I'm trying to extract a *.vdf file from DEFLEC12A grid files. I have grids 1 & 5, N-S & E-W components in little endian downloaded. When I try to extract a user defined sub-grid using Star*Geoid, the extraction process just spins its wheels and never finishes.
Well, if you downloaded the grid files for Xi and Eta, you're doing better than me. I just tried to download them for Grid #6 and while the file with the Xi components came right through, Eta gives me only this:
>You don't have permission to access /PC_PROD/DEFLEC12A/Format_pc/ehg12Au6.bin on this server.
I wonder if the NGS server is just having a bad day. Have you tried downloading the files again just to make sure one wasn't corrupted?
I had the same problem, but sadly don't remember how I solved it. Try making sure your defined sub-grid lies entirely within the grid files you downloaded, and mess around with the LL format you input. I have only had to do this a couple of times, and I remember it not working on the first try in each instance. Sorry.
I'm in the process of doing that now...
I managed to get grid #6 files, I can't convert those either.
Would you like the grid 6 files?
I'm going to try again to download the Eta file.
Well, this is just strange. I can download all of the Xi files, but requesting most of the Eta files in PC binary format just gives the same "you don't have permission ..." message.
Contents of ETA grid #5
Forbidden
You don't have permission to access /PC_PROD/DEFLEC12A/Format_pc/ehg12Au5.bin
on this server.
Is this what you are seeing for grid 6?
Yes, that's the error message that appears when I click the file link to download it.
I didn't get the error message. I only noticed something was a miss when the file only contained 1kb of data. I sent an email to the NGS webmaster inquiring about the issue.
I get the same error with every grid # I've tried (except #0).
I downloaded Grid 0 several months ago, and that's what I have been using. It contains ALL eight sub-grids (I think).
RESTRICTED ACCESS; Reply from NGS Webmaster
Brian,
There is nothing wrong with the server, but you are correct, these files have been restricted. I will contact the developer and if they are ready for release I will update the permissions and email you. I hope he will reply shortly.
Regards,
David Gietka
NGS Webmaster
Brian,
The permissions have been corrected. Please let me know if you still have trouble downloading the files.
Regards,
David Gietka
NGS Webmaster
THAT WAS A QUICK RESPONSE! let's see if it works.
Success!
Yay!
