Carlson Civil 2015
Any idea why when I issue the command CL2PLINE, the routine attempts to store coordinate points? Somehow it is pulling a setting from some other routine? Luckily point protect is turned on so I don't trash my coordinate file. I have to hold the escape key down and cancel the creation of dozens of points.
I'd love to be able to stop having to do this....Ladd?
Posted : March 3, 2016 6:32 pm
ladd-nelson
(@ladd-nelson)
imaudigger, post: 360625, member: 7286 wrote: Any idea why when I issue the command CL2PLINE, the routine attempts to store coordinate points? Somehow it is pulling a setting from some other routine? Luckily point protect is turned on so I don't trash my coordinate file. I have to hold the escape key down and cancel the creation of dozens of points.
From what I was told:
[INDENT=1]"The CL2PLINE routine does not require a CRD unless you have the option on in the Draw Centerline dialog to Label Centerline, and your Label Centerline settings have the options on for Locate Points."[/INDENT]
I tested this with both Carlson 2015 and Carlson 2016. I hope this information helps.
Posted : March 4, 2016 8:40 am
rich-roberge
(@rich-roberge)
Do you have Point Numbers unchecked under point defaults? That might do the trick.
Posted : March 4, 2016 8:51 am
Thanks guys, it seems to be drawing specific. I think I will chalk it up to being a mystery and move on with a new drawing.
Posted : March 4, 2016 10:19 am
