Intellicad/Carlson 2016 Dimension Leader Text Question
hlbennettpls
(@hlbennettpls)
I have a question about getting the Mtext box text to set and stay set at "by layer". Every time I do a text leader, I get the text at a different color than my layer is (it's usually white, and NO this isn't while in the editor, this is on the screen after I've entered the text in and pressed "Ok"). I know it's probably just a setting, but I don't know where to find it.
Thanks,
Posted : March 3, 2016 3:49 pm
adam
 adam
(@adam)
Draw, Leader with Text, check use current drawing properties. Try that
Posted : March 3, 2016 4:04 pm
hlbennettpls
(@hlbennettpls)
Adam, post: 360604, member: 8900 wrote: Draw, Leader with Text, check use current drawing properties. Try that
Would this be found under drawing settings?
Posted : March 3, 2016 8:15 pm
adam
 adam
(@adam)
Under draw tab, then leader with text, then type o for options.
Posted : March 4, 2016 5:32 am
Posted by: Adam
Thank you.
Posted : May 19, 2018 9:48 am
