procedures will be of comparable accuracy. You don't have to test every point.
Posted : April 19, 2015 8:02 pm
base9geodesy
(@base9geodesy)
Third-Order - Do you mean horizontal/geometric or vertical or both? The order of accuracy terms (e.g. First-, Second- and Third-Order) are defined national standards not just a proportional part accuracy statement (e.g. 1:10,000 or 2 mm x Sqrt K). In addition to the accuracy statement using these terms implies that you have followed a strict set of procedures that if replicated correctly will ensure that your results can be repeated at the 95% confidence level. As Norman Oklahoma so rightly pointed out GPS does not really work well with proportional part statements - this is why NGS moved away from them for the NAD 83 (2011) national adjustment. If you take into account the distance between points and you have clean data you can certainly achieve what would have been Third-Order horizontal with no trouble - not so with vertical. There are no existing guidelines that will allow you to achieve Third-Order (2 mm x Sqrt K) orthometric heights between points 95%.
Posted : April 19, 2015 8:59 pm
Harold
(@harold)
You are going to spend some time on the Excel part. That sounds like a tombstone transcription project.
The type and purpose of the data I collected was in a much smaller scale than yours, and not nearly as in-depth as yours. Offhand, I think you have estimated the time about right. Once you get a system and procedure that works, you will gain speed with practice.
86 cemeteries! Good job! Keep us posted.
Posted : April 19, 2015 9:30 pm
Trimble Business Center — From point cloud to plan sheet. Start free trial.
