Calculated or As Set, Which Do You Use On Your Plat?
22 Users
(@aliquot)
@bstrand
It sounds like you are rejecting monuments because of the math??ÿ
Posted : February 17, 2021 8:35 pm
(@bstrand)
@aliquot?ÿ Not just because of math.?ÿ Like with any survey there are several things to look at, math being one of them.
Posted : February 17, 2021 8:51 pm
(@murphy)
@holy-cow
I still don't understand why you can't simply add, "Being the same parcel as described in Deed Book 2 at Page 5", after an updated description to clear up title issues.?ÿ?ÿ
In NC, we are required to sign and seal our deed descriptions.?ÿ Even if we weren't, I would raise Cain if someone tried to edit mine.?ÿ Do you know the reasoning behind the removal of bounds calls from deed description in your area??ÿ?ÿ
Posted : February 18, 2021 2:54 am
(@murphy)
It would appear that it is our assumptions of the layperson's ability to understand our plat that dictates whether we show our measurements or whether we tell harmless white lies.
I spend a great deal of my time communicating with my clients. Clients may not understand plat data, but they recognize when someone cares about them and makes an effort to educate them. I can't think of any residential boundary that I've surveyed in the last few years where I didn't warn the client that my measurements would not match exactly with their deed and that there is a good chance my survey will show that they own less acreage than what is mentioned in their deed (slope distances were used in many older deed description in the mountains of NC).
Concerning boundary calls that don't match older descriptions, I don't have any problems with title companies. They seem to understand the meaning of, ƒ??Being the same parcel as described in a deed to Jones from Smith in Blank County Register of Deeds in Deed Book 12 at Page 345ƒ?. We are required to stamp our deed descriptions in NC so it would be considered fraud and surveying without a license if anyone edited them. If I lived in an area where the local norm was to omit bounds calls from my description, I would probably hold similar views about deed descriptions as Holy Cow. I'd like to know the origin of such an odd local custom.
I recognize the pedantry in a discussion about hundredths of a foot when in most states you could meet minimum standards on a large-tract survey with an EOC of many tenths and then set irons without any traverse adjustments. I don't view holding CPs as bad or indicative of poor professional judgment. I just find that it is more useful (certainly not necessary) to have actual measurements when I am assigning value to the evidence.
Another thought experiment that I perform occasionally is to imagine that I have been compelled to help an attorney sow doubt into the testimony of another PLS. I think I could do this more easily to a surveyor who holds record measurements than one who holds actual measurement.
Posted : February 18, 2021 5:07 am
 jph
(@jph)
@murphy
The problem is that you're not always on hand to explain your survey.?ÿ A survey plan shouldn't need additional explanation, it should stand on its own.
That's pure assumption and opinion.
Posted : February 18, 2021 5:25 am
(@flga-2-2-2-2-2-2-2-2)
Posted by: @holy-cow
You set two monuments on a survey 10 years ago that were measured then as being 400.00 feet apart.?ÿ Now you are creating a new tract along that same line and put 400.01 feet in your description that gets recorded.?ÿ
Anyone who does that is NOT a surveyor. ?????ÿ
Posted : February 18, 2021 5:32 am
(@aliquot)
@bstrand
I am not trying to be difficult, but I still don't understand how your resurveys always find that lost corners should be placed within 0.1' of the record.?ÿ
The horizontal accuracy standards are for your measurements not existing conditions. If you calculate a lost corner position to be 0.09' off the record and report record instead of the actual distance you are likely not meeting the the?ÿ accuracy requirements.?ÿ
Posted : February 18, 2021 7:20 am
@holy-cow
I experience editing of my descriptions. The last one I sent out has a reference to the ROS I did, I will put in the description a call for the ROS. The title people took that out. I filed the ROS anyway. They will sometimes remove my basis of bearings, area, distance adjustment factors. Also I include a file path on all my descriptions which is an internal note for me, that normally gets removed.
But, descriptive calls, bounds; those I've never seen removed. That would be a big editing job for someone.
As far as I'm concerned any alteration of the description beyond my internal note reduces or removes any liability I have.?ÿ
I'm in agreement that keeping the original description intact is good,,,,,,until it's altered. When pieces are sold off or added the original description often can use an update beyond listing exceptions or additions. Otherwise, might as well describe the original patent and list all the subsequent grants: an abstract.?ÿ
Posted : February 18, 2021 7:45 am
Say you have a nine sided tract where every monument is actually an "+" cut into a smooth concrete surface.?ÿ You use your magic box to gather data as you shoot all nine monuments.?ÿ Two days later you send out a trusted co-worker to do the same thing.?ÿ Guess what.?ÿ The resultant data will not be in exact agreement, especially so far as bearings are concerned.?ÿ You go back out to verify your data.?ÿ Guess what.?ÿ The results are not exactly the same as either of the two prior runs.?ÿ The monuments did not move anywhere other than in your imagination.
Don't screw with the record.
Posted : February 18, 2021 7:57 am
@bstrand
Shouldn't you be considering how those pins fit the adjoiners also??ÿ If a pin is missing, don't you proportion between your client's found pin and an adjoiner's found pin?
Posted : February 18, 2021 9:27 am
(@lurker)
Murphy, I agree very much with this "It would appear that it is our assumptions of the layperson's ability to understand our plat that dictates whether we show our measurements or whether we tell harmless white lies."
Laypersons will use our plats. All of them will not be sophisticated and the more we can do to prevent laypersons from misusing our information the better. You might be able to educate each and every one of your clients but there is no way to educate everyone who might use your plat, at least in a recording state.
Posted : February 18, 2021 9:37 am
(@bstrand)
@bill93 In a platted subdivision, yes.
Posted : February 18, 2021 9:39 am
Another problem comes about in the following fashion.?ÿ A county did some significant work which would cause a section corner monument to be torn out in the process.?ÿ They used proper procedure and had a licensed surveyor involved to reset a new monument.?ÿ The problem is that the new monument is roughly 0.03 west and 0.03 south of where the old one was.
A different surveyor comes along and uses the new monument.?ÿ ?ÿAn existing tract was created using the old monument with dimensions, let's say of 600.00 feet by 600.00 feet.?ÿ Thus the monument to the west is now shown as being at 599.97 feet, as is the one to the south.?ÿ The new tract is to be an L-shape around the first tract.?ÿ Thus, the new description commences at the new corner monument then runs along the north section line to the existing monument, south to another existing monument , east to the existing monument on the east section line and back to the northeast corner of the section.?ÿ The problem is that the new tract is labeled as beginning at the 599.97 distance instead of the 600.00 distance and so forth.?ÿ Therefore, the two deeds overlap by 0.03 feet.?ÿ If the new monument had ended up 0.03 east and 0.03 north of the original monument there would now be a gap of 0.03 between the two tracts.?ÿ Who owns that worthless strip?
Posted : February 18, 2021 1:49 pm
@murphy
Let us remember that our primary duty is to safeguard the rights of the public. Sometimes that does mean dumbing things down for the benefit of the public. Very often, precise measurement is not the primary goal. Monumenting, documenting, and preserving marketable title is.?ÿ?ÿ
Every measurement is plus or minus some amount. The plus or minus is not noted, but it is always there in the record dimensions and in your new measurement nevertheless. If the plus or minuses overlap both measurements are equally valid. Why cloud the record??ÿ ?ÿ?ÿ
Posted : February 18, 2021 2:33 pm
(@aliquot)
Good arguments here for not reporting distances to the nearest 0.01'?ÿ
Posted : February 18, 2021 2:41 pm
(@dmyhill)
@lurker
This is where significant digits needs to inform our decisions. Sure we put down 400.00 because we have to, but in almost all of our real world experience, 400.00=400.01?ÿ
Why put down the same number twice??ÿ
Posted : February 18, 2021 6:40 pm
(@dmyhill)
@aliquot
Significant digits are...significant!
Posted : February 18, 2021 6:47 pm
(@field-dog)
@holy-cow
Wouldn't common sense tell you to split it between the two tracts?
Posted : February 18, 2021 7:45 pm
(@aliquot)
@holy-cow
There is no strip. There is no problem. There is no gap. The monuments control, not the reported distances.?ÿ
Posted : February 18, 2021 8:24 pm
I knew a surveyor that rounds his dimensions to the closest minute, and tenth of a foot.?ÿ
the problem that erupts is that a 20 course description could fail to close by some amount, inclusive of the tangent of 29ƒ? x the distance of each course. Plus 0.05ƒ??
This can accumulate quite a bit, depending on the size of the tract. I wish Carlson had a program to allow every brg ?ÿand dist to change by 0.044ƒ?? and 0d00ƒ??29.4ƒ?, and that it would force a closure.?ÿ
For this reason, I publish brgs to the second, and distances to the hundredth.?ÿ
Iƒ??m not saying that each course is that precise. I am keeping the overall integrity intact.?ÿ
ymmv.?ÿ
thank you
Nate
Posted : February 18, 2021 8:31 pm
Page 2 / 6
