MS Access Query
5 Users
ppm
 ppm
(@ppm)
I have a dateset of 1000's of projects. I am adding a new Field called Pinned. I want every Job # that contains an Asterisk to have a Yes (or True) value for the Pinned Field.?ÿ
In Design View "Select" I have it looking like this"
In Design View "Update" I have it looking like this:
But My results after I run it do not mark "Yes" (or True) by checking off the box under the Pinned Field, it looks like this after I run the query:
Here is how my SQL looks:
I looks like in the SQL that it is not doing any "Update to" items??
Help an amateur access guy out please!
Posted : August 27, 2021 7:30 am
My wife says to try changing the format of the "Pinned" field to text. Let me know results.
Posted : August 27, 2021 8:22 am
ppm
 ppm
(@ppm)
I gave it a shot after changing the "Pinned" field to Short Text data type, and it did not run any differently. And my SQL view looks the same still.?ÿ
Thanks for the idea. I am kinda new to access and kinda not liking it.?ÿ
Posted : August 27, 2021 9:17 am
ladd-nelson
(@ladd-nelson)
Posted by: @ppm
I believe I've got this.?ÿ PM me at lnelsonATcarlsonswDOTcom and I'll give you what I believe will work.
It's too late in the evening for me to tap it out on my cell phone.
Posted : August 27, 2021 9:44 pm
chris87
(@chris87)
I believe the * is a wildcard character.
So is the ?.
Try using something else.
Posted : August 28, 2021 4:24 am
field-dog
(@field-dog)
My wife is working on your problem. She's an Access pro.
Posted : August 28, 2021 7:04 am
field-dog
(@field-dog)
My wife says you can create a query that will return just the job numbers containing an asterisk without creating a pinned field. What's the purpose of the pinned field? It has been a very long time since she has worked with Access, but she's willing to help. I'll keep you updated.
Posted : August 28, 2021 10:22 am
ladd-nelson
(@ladd-nelson)
If you want to select the records that have just an asterix, use the InStr() function with the Chr() function as the following:
SELECT [CLIENT DATABASE].[JOB #], [CLIENT DATABASE].PINNED
FROM [CLIENT DATABASE]
WHERE ((InStr(1,[JOB #],Chr(42))>="1"));
To update the PINNED field to True (Yes) from records in "JOB #" that contain an asterix, your query would resemble:
UPDATE [CLIENT DATABASE] SET [CLIENT DATABASE].PINNED = True
WHERE (((InStr(1,[JOB #],Chr(42)))>="1"));
To update the PINNED field to True (Yes) from records in "JOB #" that contain an asterix AND remove the asterix from the "JOB #" field, you would use the Replace() function and your query would resemble:
UPDATE [CLIENT DATABASE] SET [CLIENT DATABASE].[JOB #] = Replace([JOB #],Chr(42),""), [CLIENT DATABASE].PINNED = True
In your query, you can right+click on the Query name and set the view from Design View to SQL View and paste the query string(s) above.
I hope this information helps.
Posted : August 29, 2021 6:33 am
ppm
 ppm
(@ppm)
@ladd-nelson?ÿ
Thank you Ladd. I will give it a try on Monday.
Posted : August 29, 2021 4:50 pm
ppm
 ppm
(@ppm)
@field-dog?ÿ
Thank you for that suggestion.?ÿ
The asterisk is there to indicate the Job number has been "Pinned" in Google Earth. I am trying to get it in a separate field so it isn't in the job number field.?ÿ
If I can first query the asterisk, and Check (or 'Yes') in the pinned field, then...?ÿ I think I know how to remove the asterisk from the job number field.
I will try what Ladd suggested on Monday. Thank you for assisting.?ÿ
I will post an update if I get it.
Posted : August 29, 2021 4:56 pm
