My TBC Started Misbehaving
2 Users
BStrand
(@bstrand)
Member P&R
I have 2 problems I'm trying to figure out now that seemed to start out of thin air.  The first one is my google background map no longer turns on and I get this popup message:
I'm logged into my Trimble ID so I dunno what the deal is.  Anyone run into this before?
And then the other one is this error message which is totally screwing me:
Absolutely nothing changed with the file.  I have checked the file name over and over, I've moved the file to a different location and I keep getting this error.  I can't process my data in TBC to fix codes before I move it to cad.  Anyone know how to fix this?
Posted : May 30, 2026 8:22 am
Topic Tags
Bob Westerman
(@bobwesterman)
How up to date are you with your TBC.  I was having problems with path names a couple weeks ago which I am pretty sure were caused by a Windows update. I looked at my TBC check for updates and there was one there for something like Trimble shared resources. Ran that and everything seems to be fine now.
For the background mapping problem I don't have a clue.
Posted : May 30, 2026 9:43 am
BStrand
(@bstrand)
Member P&R
@bobwesterman I have a perpetual license but it only goes up to version 5.90 which is what I have installed.  I may renew the maintenance later this year before it goes to subscription only, but I don't see why things that were working fine before suddenly broke.  I would be genuinely surprised if it was a Windows issue.
Posted : May 30, 2026 12:30 pm
Bob Westerman
(@bobwesterman)
Posted by: @bstrand
Well if the TBC hasn't changed, what else has?
Posted : May 30, 2026 1:38 pm
BStrand
(@bstrand)
Member P&R
@bobwesterman Nothing that I know of, but I'll keep poking around.  I did install a thing in the TBC updater Called Trimble Shared something but that didn't seem to fix anything.
Posted : May 30, 2026 2:30 pm
Bob Westerman
(@bobwesterman)
Posted by: @bstrand
One thing I would definitely recommend if you do decide to upgrade.  Make sure you run the Trimble cleanup tool before doing the new install.  A lot has changed in TBC since version 5.9.
I ran into serious problems going from 2024 to 2025.
The cleanup tool fixed them.
Posted : May 30, 2026 2:36 pm
BStrand
(@bstrand)
Member P&R
@bobwesterman I normally just uninstall the whole thing and reinstall.  There's a website where you can download a zip file of your version so if you save that you can reinstall it anytime.  That's what I've been doing anyway.
I think I found the problem with the .fxl now.  I must have broken a code at some point because when I make a dummy new .fxl it processes fine.
Posted : May 30, 2026 3:11 pm
BStrand
(@bstrand)
Member P&R
OK, found the broken code so that fixed that problem.  Maybe there is a way to see it that I don't know about, but TBC offered zero explanation as to what specifically was going on.  I had to delete every single code 1 at a time and then try to process with the file to ID the broken code.  So dumb...
Chatgpt actually suggested this method of finding out what the deal was.
Posted : May 30, 2026 5:56 pm
Bob Westerman
(@bobwesterman)
Posted by: @bstrand
We keep the last few versions on the Server in case we need to reinstall. The clean up utility does the whole uninstall and then some, looking for all the registry stuff that sometimes gets missed in the regular uninstall. I used to only do that if there was a problem, but now I've been doing the cleanup for every major version.
It doesn't take much longer and will find thing that were missed from previous uninstalls, avoiding problems before you know they are there.
Posted : May 31, 2026 9:25 am
