1953 K & E tilting level
8 Users
(@kevin-davis)
I traded a client out of this K & E level. Made in 1953 per the serial number. Only problem is I can't focus the cross hairs. Anyone on here ever use one of these? Any suggestions on how to loosen the eyepiece to focus the crosshairs?
Kevin
Posted : October 19, 2012 3:23 pm
(@2xcntr)
Try pulling straight back on the eyepiece as you very slightly rotate it counter-clockwise. There is a bit of lube on that part that's probably dried up some.
Nice piece, good luck
Posted : October 19, 2012 3:48 pm
(@kevin-davis)
OK thanks. There is also a very small screw sticking out of the eyepiece. Maybe a place to insert lubricant?
Posted : October 19, 2012 3:51 pm
(@2xcntr)
I would not do that. If my suggestion does not work you will probably need to unscrew the complete eyepiece assembly to free up the eyepiece focus. Sometimes that can be done by gripping it tightly with your hands and turning CC. Sometimes it needs some more encouragement. The assembly I am talking about is the eyepiece end of the telescope (the rear 1 inch or so... not the eyepiece itself)
Posted : October 19, 2012 4:06 pm
(@2xcntr)
It might be useful to post some other views of your level. I'm not seeing the adjustment capstans for the crosshairs. That makes me wonder about the levels construction. Whatever you do do not force anything.
Posted : October 19, 2012 4:10 pm
(@foggyidea)
Take the lens cap off! 🙂
Posted : October 19, 2012 4:54 pm
The Texas Highway Department had a number of K&E levels with that same tan finish on them. I had thought it was a special order for our sunny climate. Now I wonder where else levels in that color were sold.
Posted : October 19, 2012 8:26 pm
Looks like the same color as the K&E 6e(s) that I used back in the 70s.
Posted : October 19, 2012 9:00 pm
(@kevin-davis)
I'm guessing this level was manufactured in Detroit. It was found in an attic in Michigan (probably near Auburn Hills, where my client lives.)
Posted : October 20, 2012 3:11 pm
(@kevin-davis)
I'm guessing this level was either made and/or sold in Detroit. It was found in an attic at an estate sale I'm assuming not too far from there.
Posted : October 20, 2012 3:30 pm
(@target-locked)
Kevin, how did you use the serial number to find out what year it was made? Website?
Posted : October 20, 2012 5:33 pm
(@2xcntr)
Try here:http://www.surveyhistory.org /">survey museum
Posted : October 21, 2012 2:51 am
(@kevin-davis)
www.surveyhistory.org/how_old_is_my_k_&_e%20Instrument.htm
Posted : October 21, 2012 12:43 pm
(@stephen-johnson)
You have something in that picture I haven't seen since the mid 60's. A key to the box.
B-)
Posted : October 22, 2012 11:28 am
funny memory
The pic above has a tag that says "eye end".
One of our old wye level boxes had a similar tag on the inside of the box that said, "Objective". I don't think anybody knew what that meant.
The level would fit both ways, but the lid wouldn't shut if was in there bassackwards. Sooo..one of the mental giants on the crew drew an eye with a magic marker on the side opposite the 'objective' tag. Problem solved...I guess.
Posted : October 22, 2012 12:06 pm
