Carlson DC
jph
 jph
(@jph)
Does the Carlson DC software use the same fld file, so that you can pull-down and pick field code descriptions?
Posted : February 28, 2013 10:54 am
Mark Indzeris
(@mark-indzeris)
Sort of. You need to convert or export an fcl file using the field to finish tools/ options in the desktop software.
Posted : February 28, 2013 11:39 am
ladd-nelson
(@ladd-nelson)
This is certainly one option. Newer builds of SurvCE (circa 2.5x and later) allow SurvCE to directly import the desktop FLD file format through the following steps:
File tab -- Feature Code List -- Special Codes -- Settings (button next to Green Check) to launch the following Settings dialog box:
Once enabled, "Green Check" back to the Code List dialog box, tap "Load" and change the File Type to FLD:
A compact edition of the FLD (the FCL) file will be created and subsequently used by SurvCE. I hope this helps.
Posted : February 28, 2013 5:20 pm
