"feet" in CAD
9 Users
half-bubble
(@half-bubble)
Can't seem to find the menu item for which sort of feet I'm using in
Carlson 2004/2006. I get a choice of feet or meters but no mention of WHICH kind of feet. US survey feet ? or has CAD always used International feet regardless and I never noticed before now?
Posted : May 16, 2012 12:34 pm
A foot by any other name would smell just as bad.....
The only time there is a difference, between International Foot and US Survey Foot, is when you convert to/from meters.
You might try doing a conversion in the software and seeing what answer it gives you.
Dugger
Edit-Get yourself the latest version of Corpscon and do all of your converting there, you can't go wrong then....
[sarcasm]Well, things can still go wrong, you just have to work harder at it>>>Going wrong.....:snarky: [/sarcasm]
Posted : May 16, 2012 12:44 pm
I dunno Half, I have all of my CAD drawings set to Parsecs.
Posted : May 16, 2012 12:45 pm
Chan GePlease
(@chan-geplease)
Isn't there a song they always play at wedding receptions about feet?
...ya put your left foot in.. ya pull your left foot out... ya put your right foot in and shake it all about....
But seriously, each state has their specific "feet" standard. Don't know WA, but for some reason AZ is Int. I think the only time you'll see any significant differences is when you try and apply them to SPC. Then you'll find the shift you're looking for and/or trying to avoid.
Don't know about your software, but a couple OPUS checks will tell you the answer.
PS - keep your total station scale factor at 1.0000000000000 or you will ruin somebodies day... GPS has it's own issues.
... and then you shake it all about...;-)
Posted : May 16, 2012 12:48 pm
That would be the HOKEY POKEY
B-)
Posted : May 16, 2012 1:40 pm
Kris Morgan
(@kris-morgan)
type "units".
Posted : May 16, 2012 1:56 pm
half-bubble
(@half-bubble)
Big ol' difference when you are scaling state plane coordinates from the origin ... hence my concern. I'm scaling something that should fit and doesn't ... leads me to wonder WHICH foot Carlson means ... when I type "units" it gives me various choices, one of which is "feet" but it doesn't say WHICH feet.
Posted : May 16, 2012 2:39 pm
RoadBurner
(@roadburner)
Radar has it. In CAD, a drawing unit is a drawing unit. Try using your calculator to convert meters to feet and see which one Carlson is using. Carlson 2012 has the option for using either foot.
Posted : May 16, 2012 2:45 pm
What if that's what it really is all about?
Posted : May 16, 2012 2:55 pm
A scale factor has nothing to do with a conversion from meters to/from feet.
If you have a State Plane Coordinate in US Survey Foot and apply a scale factor of 0.99999456544345 and use 0,0,0 as the point of origin, your point will move about 40 feet +/- to it's ground location. The same as it would if you used meters or International foot.....
Posted : May 16, 2012 3:00 pm
ladd-nelson
(@ladd-nelson)
Check Settings -- Drawing Setup. You should be able to specify to Carlson to use US Feet.
Be aware that AutoCAD customary "Feet" units via the INSUNITSDEFSOURCE and INSUNITSDEFTARGET are (I believe) specified to be International Feet.
Ladd Nelson
Posted : May 16, 2012 3:17 pm
half-bubble
(@half-bubble)
well, that's what I'm wondering. Carlson support seems to think theirs is hardwired to US survey feet ...
Radar -- not concerned about meters to feet. I have feet (unknown) and feet (usft) that are not matching...
Posted : May 16, 2012 3:35 pm
Are you saying that you have 2 points with a published distance between them and you have a GPS's position, of what you believe to be the same 2 points, and they don't match?
If you inverse between 2 points, 5000' a part and you use coordinates that are reported to be in US Survey Foot and do the same thing with coordinates that reported to be in International foot, I think you will have to display a lot of decimal places before you will see a difference.....
I might be wrong though..:-S
Posted : May 16, 2012 3:48 pm
half-bubble
(@half-bubble)
not gonna matter in 5000' unless you are monitoring something from that far away.
(matters in scaling those shiny state plane coordinates though.)
I guess CAD is basically unitless until you start printing stuff, so the parsecs you put in are the parsecs you get out, until you use some kinda utility that assumes some kind of units for input...
Anyhow, when I scaled some TenThousandLand stuff to state plane it fell just short enough that it could be the difference between the two kinds of feet in this particular place, so now I gotta figure out where in the data chain that is happening. Hence the original question.
Posted : May 16, 2012 7:38 pm
I see, says the blind man.....
You're scaling from ground to grid and seeing a difference in what you have and what you were told.....
There are many factors that play into this, besides just the difference in US Survey Foot and International Foot.
Is ALL the metadata correct? What is the origin of both sets of coords?
Posted : May 16, 2012 7:57 pm
half-bubble
(@half-bubble)
ok, indeed they are.
I checked my environment variables on Carlson on ye olde work laptop:
INSUNITS 0
INSUNITSDEFSOURCE 1
INSUNITSDEFTARGET 1
So, searching the web for "INSUNITSDEFSOURCE survey feet", found a good explanation at http://www.theswamp.org/index.php?topic=12351.30
So, seems like a scaling issue where the utility I'm using to scale-rotate-move is assuming survey feet and my CAD is assuming international feet.
Or, might just be that missing tenth again.
Posted : May 16, 2012 8:00 pm
half-bubble
(@half-bubble)
The coordinates were new and shiny and the two guys in the white van said they were fresh yesterday morning!
Posted : May 16, 2012 8:01 pm
