TGO on windows 10-64bits
9 Users
(@djchadli)
HI EVERYBODY
I have troubles using TGO v1.62 ON WINDOWS 10-64bit , after successful installation ,try to run it but nothing happen .
did anybody try it befor ?
need a solution if possible
thank you
Posted : 22/10/2016 11:41 am
(@rberry5886)
I have TGO 1.63 on Windows 7-64 bit, no problems, this is probably why I didn't upgrade to 10.....other than that I can't solve your problem...
Posted : 22/10/2016 12:14 pm
(@christ-lambrecht)
There are detailed instructions on how to install on Win7, did you follow these??
Posted : 22/10/2016 1:46 pm
(@rberry5886)
Christ, I think he is looking for windows 10 help....
Posted : 22/10/2016 2:24 pm
(@john1minor2)
djchadli, post: 396463, member: 12219 wrote: HI EVERYBODY
thank you
TGO will not run on W10. I've tried every trick I know. If you get it going, be sure to let us all know the secret.
Posted : 22/10/2016 4:25 pm
(@totalsurv)
Did you try compatability mode in Windows 10?
Posted : 23/10/2016 7:03 am
(@john1minor2)
Totalsurv, post: 396522, member: 8202 wrote: Did you try compatability mode in Windows 10?
I don't know if DJChadli tried but I did and it still didn't work. Good thought though!
Posted : 23/10/2016 9:07 am
(@bryce)
I have it running kind of: Install in compatibility mode for windows 7 or xp service pack, and it can be used for most of it's features my problem and why I say kind of is that when you do the rinex dates workaround and then proceed to process it does complete the post processing but almost always crashes when completed, then I restart TGO and the completed file is there but there are always some errors to work through.
Posted : 23/10/2016 10:06 am
(@djchadli)
hi everybody . i have tried all kind of compatibility issues nothing works , W10 x64bit won't run TGO
Posted : 29/10/2016 9:13 am
(@djchadli)
hi , i came back after 5 years , windows 11 64bit , TGO works but while importing file , it crashes ,any one tried it ?
Posted : 19/10/2021 3:52 pm
I haven't used TGO in over 10 years, but it seems to me that there are some GPS rollover week issues with that software.
Posted : 21/10/2021 6:46 am
@norman-oklahoma Similar, it's a billionth second problem.
Posted : 22/10/2021 3:54 am
(@goodgps)
I am using TGO 1.62 on Windows 10. The trick is to ONLY use files that were created on the windows 10 machine.?ÿ Windows 10 will NOT grab old files to work with .?ÿ This is why I have kept an old Windows 7 machine?ÿ to use with old files.?ÿ ?ÿ As time goes on, I am creating new files in the 10 machine and inserting the old DC file into them.?ÿ This works.?ÿ ?ÿSo glad I made copious backups since 1995 even the old trimmap stuff.?ÿ and TSO?ÿ good luck?ÿ
Posted : 25/10/2021 9:21 am
(@djchadli)
@goodgps
you mean the trick is to ONLY use files that were created on the windows 7 not 10 machine.?ÿ Windows 10 will NOT grab old files to work with .?ÿ
am i wrong ?
Posted : 10/11/2021 3:53 pm
