Bid this
18 Users
(@steve-gilbert)
Full ALTA survey in suburban Birmingham on a 35 acre open air shopping center with 60 boundary corners. There is one long building, a separate building that once held a Kmart, and a third strip shopping center with about 10 stores. There is a survey from 2005 by a company from North Carolina. Basically all Table A items, except for a topo, are requested.
Steve
Posted : December 27, 2011 10:33 am
(@pin-cushion)
20 large bare bones..... And I am a registrant of Alabama. If I did it in 2005 it would still cost you 15k
Posted : December 27, 2011 10:56 am
(@spledeus)
Why not 25k?
Posted : December 27, 2011 11:38 am
(@pin-cushion)
Sure, why not... I will do it for 25 too, since I
Am not going to do it anyway 😉
Posted : December 27, 2011 11:41 am
(@snoop)
$18k
bet it goes for $8k
Posted : December 27, 2011 11:43 am
(@joe-the-surveyor)
I'd say about $20-28,000.04
Posted : December 27, 2011 12:14 pm
(@neil-shultz)
I am thinking $19,999.96
Posted : December 27, 2011 12:18 pm
(@steve-corley)
$14,874.12
That is $1,500.000* the SQRT of the Acres
1500*5.1961=8,874.12
Plus $100.00 per corner.
100*60=6000
8,874.12+6,000.00=14,874.12
Posted : December 27, 2011 12:29 pm
(@mike-mac)
20K popped into my head when I read the first post..whatever it was I would say x amount, plus pins...
Posted : December 27, 2011 1:06 pm
(@beadlesh)
I like your formula Steve
Posted : December 27, 2011 1:48 pm
(@foggyidea)
Bid this-spledeus
But you wanted to charge 20K for a 3 1/2 acre alta when you already had all the site info in house? I thought 8k was fair and not low balling. Can you explain why only 5k more for about 10 times the work?
Posted : December 27, 2011 2:46 pm
(@john-giles)
I bid jobs by estimating days I will spend on it. Even a partial day is counted as a full day.
I will charge the same for a half day job as I do for a full day job. Makes no sense not to.
A day is a day whether it be 2 hours or 12 hours.
How much do you charge per day?
Posted : December 27, 2011 2:59 pm
(@just-mapit)
35 acres and 60 corners are about 80 or so feet apart on average. I'd say the Boundary would be $4,950. Setting pins not found during the course of survey is tough to estimate but I think $100-115 a corner is about right. Location of improvements would be about 7-8 days. Drafting would be roughly 4-5 days assuming data collection and line work is done. Checking and review would be 12-16 hours. Research (in my experience) would be about 4-5 hours with an existing title report in hand before so and, assuming you're not a million miles from the courthouse and do not have online access.
Without setting corners not found it looks like somewhere between $16,270-$16,800. These numbers are based on $50 for cadd, $115 for field crew and also LS. I have done these before and parked cars can be a pain. You would have to add a few thousand in for a sub to locate underground utilites (table A) and the location of such.
Posted : December 27, 2011 3:43 pm
(@snoop)
$1,000
Posted : December 27, 2011 4:48 pm
(@joe-the-surveyor)
Apparently
The firm in Florida will charge $295+;-)
Posted : December 27, 2011 6:38 pm
Apparently
$3500 will take it. It's worth much, much more, but, some schmuck will grab at anything he can find to keep his guys busy.
Posted : December 27, 2011 7:07 pm
Not me, no way, not bidding.
Posted : December 27, 2011 7:16 pm
(@jimmy-cleveland)
I'm guessing the $17k to $18k range. That's a lot of work, but I doubt it will go for much higher than that.
Please post an update to let us know the ballpark range, just out of curiosity.
Thanks, and good luck!
Posted : December 28, 2011 6:01 am
(@boundary-lines)
It is the dead of winter, you could have it flown and reduce your overhead costs if schedule permits.
Posted : December 28, 2011 6:15 am
 vern
(@vern)
That is an interesting formula, and surprised me it came up to about what i would bid the job ($15k). I got there from 7 days field at 5 acres/day plus office time.
Posted : December 28, 2011 12:20 pm
