Trying out a demo of Survnet and trying to close a big loop, 59 setups. Horizontal only.
Keep getting this error :
Here's the start of my rw5
[inlinecode]JB,NM11-3-14,DT11-03-2014,TM15:34:58
MO,AD0,UN2,SF1.00000000,EC0,EO0.0,AU0
--SurvPC Version 4.00
--CRD: Alphanumeric
--Equipment: Leica Robotic Total Station, TS12
--TS Scale: 1.00000000
--Scale Point not used
--EDM Mode: Standard
--P.C. mm Applied: -30.0000 (-30mm:backsight)
--P.C. mm Applied: -11.3000 (Leica 360:foresight)
--Set Collection with Obs Order 123...321...
CSE,N!,E!,EL*,AZ*
SP,PN1,N 752205.8100,E 1159155.2400,EL406.2000,--SPK1
SP,PN2,N 753206.0300,E 1159047.3800,EL311.1200,--SPK2
--SP,PN3,N 753316.7687,E 1159379.7931,EL0.0,--SPK3
CSE,N#,E#,EL*,AZ*
OC,OP2,N 753206.0300,E 1159047.3800,EL311.1200,--SPK2
LS,HI5.570,HR6.960
BK,OP2,BP1,BS,BC0.0000
LS,HI5.570,HR6.960
BD,OP2,FP1,AR0.0000,ZE5.2329,SD1010.494,--SPK1
LS,HI5.570,HR5.50
FD,OP2,FP3,AR257.4349,ZE358.5357,SD350.497,--SPK3
FR,OP2,FP3,AR77.4352,ZE181.0558,SD350.499,--SPK3
LS,HI5.570,HR6.960
BR,OP2,FP1,AR180.0005,ZE174.3628,SD1010.493,--SPK1
--Warning: Vertical Angles to backsight differ by 0°00'00".
--Warning: Horizontal Angles to foresight differ by 0°00'02".
--Warning: Vertical Angles to foresight differ by 0°00'05".
--SS,OP2,FP1,AR0.0000,ZE84.3629,SD1010.493430,--SPK1
--LS,HI5.570000,HR5.50000
--SS,OP2,FP3,AR257.4348,ZE91.0600,SD350.498015,--SPK3
--LS,HI5.570000,HR6.960000
LS,HI5.570,HR6.960
LS,HI5.570,HR6.960
BD,OP2,FP1,AR0.0000,ZE5.2328,SD1010.495,--SPK1
LS,HI5.570,HR5.50
FD,OP2,FP105,AR355.3810,ZE0.0445,SD137.679,--IPIN105
FR,OP2,FP105,AR175.3809,ZE179.5503,SD137.680,--IPIN105
LS,HI5.570,HR6.960
[/inlinecode]
Any insight what I'm doing wrong based upon that? The bottom of that error message screen is reporting an AZ from 1-2 of 0 which is obviously incorrect but I can't see the line where that's being defined in the RW5. The crd file is generating correct coordinates.
Random sample of one of my rw5 files:
OC,OP1,N 2941.220999,E 6563.459544,EL0.0,--
BK,OP1,BP5,******BS34.005221********,BC0.0000
Yours:
See the BS has no numbers behind it--
BK,OP2,BP1,*****BS*****,BC0.0000
You need to examine how points 32 through 36 are attached to your traverse before you worry about other stuff.
Trying to learn this with a 59 sided traverse is not the way I'd recommend you do it. In the words of Sensei Miyagi, "must walk before can run".
All I can say is when I remove your angle sets (BD, BR, FD, FR) and turn on the side shots things start working
EDIT:
OK I think I have your problem.
In Your angle sets you have zenith angles of 5°, 358°, 181° & 174°. I believe these should be vertical angles. After I changed the codes from ZE to VA the file you posted starts to process.
You need to figure out why when you imported your data it assigned the ZE code and not the VA and/or why your instrument is using vertical angles for angle sets and then reporting zenith angles for the side shots. I don't use Leica so I can't help there.
> Yours:
Yup. Had that happen to me.
I've examined those points and the only thing different is I turned 32 in multiple sets instead of just one set. Don't know why that would confuse the program but who knows.
Thank you. That was it. I was messing around in the RW5 editor previously and had switched ZE to be displayed as VA just as a curiosity. It must save it to the rw5 instead of just being a display toggle.
