Mosaic in acad from google earth images
johnymal
(@johnymal)
Does anynone knows if there is a program or a way to take multiple images from google aerth to create a big mosaic in autocad?
Posted : May 26, 2016 4:41 pm
Why not just use Autodesk 360 and get the image for the entire area?
Posted : May 26, 2016 4:51 pm
cameron-watson-pls
(@cameron-watson-pls)
I haven't used the 360 option but if you have your coordinate system set in C3D you can use the Geolocation tab to create as large of an aerial map as you want.
Posted : May 26, 2016 5:03 pm
jeffrey-diamond
(@jeffrey-diamond)
I use this one:
http://www.plexearth.com/
It can be a little bit more involved than the geolocation function, but the images are MUCH better if you do it correctly.
Posted : May 27, 2016 4:30 am
cameron-watson-pls
Interesting Double D. Do you by chance use or have available Autodesk InfraWorks? I'm curious how the images compare to what you get out of that. I think I'll give the trial a go. The price is pretty reasonable.
Posted : May 27, 2016 8:20 am
