Carlson, won't allow decimal seconds, in ROTATE coords
5 Users
I know it's pedantic, but, I like my linework, and my coords to be 100% the same. When I use the ROTATE command, in Carlson, it forces me to only work to the nearest second. The work around that I know about is the MOVE the points, one by one via move command, and then update the coord file.
I'd like to be able to rotate the points, without the rounding. I know, I'm a member of "Central Arkansas pedantry group", but CAD like some things...
Is there a setting to change this? I'm in 2009, to keep from intellicad...
Thank you
Nate
Posted : September 29, 2020 3:19 pm
rundatline
(@rundatline)
I use ALIGN most of the time. Are you checking the box for include screen entities?
Maybe I'm missing your hiccup. Edit. these options may not be available in v2009.
Posted : September 29, 2020 3:51 pm
Norman_Oklahoma
I also use ALIGN for that sort of thing. Look into it. Very handy.
Posted : September 29, 2020 10:23 pm
aliquot
(@aliquot)
Another option is to rotate by reference to two points. This will preform an exact rotation.?ÿ
Posted : September 30, 2020 11:31 am
mag-eye
(@mag-eye)
You could always make a block of the points you wish to move. move and rotate away, once happy with the position explode block and update crd from dwg?ÿ
Posted : September 30, 2020 1:24 pm
I use align. I like it.
It's an add on, to acad, and it's set to round to nearest second.
Phoow!
Thanks!
Posted : September 30, 2020 2:06 pm
